Stickiest, most heavy duty, best quality duct tape
expfcwintergreen
I need it to stick to a plastic cover.
My Dad, who was a pipe fitter, used to have some really great duct tape, but I never looked to see what brand it was. It was very strong; the backing was a dark green color. Maybe I haven't been looking in the right places, but all I can find is some thin, half sticky grey backed duct tape.
Any good brands left?
amolaver
Gorilla tape - will pull the paint off a car (damhik). It's black (not sure if they sell other colors). Available at home depot, not sure where else.
ahm
E
expfcwintergreen
ahm
Thanks, that sounds like what I am looking for. The color wasn't important; I just thought it might jog someone's memory.
CNGsaves
KS and OK
Well do NOT get the "Duck" brand as it's pretty worthless once the going gets tough. Tried using it to tape down wires on trailer before I drove in rain, and tape came off nearly immediately when wet. With all their colors and ****, they've lost their way of being useful for intended purpose.
Instead bought camouflage colored tape I found at Walmart and it stuck really well in the rain. The brand is Gorilla tape. It WORKS! Even after trip in rain with trailer wires taped down, the tape was still sticky.
Old school gray duct tape is harder to find that actual has stick to it.
ishiboo
Oshkosh, WI
Gorilla Tape is awesome. It comes in white on the full-size rolls as well. I tried it when Menards ran out of drain tile tape and it's really good stuff.
Also necessities in your tape aresenal:
1. Gaffers tape
2. Aluminum tape like UL181AP. Great for repairs/etc.
3. 3M VHB (permanent double-sided tape)
The Gorilla tapes that are similar to duct tape are also Made in the USA.
jakemac
New England
Another vote for Gorilla Tape.
If possible, warm the tape and the tarp above 50° before applying for a quicker bond.
E
expfcwintergreen
It isn't very often that there is such a consensus of thought here or anywhere else. I'm sold. Gorilla tape must be great. Thanks to everyone.
E
expfcwintergreen
1. Gaffers tape
I think I may have used aluminum tape on a muffler. I will look in to the others. Thanks.
General Geoff
Allentown, Pennsylvania
Yeah, someone shattered the rear side glass on my '96 S10 Blazer, and I taped over it with Gorilla tape (used almost 2 rolls, that window is pretty big). The truck was a $200 beater so was not worth replacing the glass. I drove that thing with the tape on it for almost a year, and it was still waterproof and holding fine.
T45
ahm
Gorilla is good :thumbup:
In my experience you don't want the glue to "feel super-sticky", the really good adhesive will take a little bit of tack before it sets up. But once it sets up, it doesn't slip or come-away from the backing. For some reason super-sticky ductape usually means the adhesive is crappy or old, and then its likely to stick to whatever, but won't have the structral integrity you need or want. This stuff usually leaves a mess behind when it is removed, whereas the good stuff will just peel the paint of :lol::lol::lol:.
eborcim
Central, MO
another vote for GT.
A little off topic, if you decide to use GT's kin, Gorilla Glue, wear nitrile or similar gloves as it will not wipe off once on your skin. Also it expands like sealant foam from any crevice.
Thumper68
Duluth MN
another vote for the Gorilla tape, and their line of glues as well. Awesome stuff when you need it to stay stuck.
ncfh
Gaffer's tape being suggested as "stickiest, most heavy duty duct tape"??? lol wut?
The whole point of gaffers tape is that it is temporary and won't ruin whatever you stick it to.
That tends to mean its NOT the stickiest, most heavy duty duct tape replacement. And as with actual duct tape, there at many brands of gaffer's tape, and many of them are about as sticky as scotch tape.
So no, gaffers tape isn't "what the pros use" in the OPs situation at all. They use the right tool for the job, not just what sounds cool or elite.
Signed grouchy old gaffer
Fugio
Gaffers tape is NOT supposed to be very sticky. It's purpose is to leave no residue. In my line of work we call it "Rock-N-Roll tape." Same thing.
Gorilla tape is what you want!
jakemac
New England
The best duct tapes have a name, and that name is gaffer's tape. (it's what the pros use)
I was one of those pro's for 15yrs. Gaffer's tape is wonderful for many jobs. Much better than duct tape. BUT, it doesn't adhere as well as Gorilla tape in cold, or moist conditions. And can have issues adhering to some plastics. As another poster stated, the adhesive that is used was intended for temporary installations. Over time, in weather, the cloth backing will break down and the adhesive dries out and becomes chalky. It will last longer than Duct tape, but not longer than Gorilla tape.
I've had Gorilla tape sealing a rip in the cover of my storage tent for almost a year now. I applied it during a rain storm in the winter. It's still holding. As much as I love Gaff tape, it wouldn't have stayed on more than 10 minutes, if that.
Bigblue&Goldie
I once used Gorilla Tape to keep a friend's boat from sinking in Lake Havasu. The rearend was under water, so we needed to seal off all of the vents to pump it out. GT worked like a champ! Nobody else there knew it would still adhere under water, but they all ended up buying a roll to keep in their own boats after that. A $5 roll of tape saved a $1,500 vessel assist bill.
markbugno
Boardman, Ohio
Shurtape PC 622 (black) is a great duct tape. Not sure how it compares to gorilla tape which I've never tried.
Another great tape is a fiberglass reinforced tape made by tesa tape. When I work for Siemens Westinghouse, it's actually their policy to wrap all impact sockets in this tape when being used with a hytorc (hydraulic torque wrench), in case they shatter. Good stuff.
DennisH2014
Definitely Gorilla Tape I would say! I'm not huge on duct tape these days, since I've discovered so many other options, but it works when it needs to!
BFHtime
I have good experience with 3M duct tape. I have tried many recently that just do not stick and tear easily. Duct tape used to be great, just about any brand.
I have not tried gorilla tape but I have tried a variety of their glues.
mrjaw14
Nashville, TN
Nashua is a brand of duct tape. They have several different types. I've used it and it's high quality stuff, but I don't know where to get it locally. I had to order mine. Locally, gorilla tape is the best if you need a thick, durable, high-adhesion tape where you want "duct tape" but need something better. It's 10-12mils thick so it doesn't tear quickly like duct tape, which means it doesn't puncture as easy.
FWIW, I do keep several feet of gorilla tape on an old credit card type of plastic in my bag when kayaking and camping for gear repairs. I wouldn't trust regular duct tape for that...
Strouty
Southern Maine
I use the clear duct tape that I think is made by 3M, it is awesome. I was remaking an upholstered door panel for an excavator and I could not hold the material tight because of the odd shape, I ended up using the clear duct tape on three sides to hold it tight while the adhesive dried. it worked very well and I have used it ever since.
I actually have not used gorilla tape, but I will be getting some.
stage20
pcola FL
Ivve never used the gorilla stuff, but napa brand duct tape is pretty sticky. Is next to my work so its more convenient than going to lowes or hd
Monte
Germany
Anyone know the source of the 300 mph tape Nascar teams use for body panel repairs?
jakemac
New England
smiffy
If you have a proper farm supply store near you try silage tape its very stretchy almost like rubber and annoyingly sticky its used to seal tears in silage bales so is made to last we use it for everything even got it holding together a truck exhaust pipe and its been there for several months and because its stretchy it màkes it easier to get a good seal with
bwringer
Indianapolis
Hey, has anyone mentioned Gorilla Tape yet? :lol_hitti
I'm sure there are specialty tapes that are stickier and stronger, but they're not sitting on the shelf of every Wally World, home store, or hardware store.
bobemmerich
Middletown, Ct.
I will go with the Gorilla. I put it on my convertible top a couple years ago, and it hasn't pulled out yet. It also still hasn't leaked.
warweapon762
Another vote here for gorilla tape, I've shipped a box with two cylinder heads in it wrapped in that stuff and it held up GREAT.
I've also used a style that had braided wire mesh in it (stainless maybe?) that I got from one of my HVAC buddies in the early 1990s and that was the most durable tape I've ever used. But I couldn't tell you who made it or what it was used for and have been unsuccessful finding any of it since then.
