Fire Blocking Question
Tim Fitzgerald
Anacoco, La
I am building an office within my shop (stand alone building)..., it just dawned on me that I may have to place 2x4 fire blocks within the framing of the walls...?, Im leaning towards no and hopefully I am correct as I am almost 3/4 through rough wiring:eyecrazy:
CNGsaves
KS and OK
Too little information. How tall are walls?? What materials are used (studs, wall covering, outer walls, etc)?? What kind of wiring used??
never enuf time
North of the Motorcity
How tall are your walls ? Every 8' is the rule. If you have already wired , you can cut a v into the end of a 2x & use firecaulk (I dont know what they really call it) in the void.
T
Tim Fitzgerald
Anacoco, La
The walls are 8Ft tall, 2x4 studs, romex 12/2 wire. Inside walls and outside(to my shop wall) will be covered in 1/2 sheetrock. dimensions are 14Wx30L within my 30x50 shop...
K'ledgeBldr
Johns Creek, GA
No fire blocking is required-
However, you definitely need to add some T-Bracing. The drywall alone isn't a good shear brace.
JimD1
I have an old ballon framed house where the studs do not stop when you go from the first to second story. It has fire blocking - and needs it. Normal construction with 8 foot ceiling height doesn't get it. I don't think I had it in the last house with 9 foot ceilings either. That would probably be a local code thing.
Cyberbear
California
As I remember from my Building Practices class in college, fire blocking is used to stop the chimney effect of a fire when it's burning inside a wall, preventing or slowing the fire until help can arrive. They used to figure a 2 x 4 would take about an hour to burn through, giving the fire dept. time to do their job. In my area blocking was generally only required for exterior walls. Your stand alone office may not need to go this far, but it never hurts, as you are the one to benefit, and it would be a shame to lose a building over the cost of a 2 x 4 and some labor.
CNGsaves
KS and OK
You may WANT to do some blocking, even if not required if you want some "meat" to attach stuff like benches, shelves, etc.
Take pictures and take notes of where you add them so you'll have gameplan once shop gets put together.
