Fire alarm in a separate building...
Notgrownup
Snow Hill NC
What are reasonably priced suggestions to get a fire signal from my new shop to my house?
I will be running conduit for power so I will have a trench dug ....just trying to see if can run some extra cables fir this signal.
n8n
Curtis Bay, MD
What are you using for detection and reporting? I've got a couple ideas but what will work depends on what you already have/are planning on using. Also, is this voluntary or are you required by code to install detection?
Probably should PM me if you get too serious about this as I'm about to accept a job in the field and don't want to be giving advice on a public forum. And of course we never had this conversation.
Norcal
Fire alarms are the domain of security/fire alarm contractors, not a DIY project.
Showkey
"MEMBER EMERITUS"
Wausau WI
These guys claim a 400 ft wireless range. Friends and my daughter use their service as an alternative to alarm service companies. It is DIY kit........they seem to be happy and confident in the system.
Having a full service alarm company is NOT a guarantee of a trouble free system........just my experience both at home and work........high cost, false alarms and poor service are common in the industry.
http://simplisafe.com/home-security-system-master
N
Notgrownup
Snow Hill NC
I just want a fire/ smoke alarm that I can hear in my house 75 feet away...I have electric with battery backup Kidde brand smoke alarm in the house, just the ones from Lowes... Not required by code but it will be a workshop with wood working.....
Stuart in MN
Minneapolis
If you already have a security system in your house it's pretty simple to add another input from the garage. Typically, rate-of-rise temp sensors are used in a garage instead of smoke detectors, which can be fooled by car exhaust, or dust from working on projects out there. The rate-of-rise temp sensors have a simple set of switch contacts that close if a fire is detected, so even if you don't have a security system in the house it should be easy enough to use the switch contacts to light an alarm light or sound a buzzer or something similar.
If u have smoke detectors with the third/signal wire, then u could run a wire in a separate conduit in the trench that ties the house alarm to the shop alarm..
amolaver
Thinking a little outside the box.. what about a baby monitor? My wireless one covers 200' and through my metal building from the far side of the house. Put the 'baby' side in the building and the monitor in the house..
ahm
I will look into this....
The interconnect wire is usually orange or red...
Are the smoke alarms that u currently have interconnected or just AC powered?
Hpozzuoli
Rhode Island
I just had to hard wire and "interconnect" all my smoke/carbon detectors so I could sell my home. Very easy to do.
Having a system that reports and is monitored is another beast. My laundromats are tied to the buildings and central monitoring. Only fire alarm electricians are supposed to touch them.
plow
Louisiana
Not in my area. We (I) take pride in the work that I install, service and inspect. Been doing Fire Protection for 22 years. I haven't lasted this long by installing ****, lying and cheating customers. You get what you pay for. If you're a cheap sob and don't give a **** about anything but a "pass", stay with your current company.
False alarms are more than likely due to ****** installation and or equipment. Again, you get what you pay for. I followed the link you posted and the equipment appears to be trash. In the Life Safety business, We have minimum standards that the manufacturer has to comply with.....An Good House Keeping aint one of them.
Do me and my industry a favor an educate yourself before you offer up that **** equipment and then blame people like me, or the rest of the industry that your DIY **** doesn't work.:thumbup:
plow
Louisiana
I dont know how long a smoke detector would last in a woodworking shop. My smokes get a little dusty and they start going off.
Smokes in a "wood working" shop are improper application of that device. Heat detectors should be used.
Beemer533
Syracuse, NY
You could look at something like the Nest alarms; as long as you have wireless network connection from you home network in your shop you are good to go..
Just install one in the shop and one in the house... Or even just one in the shop will alert you on your phone...
They aren't cheap, but I have a couple friends that use them with no issues. If you get the hardwired one they even have a night light option...
lakeroadster
Central Colorado
Good advice based on my experiences. Smokes in any shop are pretty much useless. Dust particles and spiders / insects can set off false alarms.... and it always seems to happen when you are on vacation.
Go with heat detectors.
If at all possible go with a hard wired system, not wireless. When I built my shop I ran some extra telephone cable along with the wiring for power. My alarm folks used one of the telephone cables for the alarms.
plow
Louisiana
Showkey, I would like to apologize for coming off as harsh. Bad day on my part.
N
Notgrownup
Snow Hill NC
Met with an alarm guy yesterday and the monitoring isn't bad but the installation is crazy....he is going to give me a quote today but said it would be in the neighbourhood of 1500 bux...bit steep .."..I have good insurance for now....
n8n
Curtis Bay, MD
If you know people in the business you could just get the most basic of basic systems installed & then add detection, door contacts, glass breaks, motions, etc. Yourself...
Sent from my XT897 using Tapatalk
Install it yourself!!
