snowman1981
http://www.autozone.com/tools-boxes...reen-crossover-storage-tool-combo/547961_0_0/
save $500 comes in red,black,neon green
How many wrenches fit on each peg? Will a soft or hard handle ratchet fit in the holes?
I assume that caster rating of 550 lb is each caster?? Seems like they would provide a max load rating for the box.
I've got 2 wrenches on each peg...1 normal and 1 ratcheting...I don't know if you could fit 3, but 2 isn't too bad.
The holes won't fit my HF composite wratchet. Handle is too fat. Normal hard-handled ones fit fine. Holes for ratchets are probably about the size of a half-dollar.
So what is the Stainless steel work-surface that is described in the description in the auto zone ad? The bottom chest does have 6 drawers right?
The top "drawer" handle on the bottom unit is actually a work-surface. I use it a lot honestly. As long as I don't have to get into the top 2 drawers or so, I pull it out and use it to lay the sockets and such I'm using on it. It locks out and in so it won't move around.
Regarding the ratchets fitting into those holes...There's a lot of storage space underneath the holes too. You could very easily put a little bin or something in there to put them in. I got a bunch of bins from Schaller Corp that fit into even the smaller drawers perfectly and let me organize a TON of stuff in the drawers. I basically have all my sockets in the top, either on the pegs (6-point) or in some Hansen trays underneath the socket pegs (12 point and some large sockets). I then have ALL my extensions, ratchets, and screwdrivers in the holes, with a few little bins under the holes section for my composite ratchet and a few other larger items.
The bottom cabinet I have looks a little different. I've got the larger bottom drawer, a medium sized 2nd from bottom drawer, and then the top drawers are all smaller/slimmer. The pictures in the links have a larger top drawer than I have. My bottom cabinet looks like THIS. Not sure how it's different other than the layout.
Is it only a work surface or does it have storage under the stainless panel?
Someone who has this set up please tell me about the lid.
Does it fold over all the way on the back of the top chest?
thanks in advance, a picture would help.
I've done some research the last couple of days on this? I think the older version of this had the shelf which now has been discontinued.. I think the ad is wrong. I believe it will ship with only 6 drawers and no shelf. Which for me is not a deal breaker it just makes the top drawer deeper..
I hope someone on here has bought one of these and can confirm this. I really think this box and the way in which it is set up ( 25070 total cubic inches of space) is great..
I feel this will be a upgrade for me, my current box is a HF 44 top and bottom, side box and locker. Which is as long as semi and way to big for my garage.
No stainless work top on this. Mine showed up yesterday. And to the question about the shade of green. It nearly matches my snap on green cart. other than this combo has a texture to it (similar to old white fridges).
Ill get some pictures tomorrow afternoon (some assembly req'd). I will say, I was impressed with how mine was shipped. it was on its own pallet and delivered to my garage by a RL carriers with a lift gate truck. No damage what so ever.Sweet. Any pictures of your new box?
Well the code right this minute will work but ONLY for the green box. Turns out, after a lengthy email back & forth with the customer service, there was a mistake made. NONE of the promotions were suspose to work with this sale. It blows that I may have been the catalyst to screw all this up. I was able to log back on and secure a green box with the discount. The service rep said it was a mistake and would be corrected asap. My advice if you're on the fence, buy a green one now & get 20% off or be prepared to buy without the discount.
I need a bit of color in the garage anyway!
