realjimjim
Anyone know an easy way to determine if a torque wrench needs to be calibrated?
Thanks!
Thanks!
Lock the drive end in a vice and hang a known weight off the handle, measure the distance from the center of the drive to where the weight is hung and do the math.
Interesting, and yet 5 other guys said it was spot on when tested with accurate certified instruments.
Maybe your test procedure was flawed.
Why? You can, but regular ratchets are way shorter than torque wrenches and would be difficult to put any sizable torque on it.So for you guys using this as a torque wrench checker, why not use it to torque stuff and use your regular ratchets?
