lucky.expert
Well I finally have a decent project worthy of it's own thread, so here it is. I thought this might be a project that some on here might be interested in, and I figure I could use some of the good ideas I'm sure will follow. I've been following Don Campbells thread and was inspired by all the machines he made with a riding mower. I've been fascinated with the idea of making something that can pick up heavy stuff so I don't have to, and a forklift sounds like the easiest and cheapest option. Once I'm done, and if it works, you can probably find my at my house just picking stuff up and moving it around for no reason - just because I can.
The plan is flip the direction the mower drives, so the big back wheels are now the front wheels. I will build a mast that will be about 7ft tall, and possibly make an extension of a couple more feet in case i need more lift height. The lifting will be handled by a winch with a mechanical brake. My goal is to lift 500lbs. I don't have anything that needs moved that weighs that much, but it would be cool if it could.
This homemade forklift thread is where I am getting a lot of my ideas, since i know they should work.
I found a craftsman on craigslist with a 20HP B&S that had been sitting a while, but after cleaning up the carb and a new battery, it fired right up. It seems to be fairly heavy duty which is what I was hoping for.
The hardest part will be moving the steering, brakes/clutch, and the transmission shifter. I will eventually reverse the rotation direction of the belt that powers the transmission, so I don't have 1 speed forward and 6 speeds reverse, but that can come later after I get everything else working.
Now that I got the intro out of the way, pics will follow later of the progress so far.
($80). It is definitely heavier duty than the average go cart clutch though.
