floor jack
KCHOTBOAT
Olathe, KS
Anyone have a low profile floor jack they would recomend? The new car sits to low for my old jack. Heard nothing about bad things about the HF ones. Does anyone own the one sams club sells?
bmwpower
How low is low? How far of a reach?
I have an AC Hydraulics jack which is pretty low.
Uncle Buck
Kansas
I am not generally a HF fan. However, I have never had a problem with any of their jacks. I have recently seen their 3 1/2 T jack on sale for $59.00 and would like to get one. I look at the castor size, size of the carriage and most important, the dia of the lift saddle. I do not like floor jacks having small dia lift saddles. I know it's just me but I have yet to see or use a decent quality jack that has a small diameter lift saddle (sears jacks, all small saddles). Although I am talking about HF (ANYTHING) jacks, I still want the larger lift saddle even on a chi-com jack. I saw a new Lincoln jack at my friends house a week ago and the damn thing was made in Chiney! Of the standard frame jacks available from HF the 3 1/2 T job looks like the best of the lot. Going by appearance, it also most closely replicates better quality jacks. A few things to keep in mind about a HF quality jack (or any brand of jack). 1) If you use the jack strictly for raising the vehicle,then resting it on jack stands (as you should) instead of relying on the jack alone and working under a vehicle with no jack stands, you should have no problems with even a cheap HF jack. 2) It has been my experience that when a jack starts going south, they will generally leak, or not raise, nor hold for very long the intended load. Anyway, at some point all of them shoot craps and you are left with rebuilding/replacing them. I have never had a new jack, every single one of mine was not functioning when I got it. Better quality jacks like the old Walkers (now Lincoln chi-com) and the old Blackhawks or Hein Warners have been a true pleasure to rebuild, I would simply get the proper rebuild kit (usually 20-40 bucks) install, and walla, no leaks and the jack will lift and hold the load for years to come. Most recently I rebuilt what I believe is an old HF 3 1/2 T since I had no numbers or original info to go by I went to the plumbing dept of the local true value and got a handfull of o rings, packings etc.. and rebuilt the jack. The jack now lifts and holds the load and does not leak, so I will get more use out of it ( keep in mind, I never crawl under any vehicle without jack stands in place). Anyway, if HF and Lincoln both get their jacks from china I do not see where a better paint job and a cost difference in excess of $100.00 makes the Lincoln more worthy of my consideration for purchase. I like the Lincoln jack better, I just cannot afford the difference when the HF will do the job just as well at considerably less cost. :cool:
Tim240Z
LAX area, So Cal
I bought one of those aluminum 'race' jacks from HF a couple of years ago on sale for about 60 bucks. I needed it to get my car high enough for the 'real' jack. I use the aluminum one very often, esp. when going to help a buddy or neighbor and don't feel like lugging the big one around. The cheapo HF jack has worked flawlessly and I have had zero issues with it (apart from the initial oil fill and bleed...took a bit of time to get it bled properly). For the price, it works great. I wouldn't use it as a primary jack, only because I don't trust something that cheap, but it does get the job done.
Tim
eschoendorff
I have and use the HF aluminum jack and have not had any problems with it. It's actully a rather nice jack.
Geeforce
boston
I bought a blue low profile Arco (?) jack from costco for $60. I got it because its heavy duty and will fit under my Integra which has been lowered. I think the jack range is from 3 1/2" to 21" . So far no complaints except that it was really heavy putting it in the trunk to go home!
K
KCHOTBOAT
Olathe, KS
Thanks for all the info guys. My 20 year old jack is to tall for the wifes vette and to small for the dually so looks like I need to get a low one for now since I can still slid my fat rear under the truck.
ultgar
New Jersey
Great jack........unfortunately as I found out today, Stertil-Koni will no longer be importing AC Hydraulic products to the US. Not sure if this is another victim of Chinese competition or just apathy on the part of the current importer. SD
krooser
Waupaca, Wisconsin
How about Canada? I was thinking about buying one...
homer
texas
nooooo i NEED that jack and have been saving for one. PLEASE dear god let there be a way to still get them.
REFLEXX
Riverside, CA
Just saw at costco, a nice all alum "lo-profile" jack. Like 4" to 20" range, but don't quote me.
Probably made in China, but you gotta love Costco's lifetime return policy!
K
KCHOTBOAT
Olathe, KS
I ended up picking up the HF one for now and see how it holds up. I ended up with a coupon in my email and they had a net special so ended up spending alittle over $60.00 on it.
ultgar
New Jersey
And if you do find one, what will you do for service and parts?
iiibdsiil
Tampa, FL
For $60 you throw the thing away in 5 years when it breaks. I'm sure between now and then Harbor Freight will come up with a new supplier.
mikeyr
Santa Barbara, CA
He would then be in the same boat as those of us who already have one of these incredible worth every penny they cost jacks when it comes time to service them.
I used to be one of those buy cheap and throw it away when it breaks kind of guy, after buying my AC jack more on impulse then anything else, I have thrown away the other jack and only use my AC jack. Sometimes a quality tool is a pleasure to use, even if it does the exact same work as a cheap tool.
ok, I didn't really throw away the cheap jack, I threw it in the back of the truck for when I get a flat or like that, that was 2 years ago and no one has stolen the jack yet, they must think it does not work :)
On to more serious things....I have to find 2 AC jack stands to match my other 2 now that I know they are going away.
tomroblee
Indiapolis, IN
I have two Sam's club jacks. The first is about ten years old with no problems. Bought the second one this past summer for farm.
The handle in the new one doesn't seem to want to stay attached while pulling the jack (moving around the garage). It also seem so require more effort to lift heavy items.
I was really impressed with the medium priced jacks I later saw at an Indianapolis IN "chinese" equipment dealer --but don't need another one at this time.
http://www.gregsmithequipment.com
homer
texas
the ac jacks can still be purchased in europe if i understand correctly. . all the rally teams i see when my freinds and i race use them and i have been saving to get one for myself. if the parts are available overseas or in canada i can have someone get them for me with little hassle, plus for the quality and usefulness of the jack i would be willing to pay for high shipping.
bmwpower
What?! What do we do for warranty repairs and/or parts? I bought my jack from you....
And I was just about ready to buy a set of stands AND a crane. This stinks.
ultgar
New Jersey
I'd like the names of people on this list who purchased jacks from me .....please email me directly at [email protected] . I need your full names.
Stertil-Koni faxed me a list of new spare parts they have in stock. I'll probably take a trip down to MD to see if they have a bunch of scatch and dent jacks I can buy for spares.
Also, if anyone on this list has a DK20/DK20Q or DK13HLQ jack they bought from me in the last 6 months (thats not all beat up....I don't care about the wheels), I'll buy it back. This offer expires 2/15/06. SD
