bigorangecntry07
My Shop/Apartment Build in Tennessee updated!
it started life as a 36'x36' shop and we had someone come in a take it down.
site prep wasnt done correctly so ill be fixing that come christmas.
rough in plumbing
new slab done
and most of the building delievered.
lip in the slab for a moisture barrier
the shop/apartment will be rustic red with white trim
Building up!!
electric is almost ready to be completely hooked up.
power company came on friday and set in our new pole and ran the power lines. they came with five trucks. one with the normal augar for digging, another with a rock drill bit that cost over 100k for just the bit and it required a air compressor that was mounted to another truck that was huge... cool stuff though
roofs done
trim and gutters are starting to go on.... should be done in a few days.
garage door opening is cut and the side door installed.
front
inside
rough in plumbing
new slab done
Building up!!
roofs done
front
inside
its in middle tennessee..... the shop is 40'x80' total. it will have a 24'x40' apartment inside and since im an architecture student i designed the floor plan for the apartment and my dad and i will be building it in march during my spring break. it is huge..... just the way we wanted it.
right on maggart road you cant miss it we have the nicest bridge on the road
anyway my parents just spent a week up there in may, (i know
) and got the front windows installed and my dad finally got to get some grading done. he also got a mini track hoe and burried some of that black drain age pipe with the sock over it around the buildin. apparently they had a pretty bad flash flood a few weeks ago and we had some water inside the building, but the ground was finally dry enough to work with. so heres some pics.....
