Process Fabricator/Welder's Portable Toolbox
dr_clyde
Holland, MI
Hey guys, just cleaned out my portable toolbox, thought you might be interested.
This is the box I toss into the truck when I am working away from my shop. I might be in the plant fixing something, welding at another shop, working on my mom's car, whatever. It is mostly comprised of spares from my main box but there's a fairly complete set of basic tools in there. If I know in advance what I'm going to be doing, I'll kit up a bag with more specific tools.
What's in it? Well I spread it out on the surface plate and made a list.
Box is a Snap-On UT22K
Knipex mini bolt cutters
Pliers wrench
Channellock slip joint pliers
Channellock 420 tongue and groove pliers
Channellock 430 tongue and groove pliers
Channellock 360 mig pliers
Mac needle nose pliers
Klein diagonals
2x 10wr Peterson vise grips
Williams 1/4"-3/4" deep 3/8" drive impact sockets
Williams 10-19 MM deep 3/8" drive impact sockets
1/4"-7/8" shallow cman 3/8" drive chrome sockets
3/16" -9/6" cman 1/4" drive deep 6pt chrome sockets
T15, 20, 25 cman 1/4" drive torx sockets
3/16"- 9/16" cman 12 pt shallow chrome sockets
SO 1/8"-3/8" hex sockets, ******* homemade 1/2" hex socket
T30, 40, 45 50 cman sockets
SO F731 flex head ratchet
SO F936 standard ratchet
SO T72 ratchet
Unbranded 6" 3/8" extension
Cman 3" extension 3/8"
BP 1,3,4 inch extensions 1/4"
BP universal
BP spinner handle
Eklind standard and metric Allen folders
SO yellow instinct screwdriver set including minis
SO red short pick set
Mac 1/2"-3/8" adapter
9-17 MM metric cman RP wrenches
Vaco 8" adjustable
Cman 10" adjustable
Cman 3/8"-3/4 " RP wrenches
SK 7/8 superchrome wrench
SO 1-1/8 wrench
WF USA crescent 15" adjustable.
Stanley torpedo level
Ridgid 18 aluminum pipe wrench
2x jbauer 123 blocks
Mac compothane deadblow/brass hammer
Mac 16 oz ball peen
8" Nicholson half round smooth file with handle
Empire 7" speed square aluminum
Food grade anti-seize
Cman striking scraper
SO striking prybar set minus longest one black handle
Old as balls hacksaw
Astro pneumatic die grinders straight and 90 deg
various attachments for the die grinders
Stanley 25' and 12' tapes
M.F. Co Combination square
Dasco 5/8 cold chisel
Dasco center punch
Tekton 1/8 starter punch
Blue point 1-1/4 mirror
Cheap led flashlight
Stanley utility knife
Argon to air fitting purge adapter
Techsouth 1-1/2 cut block
Wire and buna-n gasket for 1-1/2 triclamp
General carbide scriber
Spare grinder nut
Anchor stainless wire brushes
Die grinder wrenches
Assorted zip ties
Kershaw taskmaster scissors
JimDon
Holy ****! Nice set up. I like to see tools that actually look like they've seen service. But what the heck, I bet that thing when loaded could pull your arms out of their sockets -- so how heavy is that beast?
Cheers,
JimDon
D
dr_clyde
Holland, MI
Cheers,
JimDon
I don't have a scale at the shop, but it is very heavy. I usually use a dolly to move it long distances around the plant.
Cope
Houston, TX
Looking at the tools outside of the box it would appear you could never find anything, but seeing them inside it looks easy enough to get at anything.
D
dr_clyde
Holland, MI
Its not so bad for the side wings, the bottom of the main area can get a little cluttered, especially if you're looking for something at the bottom.
Lx460
Central Florida, USA
I assume since its a ut22 with the k suffix it's COO is China. How is the quality on the box? Can you tell it's an import?
D
dr_clyde
Holland, MI
The box is exceptional quality. I bought this one because the service mechanics at the local scrapyard use these on their service trucks and they hold up. Those guys could break a bowling ball with a feather.
I considered Facom, Hazet, and this box. I decided on this box because I could get it through my dealer cheap and it had a reputation of being durable.
ncfh
There is as flange bent into both sides of the lid with a hole in each to padlock them together.
You can see the holes in the OP's second picture, near the open handles, just above the warning stickers.
D
dr_clyde
Holland, MI
It does have a padlock hole, although any thief with some intelligence will just steal the whole box and deal with the padlock later.
TEXACMAN
Mount Pleasant Texas
That is a nice setup for sure ! I can never find a toolbox that doesn't end up a cluttered mess, looks like the trays are just the right depth.
Farmall 1066
Suburban Rockford, NE
Nice setup. I use a UT22 also. Had mine about 20 years and going strong. Amazing what they'll hold. Mines constantly stuffed to the gills, but stuff is fairly accessible.
