I have a Dewalt pressure washer with a General Pump Model TX1510A series 63 triplex pump. It has a very slight leak from the manifold when operating, so I took it apart to check the packing seals and plungers. The leftmost ceramic plunger is clearly cracked, the center one shows a slight discoloration I need to inspect more closely when I get it pulled off. My problem is, they seem to be stuck in there really tight. I've checked scores of youtube videos on this and the plungers always come out with ease for the demonstrators, but not in my case. Does anyone have any suggestions? I don't want to damage good plungers pulling them off since they are rather expensive to replace at about $60 each. See attached pics. If there were a proper sized collet available for my slide hammer, that's one idea. Alas, no such collet exists in my puller set. Maybe I can make a wooden bushing and clamp it to the plunger. One thing I noticed that is different from the General Pumps I saw on youtube is that the plungers were secured with a cap bolt on the end whereas mine has a bolt with a nut on the end.
