nh_yota
I recently acquired an air compressor from a local guy on Craigslist for a good price. It's a 12 gallon 2 hp horizontal DeVilbiss Pro Air II belt drive oil lubricated unit that was manufactured in 1989 according to the data plate on the tank. DeVilbisss manufactured compressors for Sears back in the day so it's almost identical to the 12 gallon 2 hp Craftsman compressors of the same vintage. It's not top-of-the line but it was made back in the days when you could get decent homeowner grade products still made in the USA.
I picked up the compressor because I need one for my small house and I don't have the money to spend $500+ right now on a quality compressor that's not made in China. I'll probably use the thing a dozen times a year to air up tires and nail up some trim. I bought my father a new Ingersoll Rand compressor years ago and I go to his house whenever I need to work on my truck, so this one will only be used for small projects here at my house.
Anyway, the DeVilbiss compressor I picked up is in good shape for its age and runs just fine. The motor, compressor, pressure switch, pressure gauge, safety valve and regulator all work just fine. The compressor seems to have been taken care of and shows a reasonable amount of wear and tear for its age. There's few if any real rust spots on the tank, and when I tapped it with a ball peen hammer it sounds okay, although I'm no expert.
The question is - can I trust the integrity of the tank? I've heard of rare instances of old air tanks exploding due to corrosion, but I heard that most tanks will start to leak when they rust out. This tank appears to be in decent shape for being 26 years old.
