MechanicNamedJohn
- Joined
- Jun 3, 2010
- Messages
- 1,344
- Location
- Tampa Bay
- Price
- Varies
Garage Journal thread on pressure transducer waveforms...
http://www.garagejournal.com/forum/showthread.php?p=4777004&posted=1#post4777004
Want to turn minutes of diagnostics into billable hours?
These transducer kits will aid any oscilloscope into becoming the ultimate diagnostic machine; works with all scopes, even Snap On Verus, and Vantage.
The power supply/signal output boxes are constructed of anodized aluminum with CNC machined front plates. They also feature rubber shock mounts. Each box can support the use of two transducers simultaneously.
Each box is internally fused and serviceable. Signal outputs are standard shielded banana connections. Transducer cables utilize a USB style connection. The boxes are powered by the vehicles battery/auxiliary power source; power leads are supplied and use either Power Probe power connection extensions or and "banana" style clips.
Each transducer is made of 316 stainless steel, and is safe to use with fuel, oil, transmission and types of fluid, Freon and high temperatures.
Basic Kit: $800.00
1 Power Supply/Output Box
1 300 PSI Transducer
1 -14.5/30 PSI Vacuum Transducer
2 10ft Transducer Cables
1 Power Supply Lead
Master Kit: $1400.00
2 Power Supply/Output Box
1 500 PSI Transducer
1 100 PSI Transducer
4 10ft Transducer Cables
2 Power Supply Lead
Each kit comes with a 2 year warranty.
I will be starting a specific YouTube channel related to Automotive Diagnostics and the use of these transducer kits.
Basic Kit: $800.00
1 Power Supply Lead
2 Power Supply Lead
