http://www.therpf.com/showthread.php?t=88027&highlight=Proton+pack+pep+fileAwesome! I've wanted to get into making a few props for myself, mainly a proton pack from Ghostbusters to take for Halloween and hang up in my cave for a conversation piece, but sheesh I can get too deep into details...... So I have put that on my back burner lol!
Far too rich for my blood $25000. At least...GMMurdoch, please keep posting about your amour project. This is definitely on the fringe of what is typically talked about on here but totally badass and interesting.
There are 3D metal printing machines, but have no clue to how much $ and accessible they are?
It may be that you have to do a combo of machining the more intricate pieces and then perhaps learn to bend and braze larger less complex pieces?
Awesome.
A gift for you my friend. Pepakura files for your own Ghostbusters proton pack. You will need to download software from Tamas oft to print it. Good luck...GM
I was wondering if you were an rpf guy. Interesting stuff. Not your typical GJ conversation but interesting nonetheless.
Sweet work. Please keep it coming as you are working the tip of spear. I used to ride that tip but now older, I'm more like the dull edge on the back of the blade!
Keep up the work and please keeps us informed.
I am a hard chrome electroplater and the pics are some of the equipment that we have. Now I know that this equipment cannot be used for aluminum with exception to the polisher. But I cannot make the whole armour of aluminum, so I'll need to use steel for some joints for movement and I plan to replicate an M134 gatling gun that needs to be functional. Absolutely in no way real, just a prop...GMIf you're going to weld aluminum I think you'll need either an AC/DC TIG welder or a MIG welder with a spool gun. I don't know of any other ways to weld it. Are you a machinist? What do you plan on using the grinders for?
Hey thanks for the tip man. I'm going to try my hand at Mig to see where I can go with it and see where my skill level is at...GMIf you're going to weld aluminum I think you'll need either an AC/DC TIG welder or a MIG welder with a spool gun. I don't know of any other ways to weld it. Are you a machinist? What do you plan on using the grinders for?
Hi guy's just wanted some info on aluminum welding vs brazing. Now in the 4th post of this thread I have a pic of my first attempt at brazing, using an aluminum brazing rod. Now I have tried to pull it apart by hand and I have had a lot of my friends try and it holds just fine. Now in the opinions of the masters here, is this strong enough for my project or do you think I need incorporate some aluminum welding also. I think the brazing will hold just fine with the exception of the boots due to the constant pressure placed on them. Any thoughts, let me know and thanx in advance...GM
You may find it a little easier to maintain the cosmetic features of the material when using TIG. Definitely takes a little more time to become competent but eventually TIG welds require less cleanup and grinding and easier to do the really fine work required for costuming. I have both arc , MIG and TIG and rarely use anything but TIG when making props and costume pieces for people. The only time I had a request to make anything similar to an arc weld bead was on a plastic costume piece and ended up using a silicone mold of a weld in my workshop and transferring it to hot glue to get the look.
If you plan to do a lot of aluminium sheet metal shaping you will need an oxy acetylene set with a rosebud torch to anneal the material. Makes it softer and less prone to cracking. Also consider a pneumatic plannishing hammer and jeny/swage for getting deep bowl shapes and crisp edges or creases. English wheel is nice for large smooth contours but in the end what you are making is like body armor to a degree. For the material you'll be using most you will likely benefit from owning a beverly shear too. A lot of the rough shaping and stretching can also be done with a teardrop HDPE mallet and a sand or shot bag.
Then watch as much Ron Covell and Lazze metalshaping youtube videos you can. There are plenty more but those will get you started. Also ton of medieval armor tutorials to teach you some of the techniques.
That's quite a bit to take in. What would you recommend as far as the grade of aluminum to use for mig welding. To be honest I thought all aluminum was weldable. I was thinking about brazing a lot but with main support pieces that I would weld. I would use some steel, but just for fastenings and other pieces. Your input would be appreciated though. This is why started the thread, research. I value any input from all of you folks and again thanks...GMSome thoughts in semi-random order...
re: welding aluminum
First off, some but not all aluminum alloys are weldable.
Some aluminum alloys are considered non-weldable (via arc welding process, such as SMAW, GMAW aka MIG, GTAW aka TIG).
Much more so than with steel alloys, you have to know exactly what aluminum alloy you are working with.
Both for the possible welding as well as the bending and forming steps.
Some aluminum alloys can be bent/formed relatively easily, others can be annealed to improve their formability, and others are not really formable.
re: brazing aluminum
Brazing can sometimes be used successfully with aluminum alloys. But successful manual brazing is usually a bit more fussy or finicky or flat-out difficult because the melting point of aluminum alloys and the brazing filler are sometimes not that far apart.
As well as the 'fussy' aspect that there is not visual indication that the part being heated is getting 'hot' like there is when heating steel to 'red hot'. Aluminum pretty much just sits there looking the same to your eye as you heat it and then if you apply just a little too much heat, it just melts.
re: strength
The needed 'strength' of your prop depends a lot on just how much bumping or bashing or jostling the prop may get.
For some parts of your prop, plastics as the material and some sort of adhesive may be plenty 'strong'.
Other parts may be just fine with brazed aluminum.
For other parts, you may need welded steel.
If the parts only have to withstand pretty much some pulling them apart by hand (or the equivalent), then your brazed aluminum joints should be fine (based on you and some friends trying to pull those brazed joints apart by hand).
Cool project though.![]()
Yeah but what is it for? If you don't mind me asking...GMMurdoch ,
This is some really neat stuff !
Good luck with jumping into to the metal working aspect with you project.
Now I've got to pick your brain.
Any resins available that are clear and will dry hard enough that they can be sanded and then buffed to take a high shine ?????
In the mean time keep showing your work !
Those are really cool...GMMosaic pins. They go through knife handles to dress them up.
Pull resin through the tube and let it harden.
So pieces get cut off and are then put through the handles in the rough and then that whole assembly is contoured by sanding and then given a final polish on the buffing wheel.
So , It needs to get hard enough to take a true polish without smearing.
Also on occasion the resin gets dyed.
Thanks for the input !
Thanks Guster for the info. Are you a prop builder and can you send me a link for me to check out? GM
It is a good summary of its weldability though basic and doesn't provide much information on what is required to 'work' the material afterwards. While TIG and gas welding/brazing reduces the effect of the heat affected zone, many structural aluminium alloys form a semi crystalline region in the HAZ which is hard and brittle. Softer alloys like the 3xxx and 4xxx range to a lesser extent hence why they are so common. They often require post heat treatment to normalise or anneal it for working with it. Some also work harden and age harden, hence good to anneal it when doing any shaping.
For costuming the 3xxx range is readily available and more than sufficient. It is good to get in the habit of annealing any work or age hardening materials before bending or shaping. They are so much easier to work with and saves time having to remake or weld a part that cracked.
One tool I forgot to add was a shrinking/stretching tool. Mostly the shrinking tool. You can substitute using the tucking method though you really need an oxy acetylene set to make it easier to work. The shrinking tool also leaves less waste on the edges to clean and is more of a consistent/controlled process compared to tucking. Alternative would be to remove material in slits and weld it shut which is usually the only option in thicker material anyway.
