If they made this wrench, would you use it?
KnurledNut
n/a
With the popularity of flex ratcheting wrenches, why not make a flex non-ratcheting combination?
I have saltus-type wrenches, but i find the box end is often too big.
A fixed design would have higher strength and a thinner ring to get on bolts where a ratcheting-type wouldnt fit.
Opinions?
I had a little fun with Photoshop:
:beer:
.jpg
Kracin
Omaha, NE
spin_prod_222289401
K
KnurledNut
n/a
I am aware of those.
But its not the same. I think we all know why. Flare vs. regular. 6 vs 12.
Kracin
Omaha, NE
not the same but its one of those things. if it was necessary it would have probably been made by now, it seems anything that requires a wrench to get on where you can put a box end, you can usually get a socket. otherwise its the open end.
i'm sure theres a few special cases where you would need super tight clearance, but dont think anyone is going to devote the time and money to another niche tool.
SASORacing
Utah
i have never broken a ratcheting reversible or non reversible wrench. I hardly even use fixed / normal wrenches now. Ratcheting saves so much time.
Bigblue&Goldie
No interest. The current breed of ratcheting wrenches are so strong, I don't see the point.
Mohawk Dave
SoCal
I want regular length that has flex box and flex ratcheting, same size on each end. Spline while we're at it.
Can't remember the last time I NEEDED an open end.
  • Like
Reactions: LSU
Gmonkee
I have offset flex line wrenches that are used for what you describe. Not the same tool you desire however. Not a frequent use tool but when required a time and 4 letter word saver.
Time to maybe contact a machinst friend and see if you can make a set of them. Make a good test drive of them on the job to see if the idea holds up in use.
devoncoolman
quakertown pa
Id probably buy them. Its one of those tools that would rarily get used but when it saves you an hour or two not having to remove something else its a money saver. Im a flat rate tech so ive got tons of tools that save me time where as the hourly guys i work with don't buy squat.
I just don't think that market for them would be huge probably why in the last 100 years nobody has made them. I have the flex line wrenches they are a big help when the need arises but its not very often.
Jeremy77
Coastal Alabama
In industrial work, the box end of a ratcheting wrench is almost always too big to work when bolting a smallish (3/4"- 1.5") flanged valve to flanged piping. While not nessecarily needed, a wrench of the type that you are suggesting would allow this. I've been in stations where it would have made life easier.
Mohawk Dave
SoCal
SNIP
I just don't think that market for them would be huge probably why in the last 100 years nobody has made them. SNIP
lol. devon, seriously not trying to bust balls and single you out bro. Just my opinion.....
I think it's super peculiar when people point out that if something hasn't been made yet, then it's probably not needed. Wonder who said that about automobiles, internet, debit cards, combines, and shark tanks.
Necessity is the mother of all invention. :beer:
Lorddiesel, I'm surprised you no want! lol. Ratcheting is strong, but I think access is the main reason. Super torque on the other side of the coin of course.
I'd also like flexed box for holding while running impact on other side. In fact, since it's box, put a lip on it so it catches nut/bolt face.
Jeremy77
Coastal Alabama
A ratcheting wrench would never fit on the inside of either of these flanges and depending on the configuration of any attached piping, maybe not on the outside. It wouldn't be a tool used all of the time but it could save dozens of turns on your wrist on occasion.
ADSR
That's what the open end ratcheting end is for.
Jeremy77
Coastal Alabama
When you are twisted out on an I beam 30' feet in the air with a harness on, it's not always easy to reposition your tools. Add in that due to things being jammed up, getting a half or even quarter turn on a bolt isn't possible with a normal box end. As I said, it's not an everyday tool but in my line of work, it could at times be useful.
Sam'sAutoParts
Northeast PA
Seems like it could be handy at times, especially in metric for newer cars. Alternator on my 2k civic comes to mind.
I'm thinking I would only use sizes 10-19mm
SASORacing
Utah
This is the point! So yes, I would use it very much because in the most places a fat ratchet wrench doesnt fit:( Not on a Bmw anyway!
you have a point but those are thick and probably cheap. The fact is its rare that the extra fractions of an inch make a difference. And even then the ratcheting mechanisim wins over slimness anyday. If clearance is an issue then grab a fixed wrench, but %99 of the time ratcheting works %100 better.
devoncoolman
quakertown pa
See thats not the point i was trying to make. I never said it wasn't needed. Or wasn't usefull. I said theres probably not a big market for it. See a big company is not going to make forging dies and dedicat full production lines to make a tool that wont sell millions of units a year. Just because we would buy them doesn't meen others will. Maybe im wrong but i don't think i am. But with all the new flex head ratcheting wrenches availible today most people are going to just buy those. Hell i know guys that strictly use ratchet wrenches. Barely even own a set of non ratchets.
bahcoswed
Sweden
Yes they are fat, but not cheap( Wurth Zebra)! All flexhead ratchet wrenches are fat! Not like my wurth maybe, but 10 times thicker than a regular combo! The problem for me when I wrenching is as allways the tight spots! I think an box end like a quadbox wrench has would be better because the ratcheting mechanism is outside the thick material and works a little bit like the box end on a stahlwille open box 13 or facom 440! But they are even thicker so the only way is to buy every style in the world on wrenches:)
K
KnurledNut
n/a
Bumping my old thread.
I really wish someone made this style.
It would have been more than handy on many past jobs.
Surely one of you tool companies that lurks these threads can make these a reality!
ThePostman
Virginia
I want that open end to be a good sharp v cut like the pittsburgh pros, the best cheap long pattern perfect for 90% of alignments wrench set that I bought them for almost 20 years ago. Make it long like gearwrench, mountain, matco. Yes, please give me a reversible flex ratcheting head on the other side and you are the perfect set of alignment wrenches. Please go from 12mm to 24mm with no skips, 26,27,30. Thank you my money will be yours as soon as they are on the market. Hey astro guy, pay attention to this.....
ChevyEFI
Phoenix, AZ
Find a ratcheting that can be bored and broached to test your idea. Might take a 10mm ratcheting to make an ideal 14mm bored and broached box.
ChevyEFI
Phoenix, AZ
Also, there are 12pt box flex crowfeet. Fitting the box part of one of those in place of the ratching part of a flex ratching combo would probably be the easiest path to building a prototype.
ChevyEFI
Phoenix, AZ
Using the VIM version of this would give an opportunity to have an offset flex wrench. Milling down another thick-neck wrench like a torque adapter could give a zero-offset build.
Wrench97
Southeastern Pa
That's where you use 12 pt heads because they are smaller in diameter.
K
KnurledNut
n/a
Good ideas. Especially the torque adaptor.
Al Borland
Is he installing or disassembling? Older stuff is traditionally 6 point. Even now, the usual going in is 6-point as the installer is using the supplied hardware.
Posted valve example 30 feet off the ground on a manlift is where vise-grips come in. Clamp 'em on and let it stop against the valve body and turn the other side. Break all the bolts loose before removing any. Impact gun and swivels are your friend.
And I would probably get a set of wrenches like that, try them and then leave them in the toolbox for 20 years next to my Robogrips and double open-end wrenches.
