I have gone through every ratchet I own to disassemble, clean, lube, and reassemble them. I find it to be quite fun!
I have two older style Craftsman ratchets, 1/4 and 3/8 drive, that have issues. I'd like to save them if I can, since they are nice compared to the current Crapsman offerings.
First, I need some help with terminology.
1: What is the proper name for the part of the ratchet assembly that actually engages the teeth? The part that has a ball bearing under it and that you "switch" with the selector lever?
My question is, is that part what is most likely to be the problem in a ratchet that has a clunky, coarse/rough, or loose feel, like it is slipping? I looked carefully at each tooth on the gears, and I see no obvious damage. So, I'm left trying to figure out what the problem is, and the only other major part I see is what engages the gears. Maybe the edges have been rounded off from abuse, and don't fit the gear tightly?
Finally, are rebuild or upgrade kits available? I'd like to save these if I can and if it isn't cost prohibitive.
Thanks for your help.
