PeterT
I am feeding a 60amp sub panel to a pool house about 75 feet from my house. I plan on feeding it with a 60amp breaker off my main house panel. Running 6/3 UF wire with a ground.
QUestion: Do I have to use the separate '2 ground rods' at the sub panel? If so, do I also connect the green ground wire coming from the main panel? Or do I ignore the ground coming from the main panel, and just ground my ground bar to the ground rods at the sub panel?
I know I cannot bond the neutral, that is not what I am asking.
Just want to know if it is recommended to both tie the ground from the main panel to my sub panel ground bar AND the ground rod (at the sub panel) to the ground bar?
Thanks in advance,
Attached is a diagram I found that shows grounding the bar in the sub panel to both the main panel ground and the sub panel ground rods.
Thanks in advance,
