Craigslist Kobalt Compressor PickUp
BearsFan315
Portsmouth, VA
Scored a Kobalt K7060HFV via Craiglist this weekend...
Guy was advertising a Compressor for sale on Craigslist, made the call, took a ride, a long ride 2+ hours to pick it up and gamble what he actually had. As the ad was a little vague and so was his description. Said he bought it to paint cars, after some talking found it was a Kobalt, not sure of the exact model, but was a few years old barely used. so made a few calls and Me and a friend took a ride out to the house and when we got to the house and saw the Kobalt and overall it looked good, dusty and dirty. Found out it was:
Kobalt K7060HFV
w/ NS18S Pump & AO Smith motor
13.3 CFM @ 90 PSI
15.0 CFM @ 40 PSI
135Max PSI
We asked if we could fire it up and the guy stated sure but it takes 20+ minutes to get to pressure, my friend and i kinda looked at each other and were like it shouldn't. We did a once over, check connections & fittings. Flipped the switch and it fired up right away, humming along after about five minutes it was only at 20psi and did not sound too happy like it was sucking through a straw. we checked all fittings and no leaks. My friend decided to pull the air filter cover and then pulled the air filter out, once he flipped the swith off, cause he could not pull it out while running. Pulled the Air filter out and it was caked !!
ayZq_DhdkiRFYomfQ5v0dPo_KOvqFUwNLVWMeRZHX6E=w868-h651-no
That Blue is Paint, and the White ?!?! yeah Bondo
the only reason you can see the white in the top right is because we scraped the blue away to see if it was all paint caked or not... mostly bondo with blue top coat.
best part was flip over the filter and the bottom was like new:
This was a good sign !!
Flipped the compressor back on it hummed right along smoothly pressure took off, 30, 40, 60, up to 135 in under 5 minutes. That filter was it a clogged filter to say the least so I will be replacing that.
here are some shots of what we carried home:
Hr9TTrWgaG2HhNzIVqbhXWfjMDhdEd9TDSoHcQHw55I=w563-h750-no
the unit runs great , it cycles on and off no issues, and hold pressure, no leaks. think i will take some time clean it up and check and clean all connections. put some vibration pads on each foot, find it a home in my garage and the wire it up. plumb up a drain on it, and go from there.
BearsFan315
Portsmouth, VA
Guy also threw in this filter & regulator:
Kobalt item: 221016 & Lowe's Carries them for $29.44 locally
Not sure the ture value of it, or just chunk it and get a better quality one, it is does not get any good reviews on Lowes.com Everyone says it is cheap plastic.
BearsFan315
Portsmouth, VA
Oh Yeah gave me his crappy blue 50ft hose as well, I may hold on to it as a spare, but my Flexilla is my go to Hose all day long !!
Also gave us some Cans of Bondo, Activator, and Clear coat about 6 cans of stuff NEW un opened. gave that to my friend as he is more into painting and such. he is going to check to see if they are any good and the value of them.
38Chevy454
Cincinnati, OH
Looks identical to mine that is from HF. Had mine for about 12 years now and it works great for me. Great price and shows how much the air filter can affect performance.
srmofo
SW ohio
That's a YOU **** at that price!
You really think so?, Its been abused (at the very least neglected) with the filter issue and its only a single stage. Its a $500 compressor new. I think its a good price, but IMHO not worthy of a you ****. $200 and he would have been there.
You guys are starting to hand these things out like candy I tell you.
gungatim
west mich
I say it's a you ****, the filter kept it from being damaged, add in all the extras and you got a great deal. probably used it once or twice and thought it sucked (or rather didn't) because it was so plugged up.
make sure you change the oil!
mbret2004
I'm on the hunt for an older Quincy compressor. Very hard to find and if you do they still demand a decent price.
Pointbock
AK
Oh Yeah gave me his crappy blue 50ft hose as well, I may hold on to it as a spare-
Give it to your brother-in-law. If you're used to a Flexzilla, you'll throw a fit when that PVC POS won't straighten out, hooks on a lawnmower wheel, tips over a paint can, kicks your dog, bangs you wife, ...
Nothing in my garage pisses me off more than the crappy PVC hose that's serving as the link from my compressor to my Flexzilla reel. Mine's blue too, and I intend to give it away with my current compressor when I sell it.
BearsFan315
Portsmouth, VA
Looking at Regulator & Air Filter combo at lunch today, here are a few that popped up:
3/8 In. Air Filter with Regulator
...Yeah it's HF but it gets decent reviews
JET JFR-38 3/8-Inch NPT Air Filter/Regulator
Ingersoll Rand P39234-600-VS 3/8-Inch Filter-Regulator
...nice combo set from IR
Ingersoll Rand C38231-600-VS 3/8-Inch Filter-Regulator-Lubricator Combination
...Set include oil lube, but do NOT need it, could I just not USE it ?!? and save a few bucks
any of these any good ?? considering i will be using a few air tools, blow gun, and maybe a blast cabinet down the road. just want to keep the water out of the line if possible.
Open to suggestions as well... not going CHEAP just want to be practical and economical
therealaveragej
You don't ****, you ****!!! Seriously though, good find. I'm still stuck with a 29 gal hf- That *****.
furbyj1
Miami, FL
one day I might upgrade to real compressor like this... but for now my 17gal from harbor freight will have to do the trick
404
Mass
Filter is installed backwards. Green side is outlet.
BearsFan315
Portsmouth, VA
Tons of Bondo caked on the belt guard, then coated with paint overspray....
Spraying with water just does NOT cut it... been scrubbing with a stiff bristl brush trying to get it off
PT Doc
Change the oil for sure. Seeing how this guy doesn't give a cramp about his tools and even think to look at an air filter when it supposedly takes 20 minutes to get full pressure, he likely did not drain the tank either.
BearsFan315
Portsmouth, VA
Well the parts i ordered started to arrive today...
got a few new filters, one to go in, one for a spare
Zoro Tools # G2652885 Stock No 4FY38
Also available from Grainger for 2x the price
Also ordered a Direct Replacement Pressure Switch, from Condor:
Condor Number 11VC2FALE 110-135 PSI, Switch, Adjustable Range, 4x 1/4" Port, Unloader Valve
BearsFan315
Portsmouth, VA
Also ordered some Feet to hopefully absorb vibration and allow me to level the Compressor, as my floor is NO WHERE near level or SMOOTH !!
McMaster Item 60855K33 Can also get them with the studs, but price almost doubles. I opted to pick up my own hardware
2ygz4WsXZHms2DzZRX1j9e_SKgxdo6p1xa1y65dnQwQ=w838-h750-no
Lowes, Got 12" 1/2-13 Threaded Rod, 8 1/2 Flat Washers, 8 1/2-13 UNC Nuts. All for about $7
BearsFan315
Portsmouth, VA
also picked up some new hardware for the compressor and motor mounting.
as well as some piping for a drain.
1/4" Street Elbow, 6" 1/4" ******, and a 1/4" Full Port Ball Valve
and some 1/2" Piping for plumbing to the new regulator :)
furbyj1
Miami, FL
WOW, that is an amazing job you've done on that compressor. under all the gunk you cleaned off its still practically new looking.
