Transfer punches, what are you using?
Strouty
Southern Maine
I am thinking that I need some transfer punches, looking for a decent set. What do you guys use? They will not be used all the time, so I don't need the best, but I would like the best bang for the buck. I think I will probably need metric and SAE ¼" up to maybe 1" Similar sizes for metric.
dogdog
HF have a set I used them a few times to copy a flange holes but that is about it I used it for.... nothing critical..nothing super accurate...
Steevo
43.49600, -112.04300
I have the cheapo China made ones, and they work ok, but the points flatten out almost the first time you use them on steel, because they are too soft.
I hope to replace them someday with a better quality brand, but for now, they have helped me out a half dozen times in a couple of years, so worth the cheapo China price.
Strouty
Southern Maine
I may search ebay and see if I can find some decent ones. If I can't find any, cheapos will probably suit me fine for a while.
LXCam
Check out Use-Enco for those. They have regular sales and you'll find you need a complete set. But at a minimum, get fractional and wire gauge.
BillK
Beautiful Southern Maryland
Strouty,
Like Steevo said, the cheap ones lose their point the first time you use them, I know, I have a set :( Getting ready to pull the trigger on the best set I can find but they will be pricey. Check MSC, Mc Master Carr and Enco. Have not made up my mind which ones to get yet but they will not be the cheap ones !
BillK
Strouty,
Not sure of brand names but I would expect to pay close to $100 for a decent set. The $30 sets are junk. Basically you get what you pay for :)
plinker
Northern Wi
For larger then 1/2", MSC has USA made, about 10$ ea. a set is available I think. Zoro tools has imports as well.
Tinner
N.E. Wisconsin
A transfer punch is used to make a tiny mark. You just tap it, then hit that mark with a real center punch. Yes the cheap ones are softer, but even the best will lose their point if you attempt to center punch with them.
I have a cheap standard and metric set from Enco that I've been using for over ten years.
1950mercury
metro detroit
Well said
ADSR
Oh! So that's how you do it! :headscrat
No wonder why mine are all flat. :spit:
popparoach
okc,ok
when i first got mine,I beat the snot out of my harbor freight set on a vise trying to flatten them but they stayed sharp.i wanted to see what they could handle or if i wasted my 8 bucks.they have lasted 3 years so far and going.
Monte
Germany
Rennsteig
xxaler
Sutton Ontario
Monte, those are definitly very nice. I would love to have a set of those for my use at work, but I'm limited to the Harbor Freight set due to it being an open machine shop. Everyone borrows every ones tools.
No one seems to understand you don't need to wail on a transfer punch with a 32oz hammer..
PT Doc
Enco had a nice set made in USA that seem to be really well made, except covered in all kinds of wonderful black slurry.
2oolhound
BC Canada
This is one of those cases where I wish manufacturers would provide a little more info such as:
Rockwell hardness
Grade of steel
Rennsteig at least tells us - hardened, tempered steel, resharpenable, spare pins available and they say it's special tool steel. All great info without telling mimic offshores how to copy and try to under cut their price.
Good post Strouty, I've been holding off on a set of these also because I didn't want cheepos from china even though they are so inexpensive up front. So far the Rennsteigs get my vote because of their presentation with good info and the replaceable pins. Just what I hope to expect from a company who builds quality products and plans to be around for the long haul to stand behind them and service them.
http://www.rennsteig.us/products/hardware/punches/589-adjustable-expanding-transfer-punch-set.html
leg17
Kentucky
What he said!
Techie1961
Pickering Ontario Canada
Rennsteig
Those are definitely cool but won't take the place of my Osbornes. Would be a nice addition but I have had to to use the longer guided shank of a regular transfer punch. The Rennsteig punch will only work if the hole that is being transferred is directly in contact or at least very close to the material that needs the punch mark. That being said, they look great for most uses.:thumbup:
Mohawk Dave
SoCal
I have Spellmaco up to 1".
The problem with the cheap ones is #1 The points flatten, but more importantly, #2 the point is longer so when you are transferring through thin work, you can't.
twertsy
Reedville, VA
I find those all the time at sales/garages/CL picks, etc. If you like, I'll pick up a set for you Strouty. Actually, now that I think about it, I just might have a spare. I'll check the next time I'm at the shop (likely Thursday).
Leoruiz
Are you a machinist or a fabricator ? These are great for general fabrication.
There are two sizes. Buy both.It's spring loaded. Put the cone in the hole and press it flat to the surface.
http://toolmonger.com/2008/08/07/dealmonger-universal-transfer-punch-650/
Adam.C
I too have the Chinese centers and agree they ****. My plan was to chuck them into a metal lathe, in a 3 jaw chuck and return the center points to be concentric with the shaft.
I have had success heat treating some Chinese tool steels and wouldn't hesitate to try that. You can heat just the end with a MAPP gas torch until it is non magnetic, then quench in water or oil. Bake in your kitchen oven at 350 or 400 for 20 minutes, then air cool.
You could probably fix 20 punches in an afternoon.
Strouty
Southern Maine
I just ordered the fancy German ones that Monte recommended. I probably paid too much, but I really liked the looks of them.
