My barn tends to run on the humid side. It is particularly troubling in the early spring when the barn is still cold, and the air is warm and moist, but year round the humidity levels are high. I live in SE Michigan.
It is a 44 x 54 building with a concrete slab. On top of the slab is a VCT floor. The roof is trussed with ply and asphalt shingles. It has a ridge vent. The interior ceiling is OSB and there is R19 batt insulation, vapor barrier down on top of it. The walls are OSB with batt insulation behind them. Not sure if it is R13 or 19. The garage door is insulated 10x10.
There is an "attic fan" in the ceiling that when active draws air out of the conditioned portion of the barn, into the attic and out the ridge vents. I do not use this as I think it would draw humid air into the barn.
In the summer it is generally cooler in the barn then outside by quite a bit. (today it was 70 degrees F in the barn, 86 F outside. Relative humidity in the barn was 60%.
Because the barn is cool, and the air is moist I have condensation issues. When it is particularly bad, the floor and cars can get damp. I have had a mold grow on the interior of one of my cars last year. In response I added a portable dehumidifier and it does help, but is not doing enough, relative humidity is generally high.
If I open the garage door on a humid day, everything in the barn that is metal (like my cars) gets coated in a fog of condensate. I am tempted to run the heat to warm the barn up and reduce relative humidity, but It is hard for me to actually do that when it is 86 outside...
Would an fan in the attic to outside on a humidistat help any? More or larger dehumidifier? More roof insulation?
Suggestions are appreciated,
Joe
Joe
