Pavlik's suburban 2-car garage
Pavlik
Bothell, WA
I have been a long-time lurker who finally decided to join, record my progress here, and share things I learn along the way. Garage is 20'x20'.
2013
My wife and I finally took the plunge in 2013 and purchased a freshly built home that came with a 2-car garage. Initially I dreamed of it becoming my "man cave", but in reality it's a family space shared with the wifey and our 2 kids.
This was taken shortly after we moved in and I cleared enough boxes to park my car in there
First order of business was to purchase something to get the bins off the ground. To this day, 3 years later, I still don't like this hanging solution. But until I find a better way to store our Christmas decorations and other random things, this will have to do. The shelf came from Lowes and was one of the cheapest models available.
The first summer in the house I decided to get the walls painted. After looking through numerous garage threads on GJ I knew I wanted to do split color. Gray bottom and light top, it makes the low ceilings feel higher. Instead of the more common red dividing line I went with purple. Partially because it's wifey's favorite color and because I'm a UW Huskies fan/alumni. First came the primer...
Next were the two main colors. I used masking tape to cover the area that was going to be purple.
First lesson learned: don't leave masking tape for too long on unpainted walls. When peeling it off it removed some of the material with it. To this day I can still see the areas through the paint. Cabinet that I purchased from Ikea is in. You'd think being an accountant, I'd know how to measure the space and get the right amount of cabinets. I could've easily fit another on in the space. To my knowledge they’ve been discontinued, so I am stuck with just 3.
2014
Summer came, which meant more projects around the garage. I scored some white kitchen cabinets on Craigslist for $200! Our house has studs that are very far apart, to keep cabinets secure I used boards cut to the width of each cabinet. After 1 year of being loaded with things they haven’t moved an inch. I also tried to use a standard kitchen countertop, but it was too short, wrong color, and not level. So it was returned. I went another year staring at the empty space where the countertop would go.
After spending whole rainy winter manually opening and closing the garage it was time to get automatic opener. This was the first time ever I installed anything like that. It’s belt driven to keep the noise levels down.
The same summer I finally got around to painting the garage ceiling and went from MK6 GTI to MK7.
2015
Wife and I have been busy with repainting our house…which reminds me of modifying cars. I have told myself countless times that I will “just do wheels and suspension”…it never worked out that way. Our “just repaint the walls” has turned into painting baseboards white, which turned into having to get white doors…and while we are at it, replace linoleum bathroom floors with tile. I still managed to get one big item almost done in the garage: countertop.
This brings us to August, 2015. I wanted the countertop to span from the door all the way to the wall, providing plenty of space for my tools, small drawers, etc. Countertop consists of a wooden frame, layer of plywood, and oak hardwood floors. Developers must not be expecting people to use these garages for anything other than parking cars, so I am also adding another power outlet to the countertop so I don’t have to run extension cords when I want to use a grinder or a drill. Last finishing touch was to put a layer of Glaze Coat I purchased from Lowes. Lesson learned while putting glaze on the countertop: you should always fill all the cracks in the wood and even though it’s already been stained and sealed, another seal layer is a must. I ended up with areas where the glaze seeped into the cracks leaving mediocre surface. At some point I may put on another layer…or leave it as-is. Wife and I want to upgrade to a bigger house and one of my must-haves is a 3 or more car garage so I can finally get a dedicated project car to work on. Finally pictures of the countertop (with daughters Bug fitting snugly underneath it)…
Before Glaze Coat:
After Glaze Coat:
Below is the most up to date pano shot of the garage. Few items I haven’t witten in great detail about:
-Gladiator rack system used on the left side of the garage to hang my son’s skateboards and our helmets.
-Same system is used on the back left of the garage to hang our bikes. Unfortunately the ceiling is too low to put them above our cars.
-Truck cargo net and some hooks to hold sleds and other random items on the left side of the garage.
-Ball rack on the right side of the garage.
So what’s left?
1) Run the power to the countertop
2) Clean up the concrete floor...it has lots of paint overspray from the door fiasco (converting from wood to white)
3) Find places for all the random items laying along each wall
4) Use either brushed steel or diamond plate under the bike rack where bicycle tires touch the wall. Use the same material for the door where kids tend to kick it open.
5) Add satin glass shelf below the cabinet located next to the door to display some of my car show trophies.
6) Source out some motorsport wall art to hang on the walls…one of them will be used to hide the circuit breaker on the right side of the garage.
7) Upgrade the lights.
8) Floor…I am still looking at my options. As of right now it’s looking like it will either be RaceDeck or another similar tile system or epoxy.
Thank you for looking and reading! I welcome all suggestions and comments.:D:thumbup:
jbrentd
Northeast Oklahoma
Looks good so far! Way to represent your favorite team with that purple. When I first read it, I was skeptical, but it turned out nice.
I see your builder put in some fancy lights for you. My attached garage had simple builder-grade lights on the ceiling that I have swapped out for florescent fixtures. It really brightened things up. But you already probably knew that since it's #7 on your list.
HSpencer
South Central US
Welcome
Looks really nice. You have brought it long way already. I like the cabinets and the wood top. A nice touch would be some under cabinet lights, and they are pretty reasonable in price. You can even get some battery operated ones that have a good lighting effect.
Looking good and I will check in to see your progress. Thanks for posting on Garage Journal!!
Best Regards
Herb Spencer
P
Pavlik
Bothell, WA
Welcome
Best Regards
Herb Spencer
Thank you Herb and everyone else for the words of encouragement! I agree about the lights under the cabinets. That will brighten up the space and help with whatever projects I will be working on.
Family and I are back from camping, so this weekend I should be able to run power to the countertop. Also considering adding another power outlet down below for my daughters electric VW Bug. If we stay in this house long enough for her to grow out of it, I can use that power outlet for a small cooler.
Welcome to the forum! Great to see another VW enthusiast. Nice mk6 and Mk7.
Thanks! Wifey couldn't figure out how I can continue buying the same car over and over. Started with MK5 and keep working my way up the generations haha.
dubber
Canada's Capital
Hahaha, she doesn't have to really understand, as long as she lets you do your thing. I'm always swapping our dubs as well. :thumbup:
Denwood
Thunder Bay, Ontario, Canada
Loving the dog! On your points 7 and 8 (lights and floor), those made the most dramatic difference in my shop. If you go with epoxy, I'd consider white. It will brighten your space dramatically :) Your design choices so far look great.
P
Pavlik
Bothell, WA
Wifey does understand and lets me play around with them. Although I don't know if MK7 will see any mods before I sell it. Had it for 1 year and haven't done a single thing to it.
In regards to the floor...white might be difficult to keep clean and I hear people say that hot tires do tend to discolor the epoxy a little bit, giving it a yellow hue. We park both cars in there every day, so whatever I go with needs to be strong enough to withstand hot tires on daily basis.
Item 7 (lights), I will most likely go with LED for the energy savings. At least once a month one of the kids forgets to turn off the lights and we don't discover that until the morning or when we return home from work. Also I am tempted to paint the fixture housings purple to tie them to the stripes on the walls. We will see though. Don't want to go overboard. :)
P
Pavlik
Bothell, WA
I have come up with a rendering of what I want the back wall to look like when I'm finished with it. Main changes include gray color in the cabinet door's indentations (same gray as the bottom of the wall). Above the cabinets I want to build a shelf that has a vertically hinged door painted same color as the wall. Goal is to get rid of the black cargo net holding all the random holiday decorations. Space above the cabinets is small...big enough to hold the snowboard, but I still want to have a door there to cover it up and blend the cabinets into the wall. Denwood's garage has been my inspiration for this :)
HSpencer
South Central US
Good plan. I would say cabinets gray, maybe trimmed in white. Door should reflect the same color with gray door and white trim. A white door will tell you about that greasy hand that opens it eventually. Also, white can **** up dirt pretty fast.
Just an opinion.
Best Regards
Herb
dubber
Canada's Capital
What are the dimensions of your space? I know one of my main successes to save space and have full used of the width is avoid having anything on the floor along the sides. That really gives the most room with parking two cars in a standard suburban double.
P
Pavlik
Bothell, WA
I must have a 6th sense because this morning on my way out I finally decided to measure the space. Rounded up it's 20x20...although actual concrete patch is smaller than that.
Wife and I are planning on going through a bunch of the items along the sides of the garage and either tossing them or trying to sell on Craigslist. I also have a little nook by the bicycles...I'll build some shelves for it and store random items in there.
Had to make a trip to Home Depot yesterday for few home items, with the "one item for the wifey, one item for me" rule of thumb I got some things for the garage too :D. Purchased new cabinet door knobs so I'm not touching the doors themselves with greasy/dirty hands and some gray Rustoleum paint. I want to paint all of the garage door rails/hangers. Brother in-law has a welder, so I am also going to rebuild the garage door hanger and paint that.
Picture of the new door knob vs the old (no more gold!):
P
Pavlik
Bothell, WA
Thank you. This weekend I will install the rest and hopefully run power to the countertop.
How are you liking your RaceDeck floor? Especially when the time comes to clean it? Winters tend to get really rainy here in WA, and I like the idea of the water draining down, but seems like keeping the floor clean underneath the tiles will be a PITA.
Denwood
Pav, glad you found some inspiration in my storage solution :) The goal to get everything off the floor is a good one indeed. I have some heavy power tools that need to be on the floor..but rule two is everything on wheels! I love the white floor..but know it's not for everyone. My last plug for a white floor...apparently makes a good dance floor..ha :)
dubber
Canada's Capital
One of the best decisions i've made. Beyond proposing to my wife lol....
Honestly its hard to describe but it completely transforms a garage. The FreeFlow tile design is perfect for wicking water away from the surface. We deal with snow up here and it works great. You can shop vac the surface and most things pull through. Then it all comes down to you own personal level of OCD for cleanliness. I pull up a section of the tiles once a year after winter and give a thorough cleaning on the sealed cement floor.
P
Pavlik
Bothell, WA
Did some more work this weekend on the garage. Learned how to splice into existing power outlets! Countertop power outlet is now live!
Also started painting some of the random bits and pieces gray. Have to figure out how to do the garage door rails without removing them.
Before:
After:
Before:
After:
Otherwise just did lots of cleanup...trying to move as many items off the floor as possible.
P
Pavlik
Bothell, WA
Yes, and they sometimes makes a world of difference too! This weekend I didn't do a whole lot in the garage...just filled the holes for the hooks that used to hold the black net on the ceiling. Since I had all the paint buckets out, I also went around the whole garage and filled all little dents I've accumulated over the last few years.
With Christmas and wifeys bday coming up, I doubt the garage will see too many projects. Although I do hope to finally start working on the GTI and get rid of that wheel gap.
In the picture the left wall has been cleaned up, and I painted cabinet indentations gray...still seeing how I feel about them.
QBall68
Very nice transformation - I really like those Ikea wall cabinets! I know you said they're now discontinued, but would you happen to know what they're called? That form factor is exactly what I'm looking for in my garage...
P
Pavlik
Bothell, WA
Sorry it took me a while to reply. I don't know the name of them, but they were in the kitchen section of IKEA. They seem to sell similar cabinets, but the doors are different. Another thing to note about these that I didn't think about before: hinges are set up to open the door all the way up, that's where they "lock" it in place. Having the cabinets where I do, prevents that door from opening up all the way, so it always tries to close itself on me. I have been toying with the idea of purchasing taller kitchen cabinets to match what I already have on the back wall, they should fit a lot more stuff, and I'll be able to open them up all the way. Probably have those go the entire length of the wall. It will (hopefully) allow me to get rid of that ceiling rack, brightening the space and making it look bigger.
Dubber...jury is still out :lol:, but I'm leaning towards just removing the paint...finish on the cabinets prevents good bonding, so this paint can probably be removed with just a finger nail.
P
Pavlik
Bothell, WA
Not too many changes or updates for the garage. I finally got some posters from a friend of mine to put up on the walls. Although I might look into printing images of my current/prior cars instead, frame and hang them.
By far the biggest change since the last post took place in the car department of our household. GTI has been sold and for the time being we will remain a German car free family. But after realizing that the new addition is the 9th vehicle I have owned, the next one will have to be extra special. :3gears:
This weekend my wife and I flew down to Pasadena, CA and picked up a 2005 Acura MDX, then drove it up to WA. Fun rig...first SUV I have ever owned. Only had it for about 3 days and it already created some fun memories on the drive up with the wifey!
P
Pavlik
Bothell, WA
Finally got around to doing something with the garage! While getting random household items I took a stroll down the lighting aisle and walked out with a pair of LED light fixtures! Can't believe I didn't do this sooner!
Left side is the original, right is the new LED fixture:
Both sides installed...now just need to get LED garage door opener lights to match the color:
First order of business was work with my daughter on building a Barbie doll house for her. Her favorite part was hammering haha
All done! Primer and paint will come next.
Travy
Bothell, WA
Those LEDs made a huge difference! I think Kellen just picked one of them up recently too for his garage.
P
Pavlik
Bothell, WA
Yes they do! Since then I did upgrade the garage door opener light bulbs to LED so the color temperature would match.
Not much else has been going on in the garage because we are concentrating on remodeling the rest of the house. What started out as a simple project of painting the walls has morphed itself into remodeling 3 bathrooms, replacing all doors, and painting all baseboards.
I am hoping that either this summer or fall I will be able to get some race deck flooring put in and change the IKEA frosted glass cabinets to something that can fit more things.
crab
Nice place, I have about the same size but we have basements so that helps. Those cabinets are pretty nice. Paint really looks good.
