6pt vs 12 pt sockets
rjtack
Finger Lakes region of New York
I've always thought 6 pt sockets were better than 12pts. Having more material seems to make them stronger and less likely to slip. Now I see guys getting rid of their 6 pts replacing with 12s.
What do you guys think about all this?
scissorman
Pleasanton, Ca.
Well, a 6 point socket wont work on a 12 pointed bolted. Me personally though, I use 12 point for everything unless I know the fastener is really tight then i'll grab a 6 point to prevent rounding the corners and creating a bigger mess. The same logic for 6 or 12 point wrenches also.
AceofSpad3s
I think 1/4 drive 6 point is essential because of the small heads with little material. I use 6p 3/8 the most but 12 should be fine since the bolt heads have more material. 1/2 is perfectly fine using 12p since the heads have a lot of material, 99% of the 1/2 drive stuff I have, new and old is 12p. In conclusion, 1/4 no, 3/8 so so, 1/2 perfectly ok.
Shiftless
East Bay SFO
Anybody dumping sets of 6 point sockets (Snap on, Mac, Proto, USA Craftsman, etc.) can dispose of them easily by boxing them up and shipping to me. I will pay postage.:D
remedialmofo
12 point bolts and fastners get 12 point sockets. Stick with 6 point if you don't care too much about the increased distance to get it indexed and seated and you don't truly need a 12 point socket. As mentioned the likelihood of rounding bolts and fasteners becomes very unlikely assuming you're using the correct size
Sent from my SAMSUNG-SM-N900A using Tapatalk
shoggoth80
Seattle
Both. 6 point sockets for 6 point fasteners. 12 point sockets for 12 point fasteners. Unless you can only afford one, and you don't know what you are up against... then buy 12 points. Each has their merits.
12 points can index to the fastener a little faster, but if you are using a ratchet, this is a non-issue. 12 point combo wrenches make sense if you are working in an area of limited swing.
1950mercury
metro detroit
3rd time is the charm.....
Hey op im not trying to be a **** but use the search function. You started 3 posts and they are all topics that have been brought up countless times ..
PJNJ
Iowa
Rjtack,
In 1/4 drive chrome, I have 6 pt. only.
In 3/8 drive chrome, I have 6 and 12 pt.
In 1/2 drive chrome, they are almost all 12 pt.
I rarely, if ever, use 12 pt. in 3/8 and only used 12 pt. 1/2 sockets a few times. As said before, in 3/8's, use 12 pt. on 12 pt. fasteners. Once I get to the point of using 1/2 drive, I now usually reach for the impact gun and sockets. Now that I picked up an Astro Pneumatic Nano, I'm also starting to use 3/8 impact sockets with an adapter.
And don't let them get to you. Lots of questions have been asked over and over again. What they keep forgetting is that members come and go. What's "old news" for many is new to many others. Keep posting.
:beer:
M4A1Carbine
Florida
Most of my sockets are 6 pt. I only use for 12 pt sockets for hard to reach nuts so I don't have to adjust the socket as much to get it on.
I don't recall ever encountering a 12 pt bolt, but I mainly just work on my own cars at home so there is a lot I haven't seen.
BDT/NWMN
Erskine, Mn
Some people do appear to do unusual things:headscrat:headscrat
Tool choice and needs will vary with different jobs and occupations..
I need 12 point for 12 point fasteners, and often use them on hex head bolts and nuts.. The twelve point sockets and end wrenches are all some people need...
Other people have to deal with stubborn, worn, rounded, or rusty fasteners; the 12 point sockets and end wrenches are not the best choice.. Your observation is correct; the six point would be the better choice under these conditions.
For me; I need both,,,, and that may seem goofy to some people also..:D
Siteman25
I use 6 point unless 12 is needed, either due to:
1) something other than hex nuts
2) I need the extra index the 12 point gives (rare, especially with 5 degree or better ratchets)
heytrid
I own full sets (1/4,3/8,1/2) of both in Metric and Standard, 99% of the time it is 6 point for me. 12pt goes on 12pt fasteners.
nine4gmc
Dallas
I have Craftsman 6 and 12 point in everything EXCEPT 1/4" drive METRIC. I can ONLY find 6pt in that size. If anyone knows wtf is up with 1/4" drive 12pt metric, please post up.
In almost 50 years on shade tree wrench twisting, I have NEVER come across a 12 point nut or bolt head.
If I come across one, I will buy the appropriate tool if my combination wrench (12 point) won't work.
Askme42
Goreville IL
Drive shaft on my 97 ranger. Couldn't believe it. I have 20x as many tools as my dad and he had the 12 pt socket I needed.
MattVette89
SW Chicago
My aftermarket intake uses 12 pt bolts. I know ARP has some as do other manufacturers.
nine4gmc
Dallas
Wow, no sense of humor I see... Well, welcome to the site anyway, it takes all kinds...
BK13
PDX, OR
The topic has come up once or twice.....
04-29-2005
6pt & 12pt Sockets
So, If a topic has ever been talked about it can't be brought up again? I know how to search, I just wanted a current viewpoint on this. Man, I can't catch a break on here, what with being tagged as banned and all. Wow.
Yeah, man, can't catch a break. If you start a new thread, you catch hell. If you dig up an old thread, you catch hell.
As to your question, I see no good reason to only have one or the other. Just use six point on six point fasteners, twelve on twelve. (I will admit to not having any twelve point impact sockets... If I ever need 'em, I'll buy individuals....
Hammer1963
Kentucky
I use and own both. Certain jobs just require certain tools and that's why they make both.
As far people screwing with you, kill them with kindness ........
PelicanPines
I have 6, 8, 12 point... If its a 6 point nut I don't bother trying the 8 or 12 ... ok a slight amount of sarcasm there... but you get my point... get it... point!
edit: not messing with you... just saying... I have them all and use them all based on what I'm doing. I wouldn't get rid of anything. Heck... I have a whole set of triple squares that got used 3 times in one day and never since.
nine4gmc
Dallas
Psssst pm 9's GF so She can put that set on Her Santa list... Those would make nice Christmas Tree decorations to boot... And we think 9 is smiling now:bounce:
I've been a bad boy, plus who spends $100 on a set of 1/4" drive sockets? :wtf: :lol:
John in OH
SE Ohio & Eastern Virginia
Rjtack,
:beer:
+1 on the above. However, I also have 1/2 drive 6 points in SAE for a lot of ag equipment applications as often these fasteners may have rounded corners. Plus, many of these large fasteners in these applications are rusted or otherwise buggered up.
Also, agree regarding the posting. The search function in the GJ software really ***** and it can sometimes be a real problem getting meaningful search results. I guess a lot of guys here have nothing better to do than keep track of who posts what here when.
9 point sounds about right, very funny, but nobody mentioned the 8 point sockets for the wide variety of equipment using square nuts.:D
Not sure if you are joking or not, but a lot of antique farm equipment uses square-headed fasteners and nuts and the 8 point sockets are really useful.
Wakefield
Arlington VA (but would like to get out to country
There really is a 5 point socket (for water meter covers and such)
12 point socket on 12 point capscrew head or nut is theoretically able to handle more torque without rounding than 6 point on 6 point. Spline drive perhaps even more (until they get rusty)
Snap On's 12 mm. 12 point socket is supposed to be strong IMDM120A
Avoid using 12 point impact sockets on anything but 12 point fasteners?
PelicanPines
What about your 4-popint and 5-point sockets?
And your 3-point sockets.
Hmmm nope... no 4 point sockets. Those 5 points... I call "keys" and I don't have those either... I have hex keys, torx in both socket and keys, triple square in keys.
Oh yea... spline drive sockets too, got a bunch of them too.
winlinmac
USA
I use my 12 point wrenches for 12 point fasteners
and six point tools for 6 point fasteners
Most of my work involves 6 point fasteners
12 point is more suitable towards light-duty tasks
Jim C.
Yeah, I was kinda thinking that myself, but okay, I'll give the guy the benefit of the doubt. I have 6 point and 12 point sockets and use both. Still, I tend to go with 6 point sockets whenever possible because they pose a lesser risk of rounding off the corners of a fastener.
Hey Nine,
As far as I know, Craftsman never offered a set of 1/4" drive deep or standard depth 12 point metric sockets.
Jim C.
619DioFan
San Diego , Ca.
I have 6 and 12 point deep and shallow in all sizes available in the 3/8 and 1/2 inch drive size(s) have 4 point ( pipe plug sockets ) for those types of fasteners. haven't run into a situation where I needed a 8 point socket ( yet ) so don't have any. I think I am pretty well covered with the 6 12 and pipe plug sockets. all my impacts are 6 point. haven't came across a need for 12 point impact sockets ( yet )if someone here uses 12 point impact sockets please enlighten me as to their usefulness so I can decide if they are a worthwhile investment.
