Check out my new BendPak/Ranger floor jack!
ovilla
Plainfield, IL
Yes, BendPak sells a bunch of other cool stuff besides great lifts. Here’s a product from BendPak’s Ranger brand (which is where my 50’ ceiling mounted air hose reel also came from). I’ve been in the market for a new floor jack for a while as my Craftsman unit has been leaving a lot to be desired lately and has been coming up short, in either reaching depth or height. So, after checking out a lot of seriously over-priced floor jacks, here’s something that won’t break the bank and can reach any depth or height you may ever need.
Introducing the Ranger low-profile, long-frame (RFJ-3000LPF) Floor Jack!
This is an extremely low-profile (less than 3”), long-framed (34”) floor jack with a lifting capacity of 3,000 lbs. Check out my pic below of it next to a landscaping stone. Yes, it’s that low. With the jack at it’s lowest setting and round black lifting hub installed, it’s a mere 2-3/4” tall (it’s a little lower if you don’t need to use the hub). Then, after only 8 pumps (some times only 7) you’ve reached the jacks maximum lifting height of 24 inches (isn’t that ridiculous for a floor jack?). It weights 112 lbs, but wheels around very easily thanks to the wide front wheels and rear swivel casters. The lifting capacity of 3,000 lbs is also perfect and will easily lift the front or rear of any vehicle. So far I’ve used it on my van, my little 914’s, and an old 66’ Chevy truck, and it was a breeze with plenty of length for getting under the rear axle, even with a big bumper in the way.
Okay, so how stable is this thing at full height? Extremely stable. The front is 11” wide and the back is 14-1/2” (so think of it as a fat 3-foot long piece of 2X12 deck wood!). Check out my pic below and you’ll see that as it reaches the maximum 2’ height, the jacking point is almost perfectly centered along the jack’s long body. To me, this is the best part of the design of this jack, the fact that the lifted weight of a vehicle gets closer to the middle of the jack, the higher you lift. By the time it’s lifted to the 24” maximum, this jack actually looks more like a jack stand and ends up using the full length of the jack for support. I’m sure they purposely designed it this way to better support heavy loads. Last week I lifted a truck by the rear axle and with the jack all the way up, everything felt rock solid. Nothing ever felt like it was going to tip over and cause the rear wheels of the jack to lift off the ground
So, let me know if you have any questions. I got this one for $290 (included shipping) and I think that’s a great deal! I’ve checked the internet and I’ve found that these specialty jacks are quite pricey and a jack with these same specs will easily sell for two to three times this price.
vette-kid
Navarre, FL
Where??? I need something like this to lift my Vette and pull double duty on my lifted Tacoma...so it needs to be really low and have a high max lift...this looks perfect!
O
ovilla
Plainfield, IL
You can get it through Brian at www.asedeals.com. He's a great guy and is very knowledgeable on the BendPak line too. I ordered my HD-9 through him last year and he was very responsive with questions and timely with my order info. Also, if you order a bunch of stuff, do ask him to give you a "bundled" price as he'll most likely be able to pass some savings on to you.
rinny_tin_tin
Northern Virginia
Wow - that second photo with the *erect* arm and saddle - it looks like its happy to be there :)
skuzzel_butt
any reason you went with the RFJ-3000LPF and not the RFJ-2TX?
any idea where these are made??
joe
e-tek
Saskatoon, SK
Great write-up O! Thanks for the info and photo's - I hope ASE or BP have you on the payroll!!
vette-kid
Navarre, FL
Funny, I couldnt find it on the ranger website until Revlover posted the link :headscrat Thanks:thumbup: Ill be looking into this...hopfully it can manage to get my Tacoma high enough to pull a tire:wtf:
O
ovilla
Plainfield, IL
You should have no problem lifting anything with big tires if you lift from the axles and not the body (although that really does depend on the vehicle). The truck that we lifted had 37" tires and the jack wasn't even jacked up all the way at first - still had a good 8-10" of height left on it when we first took the tire off. I was also lifting from the side of the axle (not the pumpkin) as we just needed to get the one tire off. I bet you could easily remove 44" tires if you lifted from the center of the axle. Anyway, it's just really nice to have one rolling jack that can truly do it all (go super low and super high) and I wanted to share that with the GJ folks.
I know this isn't the same as blow out pricing on Gladiator cabinets (that was a great find jshillin) but it's still something worth sharing as a lot of folks will eventually replace a floor jack or think of picking up another one. Let me know if you order one and how you like it. I like mine so much that I'm already thinking of donating my old Craftsman unit to the church rummage sale this spring. It doesn't really make sense having the old jack around taking up valuable floor space.
2_lude
TX
I was just looking at this jack yesterday, thanks for the review! Wanted to get an AC Hydraulic jack, but it doesn't look like they are available anymore. How did you get it for $290? On ASE site they charge $40 extra for residential delivery.
O
ovilla
Plainfield, IL
Call www.asedeals.com and ask for Brian, give him the part number, and tell him that a GJ member got it for $290 delivered. You should have no problem getting that price as someone else checked with him today and that was the price that they were given too. PM me if you have any issues.
O
ovilla
Plainfield, IL
I would also like to know where this jack is made... Is it marked? Thanks!
Sorry, I don't recall seeing that info on the packaging as I was excited to get the jack out of the box and start using it. Also, when it comes to floor jacks and jack stands, I'm more interested in specs and general design/look/feel/feedback/research and overall gut feel. To be honest, I didn't pay attention to the country of origin when I bought my first jack and jack stands from Sears either. Also, just for the heck of it, I just checked out the sears site and I couldn't even find country of origin info on any of their jacks (even the Professoinal series ones).
e-tek
Saskatoon, SK
I've been noticing many things (esp. tools) are "hiding" the Country of Manufacture lately. You can guess why.... Many items I've looked at say "Imported by...." , to get around having to declare CoM.
Mezzanine
Kitsap, WA
Yeah, I hear you- I am also shopping by reputation and specs, but I will go a bit out of my way to buy American. Realistically, I go further out of my way to avoid buying Chinese. If you get a chance, could you double check to see if the label on the jack itself says anything? Thanks!
C
Snappy
S.E. PA
I just looked at an OTC floor jack. It is assembled in the USA. Does that mean assembled with cheap Chinese parts ? I have an older Lincoln floor jack but it wont stay up. I guess the seals are bad and haven't found anything to repair with yet. :headscrat .....Scott
O
ovilla
Plainfield, IL
Looks like a great jack! :thumbup: It'll really get under the lower cars. I guess this will be added to the collection when the HF low profile leaks...:headscrat Until then... I'll sit back and admire... :bowdown:
Just in case anyone here is looking... I googled it and found this link for the jack for $200... HTH :beer:
http://www.bestbuyautoequipment.com/Ranger_RFJ_3000LPF_3000Lb_Capacity_Super_Long_Rea_p/rfj-3000lpf.htm
That's a great price for sure but too bad it doesn't include freight. I just entered my zip and it looks like it would come out to $282 delivered to my door. It is slightly better than my $290 but I'm glad I'm supporting www.asedeals.com. Brian's been supportive of our GJ site so I'm happy to give him any business we can throw his way.
O
ovilla
Plainfield, IL
Snappy - You bring up a point that is really what drove my buying decision towards getting a Ranger product versus any other jack. Down the road if this jack ever fails me (falls apart or gets a leak) you're damn right I'm going to try to fix it and will be calling Ranger. Since they're basically owned by BendPak, I'm hoping to get the same high level customer service and technical help that I've had with my HD-9 lift and RJ-45 rolling air jack. The replacement part might be free or might cost me something but I'm at least hoping that it will be able to be found and mailed out to me.
malibu101
Walnutport PA
Ovilla- May I ask a simple question?
Does the saddle on your jack lift off to reveal a ~1" hole to drop in other diameter saddles or plates?
O
ovilla
Plainfield, IL
Yes, it does! This was a pleasant surprise to me as it wasn't in the specs and now I've got plans to buy a transmission cradle adapter kit later on that will be able to drop into this hole. On two of my cars I've also got an engine bar that the engine bolts to and then the bar itself gets bolted to the bottom of the car (they're 914's but have the same concept as VW's). Anyway, I've already found that I can line up the engine bar bolts to fall within the hole in my jack and this allows for a very stable lifting point.
Mezzanine
Kitsap, WA
Best Buy Auto Equipment does indeed have free shipping- you just have to spend $250... I just ordered the same jack based on your recommendation, plus a new ranger low profile creeper and a box of gloves. Grand total? $250.42! I am all for supporting someone like the guy you ordered from, but the price difference was just too great. Thanks for the review of the jack though- I am looking forward to getting mine! :thumbup:
C
O
ovilla
Plainfield, IL
C
That's awesome! I like how you threw the gloves into the check out cart so that you could get over the $250 mark. Let us know how you like the Ranger creeper too.
By the way, I also have a Ranger 50' ceiling mounted air hose reel that I really like too. Besides being able to run the full depth of my garage, past the full length of the driveway, and onto my sidewalk, I really like the return mechanism on it - it's very smooth. I'll do a write up on that one soon.
ironroad 9c1
Gum spring,VA
Most of this type of stuff is made by one place and just rebadged for whatever company request it. in the link on the other page that jack looks exactly like the one the original poster put up,better double check and make sure they have the parts , cause I'm sure its not made by bendpack.
Mezzanine
Kitsap, WA
Same jack, marketed by Ranger. No info on who really made it or where coming up in my searches.
C
vette-kid
Navarre, FL
C
I tried to do this too and placed the order. A few hours later I got a phone call from them apologizing that they had put the wrong price on the website and they could not honor that, since it was below cost he said they would lose their vendor status with Bendpak:( Well I was disappointed but I didn't want to cause trouble for him, and I really wanted this jack, so I went ahead with the $290 price. I just got it today and Im glad I spent the money! This has to be the best jack in the world! It fits under my lowered Vette and still high enough to get the tires off the ground in my lifted Tacoma...jacking from the frame! Also the release is very smooth and easy to control, Something I was worried about with the saddle 24" in the air! Great product so far...well worth the $$$:thumbup:
sammerdog
West Michigan
Nice looking jack. Does it have a standard 1" hole under the saddle for slipping ****** saddles, etc on it?
Oops - never mind. You already answered! Sorry.
weicm3
This is the floor jack I have. I think it outperforms this ranger lift. It's longer(41-1/4''), super low profile(1-1/3''), and it holds up 2 ton(4000lbs). It can lift up my lowered car(really low) without using a low profile ramp.
vette-kid
Navarre, FL
thats really low!! Way lower than I need...if your car is that low how in the world do you drive anywhere...Id be stuck on speed bumps (I already scrape some as it is!). Anyway, the ranger jack is low enough I dont need ramps to get it under the vette. And its plenty long enough to reach the jacking points. It also has an extra 4" of lift, which is a factor for my Tacoma. If I gave up that 4" I would barely get the tire off the ground. Thats why I like this jack so much, its truly multi-purpose. Capable of lifting a tall truck or a lowered sports car.
lowceiling
vancouver,bc
nice jack!!!
I need a low profile like that...
need to finish school and find a job and start earning so I can buy toys.
jshillin
PA
I just bought that same Ranger floor jack. I'm really impressed with it so far, lifts my lowered WRX and my Ranger sittin' on 32s no problem.
weicm3
I need a floor jack that low to reach the front center jack point on my m3(bilstein pss9 suspension configured at lowest setting) to lift the whole front end. ranger lift would have no problem lifting from the side jack point but it's definitely not long and low enough for front center jack point.
I also use it to lift up my x5 as well. This ATD lift has a feature(they call it "swift lift") which is nice when you use it on SUV or light truck. It raises up quicker/higher before hitting the jack point.
sainttjames
Houston,TX
Sorry for dragging up an old thread...doing research on floor jacks...
This ADT model that weicm3 references appears to be the same unit as an Omega model...
ADT:
2-Ton Extra Low Profile Service Jack with Swift Lift™
Capacity (Ton): 2
Minimum Height: 2-1/2"
Maximum Height: 20"
Handle Length: 52"
Saddle Dia.: 4-7/8"
Size: 42-1/4" L x 13-3/4" W
Shipping Weight: 123 lbs.
Omega:
Capacity - 2 tons
Minimum Ht. - 2.5"
Maximum Height - 20"
Handle Length - 52"
Saddle Diameter - 4 -7/8"
Frame Width - 13.75"
Frame Length - 42.25"
Weight - 123 lbs.
ASE Deals Link to Omega
ADT link
thehackmechanic
One of my cars is a 1999 BMW Z3M Coupe, which is very low. I have a BendPak MDX6P mid-rise scissors lift, but there are times when I have a car on the lift for an extended project, and a long-reach low-rise floor jack would be just the thing to work on a second car in the garage without taking the one down off the lift.
Like many people, I had a serious hard-on for the AC Hydraulics DK13HLQ long reach low profile jack, but they went from very expensive to no longer available in this country. So when I saw the $290 (shipped) price point of the Ranger RFJ-3000LPF, I bought myself a present.
You get what you pay for. Or more properly stated, you never get more than you pay for.
The Ranger RJF-3000LPF does the long-reach low-profile thing, but that's the only good thing I have to say about it. The jacking action is absolutely terrible in terms of mechanical advantage. I'm 5' 8", 160 lbs, and I need to throw my weight against the jack handle to get the thing pumped up. And coming down, the action is horribly imprecise; you loosen the handle a little, then a little more, then the jack suddenly dumps a lot of air. Because of this, if I have to jack up a car that isn't low to the ground, I'll reach for the battle-axe of a floor jack I bought 20 years ago from Harbor Freight and Salvage.
So, yes, the price is great, and the low rise high lift long reach thing is sometimes essential, but I really almost cringe whenever I need to use it.
