chucklong55
This is my first project since getting my welder working again. I've done a little welding years ago on a makeshift frame table, and aside from doing some body work on a old project, this is the most welding and fabbing I've done.
It's been fun to be able to build this in my garage a little here and there as time allows.
I got the plans to build this from a member on another website (67-72chevytruck) and he did a good job of laying everything out to build this. This works real good for people like me, who don't usually have hands to help lift things. As I start to rebuild my '66 C10, I'll be needing to remove the bed and eventually the cab, so this is going to be real handy for me!
I don't have any build pics of this mount, but there's not much to this. It is used on the cherry picker, and actually stays mounted on it for lifting the cab when needed.
Here's all the pieces cut out, it consists of 1.5", 1.75" and 2" box tubing.
Here's the main beam all welded up, just adding the side receivers and still need to weld on the pipe that will sit inside the mount on the cherry picker
Here's the arms that will slide in and out and allow to lift the bed.
Once I'm all finished, I'll paint it and post pics of the finished product.
