Compressor connection question
Chuckster815
No, this is not another "copper vs. steel pipe" question:). I was wondering where to get the flexible connector that goes between the air compressor and the fixed piping? Where do you buy these and how much do they cost? Thanks.
baugie
Ontario, Canada
I've used hydraulic hose with the swivel ends between the compressor and the fixed pipe on the farm for years....never had a problem. My business relies an having air pressure at all times.
Mezzanine
Kitsap, WA
Your local independent hydraulic and hose shop will make one to your specs, ranging in cost from $4-$40 depending on what you want. I got a 12" long braided SS line in 3/4" with the end fittings I wanted for $25. And I got to help out the local boys. :D
C
Gary S
Bismarck, ND
Yep, the local Farm stores have hydraulic hoses in any length you need, and as a bonus, they use the same 1/2" thread you probably have on your compressor.
kartracer55
Grainger sells braided stainless hoses that are good to some pressure WAYYY higher than you need. I got a 3/4 ID with 3/4 NPT fittings about a foot long for like $30 IIRC. Spendy, but I don't have to worry about it...
e-tek
Saskatoon, SK
I used 1.5 feet of 1/2inch rubber hose and attached my own ends. Cost about 5bucks. Yuo don't need braided.
larry4406
Northern Virginia
I bought a short hydraulic hose at Tractor Supply with 1-inch NPT male ends with a high pressure rating (forget the rating, but much much higher than a compressor). Added a union and was done. Hose was cheap ~$20.
krooser
Waupaca, Wisconsin
Any heavy truck repair shop or dealer can make a hose for you. I use a 2' piece of nylon air hose with compression fittings.... used fittings and 80 cents for the hose.
bgott
Houston, TX.
I saw a picture of a compressor on Craig's List tonight on which they had used a flexible stainless steel gas line between the compressor head and the tank. Any thoughts?
70redbee
Knoxville,Md
Yep that is what I used on my compressor works great. Got it at Home Depot.
Steve in Mi
Mid Michigan
Vibration can cause stainless to work harden, become brittle and subject to failure by fracture. There are better choices - some have already been listed in this thread.
rickairmedic
louisville ,Ky
Chuck I picked up all the copper and such for my new airlines tonight and one of the things I actually grabbed while at Homie Desperate was a 15" braided stainless water heater connector it has 3/4" female ends on it and should do the job nicely for less than $10.00 . They are in the water heater isle in the same area as the gas hoses and electric heater elements :D:D.
Rick
35mastr
Norcal
Not to Hijack,But while on the connection thoughts.What size pipe are you guys using to out fit the shop?1/2" or 3/4"?
I notoiced on my compressor that the plug on the tank is 2" and adapts directly to 1/2".I was thinking of running 3/4.Would there be an issue with the CFM going to the larger pipe.
I have another 2" plug that goes dirctly to 3/4" on hand if it wont be an issue.
Compressor is a IR 15 CFM one.
rickairmedic
louisville ,Ky
George I am running 3/4" through my garage iys really not much more than 1/2" and gives more space for air plus it is large enough it will help release the evil moisture from the air. The most expensive thing I got yesterday and I spent $200.00 on pipe and fittings was the full port ball valves to go inline before the hose reels and also to go at the end of the drops( water drops ) . I am comming out of the compressor with 1/2" and bumping up to 3/4" before I go into my flex hose.
Rick
Steve in Mi
Mid Michigan
I used 3/4 Cu for the main line end to end of my shop and 1/2" on the branches to the side walls that feed both upstairs and down.
If you can get the 2" to 1/2" reducing bushing out and install the 2" to 3/4" that would be the best. I found that a socket and 6' bar would not budge mine, also an IR 5 HP 2 stage. Heat would probably do the trick but I couldn't bring myself to scorching the new paint. :) Hope yours is easier to get loose. So with that 1/2" restriction I immediately increased size to 3/4" and tied the compressor to the piping with a 3/4" hydraulic hose.
mad57
Rick
good idea, is it rated for 175 psi ?
rickairmedic
louisville ,Ky
MAd I dont know for sure but My system doesnt run over 135 LBS anyways and I am quite sure its rated for at least that . I will do a little research real quick and let ya know :D.
Rick
35mastr
Norcal
I am going to try to get that plug out and put the 2"to 3/4 one on.I finally got it to where it need to be in my shed.I made up 4 4'Uhmw round pads for the feet.
I rolled it over by hand to make sre that there was no oil in the head.
Then I ran my welder cord to the garage and plugged it in.It runs like new and not all that noisy either.I was suprised.
I ran a die grinder wide open thinking it would **** it right down.It held at 90 PSI and still had all the CFM to run that tool non stop.I was impressed.
This is the only compressor that I have ever used that the air comes out hot.It was not all that warm out yesterday either.In the 60's with a crisp light wind.
All of the ones that I have used over all these years are usually cold.Especially in the winter.
Is this normal?
Steve in Mi
Mid Michigan
Rick
Rick these corregated flex SS lines are designed to take-up any misalignment or fit-up problems on a water heater install. I stated above some concerns about its use in a situation where there is continuous flexing caused by vibration. The commerical/industrial flex hoses with SS braid on the outside are a different animal entirely and generally much more costly. Even if what you bought is rated for the pressure will it take the vibration?
If you have a TSC (tractor supply) store near you they will have hydraulic hose all made up good for the pressure and vibration and very reasonable. You don't need but about a 1 - 2 foot hose to stop the transfer of vibration. A hose of this length and even up to 3/4" should be less than $10.00. You can order on-line but then there might be the added S&H, sometimes S&H is free or $4.95. I don't mean to be pushy, just concerned so I suggest this other option - you decide.
rickairmedic
louisville ,Ky
Steve what I got was a braided stainless water heater connector not the corregated type . I dont even like those on water heaters as there is no reason for missalighnment on a water heater if you cut the pipes right and prefit before soldering things back up :D. I dont even like using the corregated flex gas lines on water heaters or furnaces furnaces especially since you can get a slight vibration from a furnace as well.
Rick
Steve in Mi
Mid Michigan
Rick
Okay, your thinking it thru. The hot water heater connectors also take-up the expansion and contraction from thermo cycling. Sometimes a replacement tank may not be the exact height or diameter of the old one so the flex connectors can sometimes solve a problem w/o pipe modification plus they provide the clearance needed to move a tank in and out of position. Anyway 60 psi water is much different than 150 psi air. The inner core of the braided SS hoses can be of different materials - I have some that has a teflon core.
BTW, the OP hasn't come back.
dustym
Sultan
braided steel from TP tools.
