A crooked playhouse for the kids
Jack Olsen
Los Angeles
All of this was documented in the 12-Gauge Garage thread. But a couple of people asked that it be broken out separately -- so here it is.
For a week (and a day) in December, I worked on a playhouse for my two kids.
The genesis of the whole project was to find a new base for our front-yard slide, which was getting rotted from exposure to the elements. My father-in-law had given us the slide itself. And since he passed on a short time later, it was important to my wife (and me) that we find a way to keep using it. She suggested a playhouse, and I decided to try to do a 'crooked house,' like you might see in a kids cartoon.
My 3-year-old daughter offered this picture, which has the basic elements: two windows, a roof, some steps and a slide. It ended up being all I had as a basic plan:
The first step was easy. Max and I got some In-N-Out burgers and stuck four stakes in the ground where we wanted the corners to go. Then we used cardboard sonotube and some concrete to make footings for the thing to sit on.
This is the base. It's made with pressure-treated 2x6 lumber. The plywood on top of it got coated with Thompson's Water Seal on both sides and (especially) the edges. The first piece of good news was that the concrete footings came out perfectly level.
Framing is strange when the walls are deliberately at an angle. And I really don't know the first thing about framing. I know I should have headers and footers and closer spacing, for instance.
Here's the basic shape. It finally looks a little bit like a house. The fact that it's deliberately crooked might be lost on my neighbors -- they might simply be assuming I have no idea what I'm doing -- although they have all been very polite and encouraging about it so far.
I'm using plywood gussets and coated deck screws and so far the thing is coming out more rigid than I expected.
Once the frame was up, I had to get the wood for the walls and the roof. I loaded 10 4x8 sheets on top of the Jeep and used a ratcheting tie-down to keep the load from moving.
Here you can see a test panel for the roof and the beginnings of the 'loft.'
I needed one set of stairs for the loft and another set for the slide, but didn't want to give up floor space. So here's the one 'Jack Olsen idea' in the whole place: I turned the wall joists into ladder-type steps for both the slide and the loft. The bar up above the loft is an old broom handle -- a way to pull yourself up and over if you need a little help.
J
Jack Olsen
Los Angeles
My idea was to have the old slide come out of a 'dormer' type opening. I've never done anything like this before, so working out the angles was a little tricky. (Wish I'd taken the time to learn Sketch-Up.)
Figuring out how to cut the roof opening for the dormer was also interesting. Sketch-Up aside, there are days when you wish you could simply remember some grade-school math.
I was surprised how sturdy it came out. I was able to use the dormer framing like a ladder to climb up to see if I could shake things by standing on the roof. I don't know if it makes a huge difference, structurally, but the deck screws seem to hold things more firmly than nails.
All these weird angles produce some particularly useless scraps.
Here's where I got on day four.
Short day on day five. But I got the dormer roof finished and the cut-outs made for what will become doors and windows. I've got to get the walls painted before I can put on the window, door and other trim. So that'll come next.
And here it is finished. It ended up taking a day longer than the week I'd hoped for. But now it's got paint, windows with wooden blinds, a (Dutch) door and an El-Nino-ready roof. But more important than all that, the kids are finally able to play in the thing.
Here's a Wizard-of-Oz-inspired detail on our drought-ed grass:
J
Jack Olsen
Los Angeles
First interior issue. My daughter is taller than the space under the loft. So while she'd try using the little play stove -- it meant her head getting bumped.
The solutions was to cut the back of the toy at an angle so it could use the space left by the wall moving outward. Look closely, and you'll see the wall stud going into the stovetop burner. Probably not a wise way to go with a real kitchen appliance. :)
Now the floorspace trade-off is not much more than the width of a 2x4.
Next, I put in a floor on top of the plywood. It's just vinyl. But it only set me back $36 and it should hide dirt better than the plywood did. It's supposed to look like rough-cut driftwood:
I sewed those curtains, too. :p
Another shot that shows both the blinds and the flooring. I don't know if I'd use either in my house -- but this is a playhouse:
I still have to clean up and repaint that table set.
One final little detail -- a sign holder for the door -- ended up with a trip to the ER after an incident with my table saw. It's documented here.
Even though it's finished, I'd be interested in any criticism or other input on the project. I don't expect it's going to last for decades, and it doesn't need to. But it should do better than the unprotected base we used to have for the slide. The roof has already held up well to a few rainstorms, and the wood base of the thing sits on spacers on the concrete. I'm not sure what its weak points will be, but of course time will tell.
mires
Columbia, MO
Seriously cool Jack. I wondered if there would be a thread about it after seeing your post about the digit mishap. It came out really cool in the end and I'm sure your kids will use and enjoy the heck out of it. They're lucky to have a dad that will go through all that trouble for them to have a "place of their own".
ChevyEFI
Phoenix, AZ
At first when reading, I understood the loft and slide access would be a combined platform. Then based on pictures, I assumed access to both would be via the opening facing the camera, which later was closed. Boy, was I confused until I continued reading. :)
The slide access taking no room from the interior panned out nicely. I'm a little uncertain the loft will get used though. And being sensitive to things being shorter than I am tall, I kind of feel like maybe a set of elevated, left and right cabinets would be better than a loft.
Overall, great execution. When you visit Frank Lloyd Wright's architecture work and school(s) in IL and AZ, you learn some of his practices and teaching as it pertains to space and psychologically moving people through a structure. Along that thinking, I think the canted walls are great to add space to a small structure.
Now I'll let your work sink in and contemplate what ideas I might borrow towards a treehouse for our boys.
kingchevy
Pretty cool. Is it just the pictures, or do the angles make you feel dizzy inside?
Pardigital
NKY
This is totally awesome! I built a 6'x8' for my daughter a few years ago, but never quite finished the interior before using it for storage. I keep meaning to get going on it again, but my garage build is taking most of my spare time at the moment. Great job and thanks for the thorough post. :)
J
Jack Olsen
Los Angeles
Thanks!
I think it's the camera. I have a wide-angle lens that I used for that, since the interior itself is so small. But it creates a kind of fish-eye effect.
rlitman
Long Island
Well, clearly your architect was an amateur, but still, I'd call her a visionary, and think you should pay close attention to her future designs.
BRILLIANT execution of an inspired design! ;)
Thumper68
Duluth MN
Very nice. From experience building something crooked is much harder than building it square and plumb.
ilovevocs
Toledo, Ohio
That is awesome!!! I might have to steal that in a year or 2 when my 2 week old is a little more mobile!
Start on it now so you can have it finished before he's in high school. :beer:
I'm joking, but seems like when my daughter came I had all these great ideas of things I was going to build for her. Free time? What's that again?
Again not speaking to you personally, I'm sure allot of other guys can associate with my feelings.
Pathfinder
Newbury, MA
Jack - No cringing, just fascination at your attention to detail. Your play stove solution is ingenious. I even like the surreal effect of the wall stud bisecting the cook-top. It kind of compliments that Wizard-of-Oz thing.
The plywood gusset connection of the rafter to the stud is spot on. You have created a moment connection there and it adds tremendous strength to the structure.
The most important structural element in the entire playhouse is the inner most floor joist of the loft. It is acting as a tie that keeps the building from spreading. The connection of the floor joist to the rafter and stud needs to be strong. I see you have achieved this with an over-sized gusset.
You have a rare talent Jack. And a natural sense of how things should go together. I have said this in the table saw post, but after seeing more of the playhouse I'll say it again. Well done Sir!
John Minton
fourjeepin
Atlanta, GA
Yah, very well done, though we have come to expect no less from Mr Olsen. Looks like you spent weeks planning, then built it.
Being in California, I would expect that you would need to apply for a permit, variance, inspections, and then be rewarded with a higher tax bill. :)
FTG-05
TN
Wait, I got lost on the 2nd pic: What do the inandout burgers have do with setting stakes?
And who is Max??? The construction supervisor?
[beer]
(Oh heck someone tell me what the dang gun beer icon is here!!!)
mdbeck1
Norman, OK
[beer]
I've read about it on Jack's main thread (and have followed his main thread for several years) or was that the "What did you do in your garage" thread so I think the answers are:
In and Out burgers... I think it's a local burger shop.
I don't think that the burgers don't have much to do with actually putting the steaks down but I'm guessing that it's like grabbing a beer and looking over the project and deciding where to start.
Max is his son. I guess he's probably part construction supervisor?????
The beer icon is: :beer: you can find it by using the "Advanced reply" and looking at "more". ...or just type in a colon the word beer and another colon.
J
Jack Olsen
Los Angeles
John Minton
Thank you! That means a lot to me, since it shines a light on how my engineer father let me fail (again and again) at building things when I was a kid, but kept encouraging me to keep trying -- he knew I'd get a better broad understanding from discovering what worked rather than simply following instructions. I wish I were better at this sort of thing, but I'll admit that I've had some good luck with getting through projects where I didn't have nearly enough experience or training.
And for what it's worth, the roofing and overhangs all worked very well through the 3 inches of rain we got this week.
Looks great!
Did you spray the inside or brush all those nooks and crannies?
I did it with a small roller and a brush. What amazed me was how many times a guy can hit his head against pieces of the roof in a crooked space like this. I kept thinking I'd 'trained' my brain to miss the obvious head-bumping hazards, and then I'd get another knock and a splotch of latex in my hair. :dunno:
Max is my 7-year-old son and he decided how we'd get started, which was fine with me since it was lunchtime. :)
And yes, it IS a different green from the garage. It's the same as my other T1-11 project, the storage shed I built 7 years ago.
Family resemblance?
gearhead1
NC
Beautiful work. I enjoy this kind of stuff also. Even though it's work, to me it's far more relaxing than watching TV.
sqznby
Coastal NC
Awesome, my daughter would love that, haha and all the neighborhood kids to.
Another creative Jack Olsen structure, nice.
