Milwaukee M12 Ratchet - 1/4 or 3/8 drive?
paulsomlo
Northern Colorado
About to make a purchase, interested in hearing from people that primarily use the tool for automotive work. Which size is more appropriate?
johnny5c
I went with the 1/4" because I thought it be better for tight spaces like rear manifolds and under dashboards.
DanInVA
I have a 3/8 version that I got a deal on, but I would have preferred if it were in 1/4. It is a really handy tool, but it doesn't put out nearly the power that I would expect from a pneumatic 3/8 ratchet. I would say that its power is more in line with a pneumatic 1/4" ratchet, which still makes it a very handy tool in its own right. To your point, it seems to me that if you have to treat it like a 1/4" drive tool, it would probably be more appropriate to buy it in 1/4".
Sent from my SM-G920V using Tapatalk
Fedwrench
Valley of the sun
I have both versions and I use the 1/4 one the most. It's really a light duty tool and with having 1/4 drive sockets up to 15mm, I feel it performs best in 1/4 drive.
Thedave1164
I have the 3/8 and it comes with a 1/4 adapter.
That is the reason I haven't bothered buying the 1/4 version, it is the same size.
ImStricken06
Within Range
They are not the same. The 3/8 has 35ft lbs of tq, while the 1/4 only have 30ft lbs of tq. I chose the 3/8 due to having more sockets of that size than the 1/4. Also, i use 3/8 sockets more often than the 1/4. If i ever need to use 1/4, ill just use an adaptor.
Check out my review on it:
kblee27
Singapore
I bought a 3/8 drive one. It has slightly more torque, more useful I think.
And most of my sockets are 3/8". If ever 1/4" is needed, then just use a adaptor.
shockwave
Marietta,ga
I have the 1/4 and use it the most the 1/4 sockets tend to get into tight spots the 3/8 cannot just don't try and loosen a 70ft ibs bolt by hand with it
I do like the snap on over the Milwaukee the head is built a lot better but taller and not as easy to get into tight spots
dacan23
RI
Like many have said I have the 3/8 and just use an adapter if needed, want to add the 1/4 also but is it worth it to me since I havent run into a clearance issue... Love the tool BTW, use it every time I'm working on one of my cars.
P
paulsomlo
Northern Colorado
Thank you all for responding.
I noticed the difference in the torque spec between the two drive sizes. I looked at the service parts diagram, and other than the anvil, all other parts appear to be the same, so I'm not sure why the difference. In fact, I think that the different size anvils can be swapped.
At this point, I'm in waiting mode - Home Depot is out of stock on the M12 Fuel 3/8" impact/M12 ratchet combo kit (either drive size), and I've got $125 in HD gift cards to use.
ImStricken06
Within Range
i opted not to get the combo kit. i bought the bare tool, and a 2.0 battery for $150. it was $10 cheaper than the combo kit. (i already have a m12 charger spot in the m18 charger base, and i dont need that flimsy cloth case.)
nevertoomanytools
1/4 for sure
On top of me using 1/4" drive more the 3/8" ratchet has pretty much the same amount of power. the 1/4" is just about perfect for most 1/4" drive sockets maybe even a little weak on the larger ones. I'd imagine the 3/8" would be pretty underpowered for most bolts you'd use a 3/8" socket on.
MrGiggles
3/8.
I always have 3/8 sockets out, hardly ever 1/4. I don't want to have two sets of sockets to sort through on a project.
jlipsky14
Northern NJ
I just purchased one in 3/8 as that is the size I use the most. I almost never use 1/4. I have not had a chance to put it to work yet.
areyouanywhere
I have a 3/8 head in mine but also have the 1/4 head which I will probably be putting in. For the fasteners I use it for 1/4 should work fine, and also it should be easier to access certain fasteners with a 1/4 extension and socket.
1/4 advantage- socket/extension is slimmer, easier access to some fasteners
3/8 advantage- stronger... less likely to twist the anvil off.
I think the 3/8 has more power because the anvil being bigger is able to transfer more torque... or something like that.
ihateminimumwage
I run the 3/8" daily. Holding out on a 1/4" until they have the technology to build one the size of my mini Cornwell air ratchet.;)
Ign
Butte Peak ND
I've had the 3/8" for years. Just got the 1/4" and am surprised how much more I use it than the 3/8".
Skin
Boston
They are the same. The torque increase comes from better torque transfer due to the beefier anvil which is the only difference. The same trick is used to market 1/2" compact impacts as slightly more powerful than their 3/8" counterparts.
P
paulsomlo
Northern Colorado
Right you are - I sent an email to Milwaukee asking why the difference, here's the response:
