1942 Arm & Hammer Anvil Refurbish and Stand Build
PWRstroke_smoke
NorCal
1918 & 1942 Arm & Hammer Anvil Refurbish and Stand Build 208lb and 65lb
I wanted to post up the refurbishment of my Arm and Hammer anvil as well as the stand I built for it.
208lb
Its a 1942 from the serial numbers reference in the book Anvils in America.
The two steam hammer forged parts of the anvil were arc welded together at the factory and the hardened steel face was forge welded on.
Arm and Hammer Factory ceased anvil production in 1950 with approximatly 52000 Arm & Hammer anvils made.
The stand was made out of Power pole cross beams and bolted together with 1/2" all thread rod.
railroad track hold downs keep the anvil from moving side to side and railroad spike hold it tight to the surface of the stand
The hammer holder is a control box mount for a railroad terminal box made by wrrsc (western railroad supply co)
IMAG0081_zpsv9yks8k8 by PWRstroke_smoke
IMAG0084_zpsnbthoxoa by PWRstroke_smoke
IMAG0085_zpsoli3hxgk by PWRstroke_smoke
IMAG0082_zpsfc5qstwc by PWRstroke_smoke
P
PWRstroke_smoke
NorCal
P
PWRstroke_smoke
NorCal
Monkey Milk
Hawaii
hmm, I got two that looks like that but they say VULCAN on the side. Maybe vulcan bought the rights? Looks good. Did it crack and got welded up?
P
PWRstroke_smoke
NorCal
I believe Vulcan was it's own company, they had cast bodies and a similar style hardened face plate. the weld was how they made them from the factory after 1940 they welded the top and bottom hammer forged pieces together.
RustnGrease
Schuylkill County, PA
Wow, the face on that looks perfect. I used a similar design on my stand, should serve you well, also great idea using the RR pieces for tie downs, i never thought of that.
ZRX61
Solar Blight Valley, SoCal
If that was mine I wouldn't be able to resist firing up the welder & grinder to make the original weld *disappear*. I'd probably also have a go at the underside of tail.
Jazz1
Thunder Bay On.
Thats a great looking anvil. I had not seen that brand. Good idea on the stand. I used rad supports from old truck to anchor my anvil to a piece of lumber. Secures anvil as well makes it easy enough to drag around shop instead of "walking" the whole unit.. I can also swing the supports down to lift anvil off.
Interesting hammer holder...good to see things repurposed as opposed to running to HF to fill the cart.
drivesitfar
Smoke: I'm curious how the rebound is on your anvil since the body was broken and brazed back together about half way up from the feet. this might have been the weld/braze that Milk was asking when you said the top was welded on at the factory.
i'm guessing that weld wasn't done by you because it looks pretty old.
nice looking stand anvil combo and can you take and post another picture of the hammer's holder with the hammer out of it?
thanks
P
PWRstroke_smoke
NorCal
Very nice hold down system I love it. Everyone comes up with their own unique ideas for strapping an old anvil down!
P
PWRstroke_smoke
NorCal
thanks
That weld halfway up the middle from the feet is an arc weld done at the factory. That is how arm and hammer merged the base and top of the anvil.
With early arm and hammer anvils the top and bottom half were forge welded together later anvils were arc welded together.
The top hardened steel face plate is just forge welded on, Im not sure i they do that before or after the two halves were arc welded together.
the gouge marks on the underneath side of the heal are the left over forge marks from the steam hammer forging.
rebound is over 90% on this one.
drivesitfar
PWR: i had no clue that a new anvil would have that braze or weld across the middle of it when leaving the factory. thanks for the old picture too that i saved to my laptop.
Black Frog
The confusion between Arm & Hammer and Vulcan anvils comes from the use of the very similar logo of an arm holding a hammer. The similarities end there.
They are two completely different companies. Vulcan was made by Illinois Iron & Bolt Co. in Carpentersville, Il. The were made similar to Fisher anvils, cast iron body and steel face. But the Vulcan steel face is much thinner, and generally considered to be a lower-quality anvil. You find many of them really beat up. The cast logo on the side is raised above the surface.
The Arm & Hammer anvil is a very high quality wrought iron anvil with a forge welded steel face, made by the Columbus Anvil & Forging Co. in Columbus, OH. They did not make the numbers of anvils that Hay-Budden, Trenton, or Fisher did, but they are just as high quality. You'll find a serial number on the front foot of A&H anvils. The logo is stamped into the surface of the side of the anvil. There were at least four different A&H logos used at different times.
Vulcan anvils have no serialization.
I have lots of advertising from A&H through the years, and even a few photos of the actual plant. :)
greenbikemike
Twin Cities,Minnesota
Real nice,like the stand,I've been looking for an anvil,my dad had a railroad "homemade" one,I'd settle for that right now.
So I've been looking and I saw 2 Arm & Hammer anvils on Craigslist the other day,listed as big and heavy,they looked to be good shape and very similar to yours,$75.00 each! I did a quick search and TRIED to jump on them....gone...I have to get up earlier.
Nice setup....
Greenbikemike
P
PWRstroke_smoke
NorCal
Nice! I really like the stand too. Great job!
Phil
Thank you!
your welcome glad you enjoyed the old advertisement.
Great post, PWR!
Thank you!
Great Info BlackFrog! Thanks and if you feel like sharing some of your old advertisements that would be much appreciated.
Nice setup....
Greenbikemike
Thats is a very good price!!! they never come up that cheap here and if they do they only last minutes on craigslist.
Black Frog
A&H anvils are a high-quality tool, but they did not spend the time finishing them as nicely as Hay-Budden or others. For example they left noticeable steam hammer forging marks on the underside of the heel. Why spend the time (equals cost) finishing that when no one sees it, and it doesn't really serve a useful purpose? They provided the customer a top quality tool at an affordable price by not doing the unnecessary steps.
Here's an earlier ad from 1902, very "no frills" and basic.
P
PWRstroke_smoke
NorCal
Thats a great ad! I actually kind of like the steam hammer marks. The character of each anvil is so different and the marks just add to that unique character of the arm and hammer.
Columbus Anvil Sept 1916_zpsfsw9giqj by PWRstroke_smoke, on Flickr
IMAG0090_zpslksknfiu by PWRstroke_smoke, on Flickr
Black Frog
I have had many anvil company signs made up based off of old advertisements, and then "aged" to look old. So based off of the A&H concept of no-frills, just a quality product, I designed this sign layout for A&H. Like I mentioned they had several different logo styles through the years, this composition uses aspects from a few different ones. Basic, plain, but cool. :)
Enjoy your A&H! They are a great anvil, and if used correctly will be around for another few lifetimes of use.
P
PWRstroke_smoke
NorCal
Wow that is so cool, I would love to have one of those made. Nice work!! A smaller version of that would look great hanging on my new hammer rack
greenleaf4902
The base of a Arm &Hammer anvil is not in anyway forged. These are cast of an inexpensive steel. That is why they exhibit the familiar casting lines of the sand mold.
TailGunner3000
New Jersey
Their own advertising clearly says "wrought," which is forged, not cast. Also iron, not steel.
What are you basing your comment on?
greenleaf4902
There is a book about anvils . Do you have it?
The base of the anvil is cast. And obviously so, by looking at it.
The body of the anvil is forged from wrought iron. The body of an anvil is not the base. They are two entirely separate components. If you have the book, and read it, you would know that.
Here is a picture of the chapter Arm &Hammer Anvils. Discussion of the A&H base. Trenton anvils did the exact same thing.
Maui
Upstate NY
This looks right. I have a 100+ lb Vulcan anvil (cast) and had owned an 150 lb Arm and Hammer anvil (wrought). They are very different anvils. The Arm and Hammer came with an original cast iron stand which I fortunately decided to keep. I’ve never seen another one of these stands anywhere, including the internet.
steaks&anvils
Colorado
This is GJ, we need pictures of your stand. I'm sure you posted somewhere already, but we want it here too!
