The new Church of higher RPM
Big Dad
S.E. South Dakota
Long story short
Moved home a couple years ago to be closer to family,step dad died and left mom alone @ 84
After a extensive search , found no places with garage anything near like I wanted so ..
Bought a nice older home and knocked this down
Big Dad
S.E. South Dakota
That building from the outside looked kinda good, it was all stucco and everyone thought it to be a wood structure but ..nope
It was clay tile all covered up , one touch with the back hoe and it it fell into a pile of rubble
Squankum
Southeast
So now you park your cars on a patch of dirt?
Just kidding. I'm sure more, cooler pics are coming. :thumbup:
Big Dad
S.E. South Dakota
I started in May 2015 making calls to get the building down and hauled it away, it finally went down Sept 6th
Then, on to getting a pad poured
32 x 38
Big Dad
S.E. South Dakota
The concrete got poured Nov 15th
Took 100's of calls, lots of "too busy" and "can it wait"
Lucky the weather held all i can say.. found one guy that told me the truth and showed up as promised
RangerSVT
Rochester, NY
Brrr... cold time of year to be starting a build! Sounds like a nice size garage. Looking forward to following the build.
Big Dad
S.E. South Dakota
Tried to get it done sooner but ..
So many people promise to show up and don't it is just one set back after another .
It should be close to enclosed by next week , we have a nice January thaw headed in .
And, maybe by March(ish) move in
Squankum
Southeast
Wow. You've got to be tough to work on it at this time of year.
Well, on the bright side, I guess you don't get much freeze/thaw cycle there? Not much mud or slush.
Big Dad
S.E. South Dakota
10 months of winter and two where the sledding is bad :eek:
Typical , End of Dec, Jan(sux) Feb can be either crappy or nice, March, snows but warm(er) most often
End of April, May, June, July, August, Sept beginning of October are all nice
Trusses are up
https://scontent-ord1-1.**.fbcdn.net/hphotos-xpf1/v/t1.0-9/12472683_10208640813767580_2814976654519551947_n.jpg?oh=fce7ee2b4ed872267fec149532d55e3e&oe=5746D3C0
jwhcars
Central PA
Makes me cold just looking at those guys working.
Looks like you will have a nice garage when finished.
Big Dad
S.E. South Dakota
Roof deck on, most of the walls are enclosed or , will be soon
https://scontent-ord1-1.**.fbcdn.net/hphotos-xtp1/v/t1.0-9/12472396_10208648295794626_4776153132741051900_n.jpg?oh=b7bafec9b574e5be7d692391e0d8b8f8&oe=57060A0B
Big Dad
S.E. South Dakota
https://scontent-ord1-1.**.fbcdn.net/hphotos-xfa1/v/t1.0-9/12512827_10208648309114959_8812627979516260429_n.jpg?oh=d035069956bc92bc6dce3e0f2c10e6f3&oe=5733F44C
Big Dad
S.E. South Dakota
Few new updates, garage door opening is trimmed out
https://scontent-ord1-1.**.fbcdn.net/hphotos-xfp1/v/t1.0-9/12643008_10208686129300440_2913736920654111629_n.jpg?oh=cc430f00853068abd29e87e738e0b057&oe=57489AE5
Big Dad
S.E. South Dakota
One window is in
https://scontent-ord1-1.**.fbcdn.net/hphotos-xap1/v/t1.0-9/12549016_10208686136540621_3314624541808020978_n.jpg?oh=7719af352cd85a7196166d471872877d&oe=57351D4D
Big Dad
S.E. South Dakota
Walk in door is in
https://scontent-ord1-1.**.fbcdn.net/hphotos-xft1/v/t1.0-9/12642657_10208686149380942_775989018898661332_n.jpg?oh=80f37e8b271b268c37f9c0cb278a17c4&oe=5731D1E3
Big Dad
S.E. South Dakota
he did not use the vented material here , he said he was going to do it where the gables are
Not sure if it matters but, he said he would change it out how I preferred
Does it matter ?
https://scontent-ord1-1.**.fbcdn.net/hphotos-xft1/v/t1.0-9/12642876_10208686166861379_5633699826394757501_n.jpg?oh=beacbac0056c1a527b18477879537ad5&oe=572A0895
COSMOS
Phoenix, Az.
Big Dad, if you were to have a fire inside with the door open the vents you want at this soffit would draw the hot air and fire into the attic space. The fire code where I live does not allow soffit vents above windows and 24" in a vertical plane to either side.
Firebird 1
Maryland
vented soffit should be on the eaves. This along with baffles between the rafters, and a ridge vent will allow ventilation to the roof. Vented soffit on the gable end does absolutely nothing. If there is a fire, I dare say the vented soffit will have no effect on anything.
Big Dad
S.E. South Dakota
Ok, well I seen it and questioned him and he said his way would be fine, then after 10 minutes called back and told me he would change it
everything I have read says do it that way
COSMOS
Phoenix, Az.
vented soffit should be on the eaves. This along with baffles between the rafters, and a ridge vent will allow ventilation to the roof. Vented soffit on the gable end does absolutely nothing. If there is a fire, I dare say the vented soffit will have no effect on anything.[/QUOTE]
The UBC fire codes states otherwise, appears he is in a rural area with little or no inspections.
Are you installing drywall or any sort of panels on the interior ceiling.?
Big Dad
S.E. South Dakota
Siding going on today
https://scontent-ord1-1.**.fbcdn.net/hphotos-xaf1/v/t1.0-9/12651365_10208693601447239_6000771671925979599_n.jpg?oh=bbd8a6447bd3fa16a03df12f8faaf73b&oe=573C88BA
Big Dad
S.E. South Dakota
https://scontent-ord1-1.**.fbcdn.net/hphotos-xtf1/v/t1.0-9/12417624_10208693605687345_2097353733212683532_n.jpg?oh=51e763889cb73d3fdd5b676b9f780be0&oe=5739B7F1
Big Dad
S.E. South Dakota
2 of the 3 doors made it , one on backorder until next week ..great
https://scontent-ord1-1.**.fbcdn.net/hphotos-xpt1/v/t1.0-9/12553083_1203856952972801_7916102822224464692_n.jpg?oh=b4f939433a51af87f07cd9ff077d2f18&oe=5726866B
Big Dad
S.E. South Dakota
https://scontent-ord1-1.**.fbcdn.net/hphotos-xap1/v/t1.0-9/12573120_1203859839639179_3647544441537076438_n.jpg?oh=63eece1c3caea754d69407c01aa2e25f&oe=5747D638
Big Dad
S.E. South Dakota
south windows in and half of shingles done
https://scontent-ord1-1.**.fbcdn.net/hphotos-xat1/v/t1.0-9/12573209_1204551956236634_1974319228381429012_n.jpg?oh=f0c66cd08bd7014232aa7a74c6edb830&oe=57329351
