bareass172
I'm somewhat at a loss here. I snagged this charger for electrolysis and have been trying to run something with it and having no luck at all. After a week of fooling with the electrolysis and having very poor results I'm starting to think the problem is the charger. Not to say I'm perfect, but I read extensively about electrolysis and have modified my rig over and over to eliminate possible problems - I truly believe it's the charger. Unfortunately all I read online, even many posts here, say test it by hooking to a battery and check back later with no further details.
I tested and I'm getting ~12V out of the charger. But when I check for amperage under load I see much less. Even on the 10A setting I was only seeing ~.3-.4A. I checked this with an inline meter (on the 2A setting) and confirmed with a clamp meter on the feed line before the transformer (where the built-in gauge checks also). I realize the AC feed line won't show 10A, etc, but more than .3A would be expected.
All the diodes test good. I broke loose all connections and cleaned them with contact cleaner to be sure it wasn't a corrosion issue. I cleaned and even soldered the wires to the alligator clips to be sure corrosion wasn't an issue there (there was a lot of corrosion on the neg terminal). I don't see any continuity from the coil to ground so I don't suspect a short.
My understanding is that these are relatively bulletproof and if they do fail they are fixable. I would love to figure it out and get it working. I am electrically inclined and have good test tools, not to say I can't be taught, just to say with guidance I should have all necessary testing tools.
I'll explain down here what it's doing during electrolysis in case that matters... I hook it up to my rig with a clean sacrificial rod (rebar) and it works beautifully for about 15 minutes and then the amp gauge drops completely. I pull the rod and it has very slight surface rust on it, but unless I wire wheel the rod clean the amperage will not go up again. So it's working, but barely. This is why I suspect I'm just not getting enough amps out of it.
As always, thanks in advance for any advice and help.
