Base slots on a drill press. What are they for?
skipnay
PA
I'm wondering why they put slots on the base of a drill press? Maybe it's just me but can't think of a reason other then their isn't a reason!!! I would say I guess you could bolt weights to it. :mad: For what reason? Pictures might help me....
1991Syclone
Englewood, FL
Well, there's this for the table:
But I think he means the very bottom base, not the table. I suppose it's so you can anchor it to a stand.
zmotorsports
Northern Utah
The slots in the BASE are there for fastening/clamping/jigging longer items to that won't fit between the table and the quill. The table merely swings out of the way and you mount your work to the base. I don't think it is anywhere near as common as it once was but drill press manufacturers still put them on the base.
Mike.
Big Pete
I've used them to clamp big stuff down to. I bored out a motorcycle swingarm pivot by bolting it down to the base of the drill, no way was it going to fit in a vice.
skipnay
PA
Thanks guys. Yes I was talking about the base and not the table!
jmarkwolf
Southeast Michigan
On a floor standing drill press, there can be nearly 4 feet between the quill and the base.
Still not clear on the practical use of those slots in the base on a floor standing drill press.
OccupantRJ
Eastern North Carolina
If you need to drill a hole in the end of a railing ballister or the like, it can be stood up on end and clamped or bolted to the DP base by whatever fixturing one can come up with.
speed bump
Butte Montana
We had some jigs that we bolted in those slots for locating the parts. Not having a lathe it was also convenient for drilling and tapping long parts.
ovrrdrive
Central Florida
I use the slots on the table for bolting a drill press vise on. I use the one's in the base for bolting the drill press to my home made stand...
CJM8515
Its the same principle as the table, you move the table out of the way and can mount a clamp to the base. Its for longer objects.
Ign
Butte Peak ND
It's called Z-space, and if you're a machinist it's nearly the holy grail. I put a 4" riser block on my Bridgeport to gain, well, just 4" of Z.
One of (but not the only) the primary reasons machine shops keep a DP around is because it will have a lot more Z-space than any vertical mill.
Provincial
Near Salem, OR
Has anyone bought these? T Slot clamping kit
I haven't used that particular brand, but I have used both high-priced American and low-priced Asian (including Harbor Freight) versions of the same thing. All do the same basic thing, which is clamp the work firmly to the table. I had to rework the HF set a little, since the threads wouldn't spin together with my fingers. The threads were very hard, and I believe the studs are very strong and wear-resistant. All the other parts were very hard, as well.
Unless these aren't properly heat treated, they should hold up in a home shop environment.
zmotorsports
Northern Utah
Exactly. Sure glad I had my 20" floor mounted drill press last week when a Borg Warner T-18 transmission housing wouldn't quite fit in my mill and I had to drill and tap some holes for a Novak adapter that I was mounting for a client.
Mike.
