Socketry sizes and styles - what would be your top pick?
ToolRoom
UK
I'm slowly upgrading my sockets and added in some 3/8 (not really a common drive system here) and I'm curious as to what sizes, styles and overlap everybody uses a lot or finds useful.
For example, where does your 1/4 drive end and your 3/8 or 1/2 start? Do you ever really use all the sizes you bought? Preference for 6 point over 12 point, have both, or just in certain sizes?
As a confessed toolaholic, I have a compulsion to have all the sizes in all the combinations, and surely everybody must have different needs - but if you were starting over what would you honestly actually buy again? (Keeping brand out of it for the sake of impartiality)
I don't think I've ever actually used my speedbrace, or a 9mm socket (although it is still indispensable for hammering over a well rusted 10mm bolt when all else fails). I couldn't live without a set of 6 point deep 1/2 drive sockets.
Just interested in opinions.
gdocktor3
Connecticut
I have all sizes in 6 and 12 point, deep and shallow, in all drive sizes. Even my 3/4" drive stuff goes down to 7/8" and up to 2-1/8". Then my 3/8" goes 1/4" up to 1-1/4" and 1/2" drive goes 3/8" up to 1-1/2". My 1/4" only goes up to 5/8". Metric is a bit different as I don't use them much, but there's a couple over laps. Each drive has its uses. May need a 1/4" socket to use with my Dewalt 1/4" impact driver, but then that same size in 3/8" to fit torque wrench. Just an example. Plus I'm an addict and like to have as much stuff as possible because, well, you just never know when you'll need it.
JJThrasher
Indiana
My 1/4 goes up to 12 or 13 mm. 3/8 runs 6 to 21 mm. 1/2 goes 10 to 38 mm. 3/4 starts at 3/4 and goes up.
3/8 is probably my most common used size. Covers lots of engine work, light duty brakes, and some interior work.
shockwave
Marietta,ga
Honestly 1/4 drive I usually go up to 12mm depending on application
And 3/8 from 8mm to 22mm (most versatile) drive size
1/2 drive 14mm to 36mm mostly suspension axles crank bolt
But for the most part I can do 80% 3/8 impacts and use 1/4 for most engine work
Depending on bolt size too
Rossco
Great White North
Well I make a living with the following.
1/4 shallow Metric 5-12mm.
3/8 Semi-deep 10-19mm
1/2 Shallow 3/8 - 1 1/4.
Best way to learn how to wrench.
L.Cheapo
Generally, for me:
<10mm = 1/4"
10-17mm = 3/8"
17-32mm = 1/2"
>32mm = 3/4"
Of course, convenience, clearance, and required leverage may dictate moving up or down a ratchet size...or two.
camd64
Cedar Park, TX
I have
1/4= 4-14 and 7/32-9/16
3/8= 8-22 and 5/16-7/8
1/2= 10-36 and 1/2-1 1/4
3/4= 1-2 1/2
Mostly use 1/4 up to 10mm, 3/8 up to 19mm with some overlap into 1/2 drive when space permits or it's just a really stubborn fastener. The majority of my sockets are 6 pt. and I have really only ever needed my 12 pt. when working on engines where the customer specified the build use 12 pt. or the occasional diesel with them.
