Yet another happy racedeck customer!!
zvezdah1
columbus, GA
HI All,
After ruminating over flooring for over a year, I finally settled on racedeck. Spoke to Jorgen this past Monday, my flooring arrived on Friday (Utah to GA!) and installed this morning. Total time was probably about 5hours, but that includes the rubber wall baseboards.
Had I to do it over again, I would've don the tire changing area in black or graphite as I know that area will get filthy.
Very happy.
Chris
Z
zvezdah1
columbus, GA
Looks great Chris, I really like the white!
Thanks, I'll probably regret it, but I like the brightness of it! ;)
Also wanted to mention to you as I don't believe you've installed the rubber baseboards in your garage yet because of the temps. When ready to install, get a 4" paint roller, it does an exc. job of forcing the baseboard to bond and gives you a good smooth look.,ie put the adhesive on the back, lay in place pat down and then roll it along the length.
Chris
brmorr
Chicagoland, IL
Looks great, I am about to order some racedeck next week!! Quick question though, does your edging come outside of your garage door? Hard to tell in the pictures, but it looks like when the door is down, you would be able to see it from the outside.
Brian
Z
zvezdah1
columbus, GA
Brian
You are right, good eye, the way my garage is constructed, try as I might I couldn't configure it to have the edgin without leaving an open area on either side of the door of bare concrete, so I opted for edging protruding to have a more finished look inside. The option was to move the edging in but would've entailed gluing.
Wolverine - you can never have TOO many motorcycles!!
Chris
Z
zvezdah1
columbus, GA
Brian
After I read this I went out and looked it over, and I absolutely could've done the strip to the inside with not a major modification, for some reason I just couldn't picture it, oh well, it's there for good now.
Chris
brmorr
Chicagoland, IL
So you can see it from the outside then? I think most run the edging up to the door track. Could you shoot a pic of it the way you have it? I am in the Chicagoland area, so I am thinking I want to keep it all inside the garage due to snow, ice, etc...
Brian
Chris
marty_p
SE LoUiSiAna
GREAT JOB!!!
The red/white checker is a very nice contrast to the customary black/gray designs that we see.
Glad to hear that a good few hours will get it done that fine, Chris.
Z
zvezdah1
columbus, GA
DOH! I was afraid you'd say that!
I should've also prefaced that "you can never have too many motorcycles when they're Italian" as one tends to be broken?
Thanks for the comps guys, I'm really pleased with the colors.
Motorsport, I did go with the 18" as I thought the checkerboard pattern in 12" might be a bit dizzying for me.
Chris
Hellcat6
Chris
Thanks for the tip Chris. Still waiting for a couple of back-to-back warm days here in Ohio.
