WaterLine to Workshop
kc10a
McHenry, MS (Gulf Coast))
I need to run a water line underground to my workshop, about 150'. The line will need to go under the gravel driveway. Any suggestions on what kind of tubing to use and how deep it needs to be? Thanks in advance.
RoscoTom
Northern Michigan
I'm thinking the frost line in Mississippi is at right about an inch and a half, a little deeper at higher elevation....:)
Tom
BobRae
What he said, plus copper tubing.
Why copper? I'd use PEX. If you don't want to dig down too far you can run a heated insulated PEX line that depending on winter temps is pretty economical to operate
Cyberbear
California
We don't worry about the freeze level in California, but whatever is used is usually buried 12" deep in order to prevent accidental damage from digging or vehicle traffic. We most often use PVC pipe under ground and something durable and rigid above, like galvanized water pipe. Sometimes the coyotes like to chew on the water lines.
ibedayank
Columbia TN
copper corrodes Pex don't
Copper will need to be joind togather to get 150 feet Pex won't comes in Rolls of 5o or more feet up to 500
Copper splits if freezes Pex just swells
Pex is much cheaper
gnpenning
I have more questions than answers.
Clear core. Can be called several names. It's blue with a white or black core. Mostly 250 psi and rated for drinking water. Designed for to be buried.
If your going to use pex make sure it's designed for direct bury and if exposed is UV stable.
You can use a black irrigation tubing. It has lower psi and not rated for drinking.
sberry
Brethren, Michigan
They make black in potable. It's cheap and works well. If you put joints in use all stInless clamps, double them, tighten, wait, tighten again.
Boilerhouse
Muskoka
I would use a single piece of black poly, down about a foot so that something driving over it doesn't compress it, and back-filled with a rake to keep bigger stones off the pipe, which could also compress/puncture it.
wes73
South Central PA
Use PEX and sleeve it in 2" conduit. This will help protect it and allow you to replace it if anything happens without digging everything back up.
bjcouche
I vote against using PEX. It wasn't designed for that use. I would use Poly or whatever it's called in your area. It's the same stuff that's used for running from a well to your house. For those on city water you've likely never seen the stuff. For those with a well it's the black pipe coming into your house and going to your pressure tank. It's designed for drinking water, direct burial, and sunlight. Simply put, it's designed specifically for what you are doing, and might even be cheaper than PEX.
Brian
K'ledgeBldr
Johns Creek, GA
Black poly and PVC are the two most common materials used for underground supply lines. There are two very distinct differences- poly will only have two fittings. The PVC will have about 16-17. Another nice advantage to poly, it can be installed with a DitchWitch machine:
No need to dig a ditch!!!
Rigpig
Victoria,BC
I'm running a water line to my shop as we speak. My run is also about 160' and buried it about 12-18" because of my location and frost issues.
If its going under your driveway i'd recommend at least a foot, deeper the better and sleeve it in the vehicular traffic area just to be safe.
I used 1" PEX, and yes its rated for direct burial and came in a 300' roll. Use a good gravel crush to surround it for the first several inches, then cover with the old material. Stay away from joints/splices whenever you can.
Good luck!
Pwrgeek
Texas USA
I used 3/4" PEX in a 1 1/2" PVC conduit sleeve. If it ever leaks or breaks pull it out and pull a new one in.
Sigo
I ran PEX. A single run with no connections to fail. It was probably 18" deep or better. No issues with freezing this past winter in the Kansas City area.
flat350
illinois
Normally I'd say copper but not for 150',don't like joints buried.Run it in some kind of poly and drop a tracer wire in the ditch so you could find it later if need be.
Highbeam
Mt Rainier foothills, WA
I work for a water utility. We do NOT allow PEX, require black poly (actually called HDPE) it comes in 300 foot rolls and is rated for 200 psi. Only the jippo plumbers try to use pex, we make them rip it out.
Pex is great in the house, not in the dirt.
CNGsaves
KS and OK
^ ^ ^ This. With Ditch Witch or Vermeer equipment, they can horizontal drill UNDER the driveway. For the rest of distance, they can use vibratory plow and put down the continuous poly pipe just like sprinkler system.
A sprinkler installation company could do all this for you, and you finish the connections.
csp
Franktown, CO
Just like there are different versions of PEX there are different versions of black poly.
Thus the suggestion to see what's customarily used in your area. The supply houses know as well as anyone.
The HDPE used in my area is blue (and not polybutylene).
rburke65
Canfield, Ohio
Black poly pipe as said. 1 1/4" and S Steel clamps. I'll bet mine has been buried in Ohio for 20 plus years without a problem.
coldh2o
Ontario, Canada
This stuff is used all over around here, by lots of municipalities and utility companies, and has been for years with no problems:
https://www.rehau.com/download/870960/municipex-brochure.pdf
Kevin54
MEMBER EMERITUS
Urbana, Ohio
1" black poly line that is made for water. That is all that is used around here. It's thick wall and you can't tear that stuff up if you try.
