lakeroadster
The more I read about concrete slabs the more I realize it's more art than science.
My barn is done and they'll be prepping the interior for the slab, with any luck, next week.
During my attempt to research "the optimal slab design" I have unearthed:
In any event I have amassed quite a number of links and figured I would share them here.
Selecting Sub Grade Materials: Soil Compaction Handbook
Visual Inspection of Concrete
Better Garage Floors
Flatness:
http://www.concreteconstruction.net/how-to/floor-flatness-number-conversion_o
http://www.faceco.com/docs/40 Questions June 2012.pdf
Slabs On Grade:
http://www.bpesol.com/bachphuong/media/images/book/3021r_96.pdf
http://www.constructionknowledge.net/concrete/concrete_basics.php
Plastic Crack Risk Calculator: https://plasticcracks.siue.edu/index.php?unit=Standard&zip=45339
Vapor Barriers: http://www.stegoindustries.com/docs/Vapor Barriers Under Concrete Slabs.pdf
Building Tips for Trouble-Free Slabs: http://www.cement.org/for-concrete-...truction/building-tips-for-trouble-free-slabs
International Building Code Section 1803: http://www.ibc-wiki.com/section-1803/
Cold Weather Concreting: http://www.concretenetwork.com/cold-weather-concrete/curing.html
Control Joints:
http://www.concretenetwork.com/concrete/slabs/controljoints.htm
https://inspectapedia.com/structure/Concrete_Control_Joints.php
Wire Mesh Standard Practice: http://files.engineering.com/getfil...c=212727627.1.1460754610957&__hsfp=2088101374
Effect Of Rust On Bond of welded Wire Fabric http://rebar.ecn.purdue.edu/wwr/Library\Effect of Rust on Bond of Welded Wire Fabric.pdf
Re-bar Spacing a/ Weight & Materials Calculator: http://www.blocklayer.com/rebar-slabeng.aspx
Concrete Cracking Overview: http://www.cfawalls.org/foundations/cracking.htm
Concrete Floor Slabs On Grade Subjected To Heavy Loads: http://www.constructionknowledge.ne...ts/Div_3_Concrete/Concrete_slabs_UFC_2005.pdf
- Re-bar vs. Wire Mesh vs Fiber Mesh vs Wire Mesh and Fiber Mesh,
- Re-bar assures additional cracking vs always use re-bar,
- Plastic Chairs vs Wire Chairs vs Concrete Chairs,
- Thicker concrete at high load areas (2 post lift) vs a uniform area throughout,
- 3,000 psi vs 3,500 psi vs 4,000 psi,
- Vapor Barrier vs No Vapor Barrier,
- Always ask for mix sheets vs you don't know how the hell to read them anyway.
- And my favorite: That link is 10 years old... that's not good information!
Flatness:
Slabs On Grade:
Control Joints:
