owdlvr
On and off over the years I've lurked here on the garage journal. I suspect it was Jack Olsen's garage that originally brought me here, but I've stuck around for some of the threads and certainly the 'how tos'. Despite owning a few classic cars, and enough tools to be a professional mechanic, I've always rented my shop space...so having a 'build thread' didn't make much sense.
This week, however, I've signed the paperwork on what will become my new garage & shop in the fall. It's currently just a shell at the back of the property, 2 of the 3 bays are poured concrete while, oddly, the middle one is not. Metal roof, zero insulation, no electrical and only one garage door installed. BUT, it's a shop I can make my own, and ends my days of renting. With a little work, it should be a fantastic spot.
Here's what I'm starting with:
Bay #1 is currently secure, but bay #2 and #3 just have tarps for doors. Bay one's door opening is 9ft wide and 8ft tall. Bay two's opening is 9ft wide and 10ft tall. Bay three has an opening of 10ft11" wide by 11ft tall. I suspect the previous owner never finished the doors because the openings have been made in a custom size.
[/url]
Three Bays, with a supporting post in between bay "two and three". The shop currently has a floor to ceiling wall in between bay one and two.
Inside Dimensions (and potentially approximate)
Interior Ceiling Heights:
I'm currently in the planning stages, as moving in is going to be quite the problem. I have enough tools and cars that I really need the shop finished and secure before I can move, but I also want to save the money by doing the work myself. I don't live close to my new shop, so zipping over for a couple hours of work each night isn't an option. Climate wise, I need to have the shop insulated and heated for winter, but it doesn't get so cold here that I can't be doing that in October/November.
Unless there are other suggestions, my thoughts are to focus on the garage in the following priorities:
1) Floor
- the middle bay needs the concrete floor poured, and since I have the opportunity I'm going to make sure the slab we put in is appropriate for a 2-post lift. No heat going into the floor, as there is no water out to the shop and I'd rather put the budget elsewhere.
- Bay's 1 and 3, which have been poured, are finished with a broom finish like you see on a sidewalk. I'm probably going to rent a grinder to make both bays smoother, in an attempt to make it better for rolling jacks and engine stands around.
2) Doors - Need to close up bay 2 and 3. Options are (I think) ordering custom doors, re-framing the openings for standard sized doors or deferring the spend to a few years down the road and making some hinged carriage doors to keep the budget down. Option three I think is a last-resort, because doors that swing out in to the driveway area will really limit that space. Definitely would like some garage-journal input on what might be my best move here.
3) Electrical - has to be run from the house, trenched, and then installed from scratch in the interior. I've got a rough schematic of what I *think* I need in the shop, will post that up a little later.
4) Lighting - Because of the sloped ceiling, I'm not entirely sure what I'm going to do with the lighting. My current shop (800sq ft with 8ft ceilings) uses all fluorescent lighting. I know the downsides, but I don't think LED is in the budget, especially with the amount of lighting I will want/need in this new shop. So planning on fluorescents. Not sure if I should mount them flush to the ceiling (and thus on a slight angle) or use lights that hang off of chains.
5) Insulation - Roof and walls all need to be insulated. Having never insulated a space before, I'm not sure what I should be doing or using in either.
6) Wall covering - Wall covering, for my shop, is completely a budget question. My personal preference would be to drywall the whole shop as I like a smooth, white, wall surface. But on the other hand, I understand the benefits of being able to hang anything off of plywood/OSB.
7) Floor Paint - Current shop has epoxy painted floors, and after 10 years I have a pretty good idea how well (or bad) it will hold up. I'm okay with the slight stains and marks that happen, I just want a painted surface to avoid the large permanent oil stains bare concrete will certainly end up with.
In an ideal world, I'd finish all of the above before moving into the space. But time and money may not allow for that, so I'm going to have to figure out how I piecemeal it, or shuffle stuff side to side and away from the walls to get it all done. My home improvement or building knowledge is about a 1/10, currently, but I learn quick. I didn't know how to build engines, rebuild transmissions or restore cars before I started...but I can read manuals, I'm careful, and I'm willing to learn to save the money from paying someone else. I figure a house & garage can't be that different!
Hopefully that's a good introduction, and some things to start a discussion or questions on this new shop build.
-Dave
1) Floor
-Dave
