454ragtop
I've had this Kellog American compressor for about 30 years, bought it used, pretty much trouble free other than a pressure switch failure. Pump is a 331 TV that was new right before I purchased it. Been slacking on maintenance, finally ordered some Amsoil compressor oil and went to change it a couple weeks ago. Didn't like the looks of the milky oil that came out, so figured I would fill it with Mobil 1 5W30 , run it for a couple weeks, then drain and install the pricey Amsoil. Seemed fine, then last Thurs. noticed it running longer than normal, seemed stalled at 150 PSI, didn't want to get up to the 160 PSI shut off point, so shut it down. Started it this AM and the gauge just sits at about 55 PSI, won't make any air at all. Any ideas on where to go from here? Could the Mobil 1 have caused this?
TIA, Jim
TIA, Jim
