Shane's Attached Two-Car (plus a motorcycle) Garage
shaner3721
Denver, CO
Hey All,
I've been lurking on here for years, but I have finally decided it is time to post up my garage project.
A little over a year ago we purchased our first house and I had some pretty lofty dreams for the garage (as we all do on here), but other house projects and life took over and have stopped me from making the garage I want. I've finally decided to try and improve the storage, cleanliness and look of my garage to make it super functional and aesthetically pleasing. Here we go!
First, a picture of the front of the house. It looks quite a bit different with some changes we have made, but this will give you a good idea of the size and location of the garage.
And here's a picture of what the garage looked like when we first moved in:
My least favorite feature: The post in the center of the garage!
My most favorite feature: Heater in the corner so I can work on my toys all winter!
A few more pictures of the space:
The biggest concern when we first moved in was a lot of the wiring in the garage. Everything was stapled to the outside of the drywall and the garage door opener was plugged into an UN-GROUNDED extension cord and run across the ceiling and down the wall to an outlet! I promptly ran power up to the ceiling and installed a proper outlet for the garage door opener. Then I hid all the other wires in the drywall.
After all the power was cleaned up I rearranged and added some cabinets and moved all the pin board to go above the workbench.
At that point I painted the cabinets blue and hung a bunch of flags and posters I had laying around and called it good... Over the past year I have done a few minor changes such as removing all the old hangers and nails around the walls, added additional storage in the rafters and just organized/cleaned the space up.
Now it's time to truly transform my garage into what I want it to be. Here's my very basic list so far:
  1. Get new cabinets/storage setup
  2. Paint walls white
  3. Coat the floor
  4. Improve organization and cleanliness
I'm already working on the cabinet/storage part. I just picked up a set of free kitchen uppers yesterday and sanded them down and painted the bases. Please ignore the mess that is my garage!
Once I get the cabinets all hung (hopefully tonight), I am planning to patch, sand and paint the walls a nice bright white to help clean up the look. The goal is then to store everything in the cabinets or up in the small rafter space I have (aside from wheeled items that belong on the ground and some workbench stuff).
Looking forward to tracking my progress here and hopefully providing some insight and ideas for others! More to come soon.
-Shane
rattle_snake
Chandler, AZ
Glad you are able to prioritize you garage now. A little paint will go a long way. I also try to have everything in cabinets for a cleaner look and cleaner tools. Good luck. Like the wheel hose/cord hangers.
shaner3721
Denver, CO
Thanks, Justin! Much appreciated.
I really enjoy your custom fabrication in your spaces and am actually planning to setup my compressor with a reel setup like yours. Thanks for the inspiration!
shaner3721
Denver, CO
Thanks for the comments! Keep the ideas and opinions flowing!
I got a few things done tonight. Picked up some conduit and cleaned up the wiring running to the heater setup:
Next, I got all but the last 'new' cabinet hung. The final one will go on the right side where some pin board is now.
Last, I pulled the ugly old blue cabinets down. It already looks better!
Next steps are finishing up the last cabinet and then organizing everything.
Thanks for following along!
Shane
shaner3721
Denver, CO
Got a bit of time to work on the garage today. I was able to install the last cabinet and start organizing. I then tore down the workbench, reinforced it with some crossbeams and got half of it reinstalled. I also added some shelves for the mini fridge and stereo.
Hoping to get the rest of the workbench reinstalled tomorrow and then I'll organize everything. Haven't decided what I'm going to do for a workbench top yet.
shaner3721
Denver, CO
Completed some more work today. Got the rest of the workbench reinstalled/leveled. Put up the last pinboard and got some organizing done. Here's where it's at now:
shaner3721
Denver, CO
Spent a little time cleaning up the other side and starting to plan it out. I modded some left over cabinets I had and am planning on getting a door as a top for them soon. Any suggestions for how to level them? The floor slopes downward toward the front of the garage so I'm thinking about mounting the cabinets flush with the top edge of the concrete. Thoughts? Ideas?
-Shane
shaner3721
Denver, CO
Thanks, 1/2 Cup!
I appreciate the thoughts on the cabinets. Didn't even think of the idea of adding baseboards or a molding to the bottom. Definitely going to look into that and it should help me decide the height of where I mount the cabinets!
-Shane
shaner3721
Denver, CO
Got some work in the garage done today.
Got a desk top for the top of the workbench.
Mocked everything up:
Then I sprayed the cabinets, anchored them to the concrete and glued the top on:
Let me know what you think!
Shane
shaner3721
Denver, CO
Alright, I need some opinions!
I've got wires galore running advertise the ceiling for all these lights the PO put up and I've also got some garage sensor and opener and sprinkler system wires running on the right wall.
I'd rather not bury them because that's a ton of work and would be a headache if I ever replace the garage door opener or sprinkler setup.
Any recommendations for how to clean this mess up? Some sort of conduit of something?
wasfast
San Diego CA
One reason they are so visible is they don't follow the existing edges. Run the garage wires along the stem wall at the bottom of the wall, then up along the door jamb trim. Run multiple together instead of separately.
shaner3721
Denver, CO
Ended up going with the wire covers I linked to earlier.
Got some of the wiring for the ceiling lights done and then cleaned up the house-side wall with wiring for the garage door opener buttons and sprinkler system controls:
Here's a quick pano of where I'm at today:
And a shot with all the ladies tucked in for the night!
That's all for now. Gotta get a few more wire covers to finish up all the lights and door opener wiring. Then I'll mud and paint the walls and get the cabinet doors hung.
-Shane
rmckee
Wake Forest, NC
I can appreciate the sentiment towards the post in the middle of the garage... not my favorite feature, but I'd rather have it than have the upstairs collapse down! Good progress so far.
shaner3721
Denver, CO
Not a huge update, but a lot has happened. I was able to pull everything out of the garage over the past weekend and get a ton of mudding and taping done on the drywall. I got the cabinet doors finally hung as well. Hoping to paint the garage tonight so I'll have a more exciting photo or two soon!
Here's a quick shot of the cabinets with doors:
shaner3721
Denver, CO
Just ordered one of these so that I can get my pedal bike up into the 'rafters' and out of the way completely. I'll have to build some sort of level shelf up there to mount this too so that is the next mini project in the garage.
I'm also planning to move our old tv out to the garage soon, so that's super exciting!
Third thing on the list is a magnet whiteboard space so I'll hopefully be painting that on one of the walls soon too!
Thanks for looking,
Shane
PECVD2
Albuquerque, NM
Nice looking place Shane. I am gonna steal that Saab sign idea from you and make one for my wife (huge Saab fan) and I love the craft lagers from upslope. I recently had top self Mexican style lager from them at the the brew fest in Durango....I am taking both of my insulated growlers with me as soon as I find it on tap near by
shaner3721
Denver, CO
Happy to provide the idea! What kind of Saab's do you or your wife have?!
Can't get enough of Upslope's beer... The brewery here in Boulder is a fun place too. They make a Blood Orange Saison as a fall seasonal that I love, so I've been getting quite a bit of Upslope cases lately! :D
-Shane
PECVD2
Albuquerque, NM
-Shane
These days the wife is rolling in a Saab(GM) 9-7x, it is more GM than Saab and in fact I personally think the only Saab feature is the ignition switch in the center console LOL. She does have her eye in an early 70's 96 as a woman who moved into the neighborhood is driving one around and has sparked her interests in one.
I am going to visit total wine this week to see what Upslope they are carrying these days.
Do you have a Saab?
shaner3721
Denver, CO
Do you have a Saab?
My father actually drives a 9-7x. Not to bad for a GM branded Saab!
I do have a Saab (ng900), but it's currently torn down to the bare metal and the heart is rolling around my garage:
Said heart (pictured above) should push 400 ponies when I get everything put back together!
-Shane
shaner3721
Denver, CO
Decided on a location and hung the ladder up tonight:
Also started on the setup for the bike hoist. More to come on that later.
-Shane
shaner3721
Denver, CO
Got my new bike hoist last week and finally had a chance to install it yesterday. Crummy pics because it's an awkward space, but I'm thrilled with how it turned out and how well the bike is hidden now!
Also bought a new TV for the house so now I have an older 32" to put in the garage. Ordered a wall mount for it last night.
-Shane
