Below 265 SQ/FT 12' x 16' storage shed (making room in the shop)
All workspaces below 265 squarefeet.
couch67
Ontario Canada
Hello fellow Garagers,
Thought I'd finally start a thread to share my shed build. First of all, thank you all who contribute to this forum. The wealth of information on this site is incredible.
My wife and I live on the outskirts of Ottawa Ontario, on 1.5 acres. This was our first home that we purchased in 1994, a small house (~800 sf) in need of work. Over the years we have completely renovated on our own, and added an additional 1000 sf of living space. Not included in that space is an attached garage which is dedicated to shop space. We probably should have started from scratch, but you know the saying about hindsight....
Fast forward 22 years later, we have two kids 13 and 11. Things are busy, and while I think we live pretty lean, there is a healthy amount of 'stuff' that gets moved around from space to space depending on the season. Time for more dedicated storage.
In the back of the yard we have two storage sheds:
- A 6 x 8 metal shed that the squirrels pretty much own. Winter/summer tires are swapped out twice a year, and I shovel a load or two pine cones out to at least get the doors open. Not even sure what hell else is in there.
- An 8 x 12 wood shed, this contains most of my seasonal stuff. Lawn tractor, trimmer, chainsaw, snowblower, shovels, etc. This shed would probably be fine on its own with an efficient layout, but it is showing its over 40yr age now. Its sinking (wood floor on patio slab), to the point the doors barely open.
My initial goal was to build a new shed to replace both sheds, and have enough capacity for a permanent storage location for other items from the hosue / shop. I'm now thinking the 8x12 will be a recovery project next year. It needs work but the roof is relatively new, and the overall structure is still solid. Need somewhere for those damned squirrels!
My design is a 12' x 16. Standard thickened edge slab (12" footing with 4" floor). 2x4 walls, gable rafter w ridge board roof. Nothing fancy.
View media item 74313
Here's the start of the sandbox. Sandwiched 2x10's and 2x4's to get the required footing depth - that's what I had on hand. On the edge of our property, note the neighbours garden shed behind it.
View media item 74314
The underside of the slab has been backfilled and tamped, to allow for 3.5" floor...
View media item 74315
mesh and rebar inserted. Not all of the form supports were added at this point (I thought I had enough, my concrete buddy said to install more!).
View media item 74316
Fast forward after the concrete placement (I ultimately hired this part out after doing the hard work!). In the end I was really happy with the job. This picture was a few months ago and there have been no issues.
More updates to come shortly...
C
couch67
Ontario Canada
The pad was formed in early June, and with a busy (and hot!) summer, I didnt start framing until August. The walls are 2x4, 24" o.c. PT bottom plate, and double top plates. 7/16" OSB all around.
Here's a picture of the kids helping frame and lift a few walls. It was good to get them involved a bit with this project!
View media item 74317
I hadn't realized how few pictures I took of the framing. Must have been too into the build to take a break. The walls are framed and sheathed, and most of the roof framing has been erected here. Roof pitch is 5/12. I used a 2x8 ridge board, and 2x6 rafters @ 24" o.c. 2x4 ceiling joists have been installed on all rafters except the rafter at 2' and 14'. The intent is to have a few extra feet to get longer things in and out of the attic space.
View media item 74318
Another pic of the roof framing. False (fly) rafters were framed with a few 2x4 stretchers that were notched through the gable to the next rafter. Additional blocking will be later added in-between the false and gable rafters.
I ended up using some of the 2x10 forms for the garage door header. These same boards were used for a few years as part of an outdoor skating rink, so they have been around! Surprisingly they were dead straight. Additional jack studs will be added later..
View media item 74319
The roof has been framed and sheathed. Gable rafters have framing to accept sheathing. Rafter tails have been cut to allow a 2x4 facia board. Don't laugh too hard at my scaffolding, they are pretty old and rusty, but still sturdy. You need a tetnus shot just to look at it!
View media item 74320
View media item 74321couch
CNGsaves
KS and OK
Looking good OP. You've got a beautiful lot. :beer:
Hope that you will be putting on metal roof since you're right under trees. Those will shed lots of debris that will hold water and snow on roof.
C
couch67
Ontario Canada
thanks CNJsaves, I contemplated the metal roof but in the end went with shingles. My 8X12 also has shingles. Its on the opposite side of the property but has very similar tree coverage. It hasn't been an issue with debris/water or snow.
Couch
velillen01
Wyoming
Looks good! I built the same size this summer and love the extra room (though i didnt have any other sheds ot begin with).
C
couch67
Ontario Canada
Quite a bit of work happened before these pictures were taken. The side door and window have been installed and trimmed out, aluminum soffit and facia has been installed, and the roof has been shingled. This happened over a couple of weekends.
View media item 74327
The side door is open in the picture above, but it has been trimmed out. I used 2.5" x 1" PVC trim, and rabbetted 1/2" out on the edges to make a j trim for the siding. Some other pics will show a bit more detail there. The window has a built in brick mold, so will use regular j-trim there.
View media item 74328
The front door jambs have been flashed, and like the side door, PVC trim with a rabbet cut was used to frame it out.
View media item 74329
Fascia trim and soffits. I rented a brake to bend aluminum coil trim. First time using one. I was slow as hell but was happy with the results.
View media item 74332
Roof shot. Under the shingles are one row of ice/water membrane at the eaves, and 12" wide membrane along the gable ends.
View media item 74330
A shot of the inside. Looking pretty cluttered at the moment, but so far has served as a good dry place for cutting and for bending trim.
C
couch67
Ontario Canada
Here's where I went a bit crazy. Did I mention we get a lot of squirrels? This shed is being built with the intent to keep them out. While I had the brake, I bent a bunch of 1/4" mesh strips to protect the bottom part of the OSB. On my old shed, they had no problem making their own entrances where-ever they wanted in the OSB. The corner siding pieces also have mesh jammed up in the bottom. Time will tell if the madness pays off...
View media item 74322
I like installing siding. It goes fast, and you get quick results - until there's openings to deal with. I use a lot of flashing to shed water to the lower piece of siding. I also drill extra drainage holes in the next layer of siding to help shed the water. I built a small cutting fence out of some scraps to allow siding to be slid through, and can be cut with a skil saw (framing blade on backwards).
View media item 74323
View media item 74326
The siding was completed, now just need the roll-up door to come in. Its a Clopay model from HD.
View media item 74333
C
couch67
Ontario Canada
Captain, I have always been a behind the scenes carpenter, never for money but have enjoyed every job I've done. So to estimate my experience, I've been at it about 30 years, but only a few week-ends at a time now and then.
When I get into trouble this site especially has helped me out.
couch
rmmiller
Kennewick, WA
We just did a 12 x 16, largest we could go without a permit. It freed up so much space getting the lawn **** out of the garage, next up is my work bench in the garage!
Platonic Solid
CT-USA
...I built a small cutting fence out of some scraps to allow siding to be slid through, and can be cut with a skil saw (framing blade on backwards).
Nice build and nice tip.
Is that diagonal 2x4 a permanent part of the structure?
I've obviously got a lot to learn as I'll have to google half the construction terminology you use.
C
couch67
Ontario Canada
Thanks Platonic. The diagonal was there during framing to keep the wall plumb. I had taken it off at some point after the sheathing went on.
couch
