sbosecker
I purchased a BendPak XPR-10A-168 about 2 years ago. A bit less than 2 years later, I got the lift installed in my new shop. I installed the lift in the "Wide" configuration.
Today I was going to use my lift to raise my 2000 F150 SuperCab.
To my surprise I couldn't reach both the forward and aft lift points - at the same time - with the arms that came with my lift. The picture shows my final attempt - which was almost a symmetrical approach to the problem. This came close but - as best as I could tell - was not correct.
Here's the Chassis Lift Guide that came with my lift. The 2000 F150 is the diagram in the lower right.
I also have the 2000 Light Duty Truck Specification Manual. Page GSI-13 shows the lifting points in better detail than the Chassis Lift Guide.
So has anyone lifted a F150 similar to mine with a BendPak XPR-10A in the wide configuration?
Do I need a different set (longer) of forward arms to lift my truck properly?
Scott
Scott
