Tools Explained by a Do-It-Yourselfer (repost)
crashbumper
Gilbert, AZ
Saw this at Dinosaurs and Robots
I found it disturbing how many of these I could identify with! :)
TOOLS EXPLAINED BY A DO-IT-YOURSELFER:
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings objects across the room, denting the freshly-painted vertical stabilizer which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench at the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh*t'
ELECTRIC HAND DRILL:
Normally used for spinning pop rivets in their holes until you die of old age.
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50-cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE:
Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as leather seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
DAMMIT TOOL:
Any handy tool that you grab and throw across the garage while yelling 'DAMMIT' at the top of your lungs. It is also, most often, the next tool that you will need.
HandyManny
Out West
I don't know. I really can't poke fun at DIY'ers too much. As long as they are competent and invest their time and research to actually learning how to do the job correctly. I commend them. Americans have always been DIY'ers. It's in our culture and history. That's how a good portion of our country was built. Besides from some of the less-than-steller work that I've witnessed being done by so-called licensed professions these days and for what they'll charge you, I don't blame anyone for wanting to learn how to do their own repairs and doing them right with care.
The big problem I have these days with many DIY'ers is that people today watch those cable channels and home improvement channels, take their cues from the host, a face who's not an expert and suddenly they think they are Bob Villa. Then they end up doing more harm than good to a home or vehicle. People need to understand that those TV shows and programs don't actually show you how to fix or build anything, what they do is show you that they are fixing and building something. There is a difference. As long as people understand this then they can go learn how to do a job right from the right folks.
Shocker
Olympia, WA
I don't know about that HM. I have been sick for a while and spending some time watching DIY network and HGTV. Just about everyone hosting is an expert in the field.
Rock Solid on DIY is great. Both of the guys on there have been stone masons for 25 years and come from a family of masons. Great show with lots of great ideas. They do a project and show every step taken. Now you are not going to be as skilled with the rock chisel, but they show the proper technique and you can sure practice that.
HandyManny
Out West
Yeah Rock Solid is a good one and so is This Old House as the crew there are seasoned experts as well.
I was mainly talking about shows like Flip this House, Bathroom Rennovations, Yard Crashers, Man Caves, Tool Belt Diva, etc. But mainly Flip This House. I think anymore these networks find a face to show on TV, call them an expert, and everyone watches and listens. I have a real problem with some 22 year old hottie female being refered to as a "veteran carpenter". I have a problem with anyone who has less than ten year experience being refered to as a veteran or expert. I also have a problem with seeing younger guys on these shows being refered to as "experts" when they are obviously younger than 27 years old and their tool all look brand new as if they just bought them or were given them to use just for the show.
True experts are guys like Tom Silva, Norm Abrhams, and Richard Tretherwy. Older men with rough hands, grey hair, beer bellies, and tools that show extensive hard use over many years of service.
But mainly my point was that DIY'ers doing their own repairs, be it, automotive, small engine, carpentry, plumbing, or electrical is a great thing. Just as long as they take their time to learn how to do it competently, safely and do it right. And as long as they have access to or are willing to invest in the proper tools. That is the key. I've seen experts in the field who don't always do even simple jobs correctly or with much care. For what the customer gets charged, it's appauling.
