uberschnell
- Joined
- Oct 8, 2015
- Messages
- 6
I recently bought a Farm Hand (rebranded Campbell-Hausfield) Versa Arc 95 welder. I know this is a crappy model, and it's old, but it works...or should.
I wanted to get a "cheap" start to MIG welding before upgrading to a better machine later on. I've got a bottle of C25, regulated to ~20CFH at wide open. I used Lincoln wire for flux core, and have .030" Hobart wire for MIG.
I don't claim to be good at it, but I have welded before.
First picture is how it welds with flux core wire. (please don't judge me!)
Second picture is the horrible train wreck that happens when using gas. There is almost no penetration...it's almost like a voltage problem, but I'm plugged straight into the wall and even on the lowest setting it is totally unusable.
Third picture is the polarity adjustment, which I don't totally understand. The knob was seized and broke off, and I couldn't figure out how the mechanism works. It appears that those plates can be swapped in order to reverse the polarity. I tried it both ways, same result. With and without gas, same result. I can hear the gas escaping the nozzle when the trigger is pressed, and watch the gauges on the regulator move. Pretty sure it isn't a gas problem.
Does anyone have info on how to reverse polarity? Do I have another issue? Is this model just that much of a POS that it's useless with anything other than flux core wire? Is it possible the wiring in my garage is just too small to support a MIG welder, but works fine with flux core?
THANKS!!! Woo first post!
