Lowes - Waterloo 32.5-in x 26.5-in 4-Drawer Ball-Bearing Steel Tool Cabinet $50
Gannz
Triad, NC
Lowes - Waterloo 32.5-in x 26.5-in 4-Drawer Ball-Bearing Steel Tool Cabinet (Black) $50.00
Waterloo 32.5-in x 26.5-in 4-Drawer Ball-Bearing Steel Tool Cabinet (Black) $50.00 save $59.00 off reg price.
https://www.lowes.com/pd/Waterloo-3...l-Bearing-Steel-Tool-Cabinet-Black/1000139577
$49.00 for this tool chest, save $40.00 off reg price.
https://www.lowes.com/pd/Waterloo-1...&cm_mmc=AFF_CJ-_-4485850-_-1122587-_-10926682
https://slickdeals.net/f/9291715-lowes-waterloo-32-5-in-x-26-5-in-4-drawer-ball-bearing-steel-tool-cabinet-black-50-00?v=1
Add $15 off $50 coupon to get it for $35. Link to coupon in link above.
Not the best quality but for $35 I can find a use for a couple to store blades, bits, clamps, discs, burrs, etc.
Tirade
What's the link for the code? First two links don't work.
Sent from my Pixel XL using Tapatalk
G
Gannz
Triad, NC
Read the thread in the third link. But, the code generator is not working now. Probably got overwhelmed and/or drained by everyone on slickdeals using it.
Super Sport
West Michigan
Killer deal for some light-duty storage. If I hadn't just bought a couple other cabinets I would likely jump on this.
KMdef9
The Motorcity
Wow, will get be getting this for $35. Might get the top too. My storage are nearing capacity again, so this would work great in the basement.
EDIT: Actually it would be nice to replace my original tool chest, the drawer layout is terrible...
EDIT: EDIT: This would make a great gift for someone!
Hopefully it's just capped so it doesn't get abused and shut down like the last one.
G
Gannz
Triad, NC
There's a way to generate your own codes but I'm not smart enough or patient enough. You can also buy them on fleabay at about .50 each.
nickelmore
50 miles from Chicago
Can someone PM me a 15 code they have one left down the street.
I was looking at redoing workbenches and need a bunch of these but 1 will work for now.
Thanks
exmaxima1
Midwest
Just bought a code off fleabay and got a cabinet ordered for pickup today :rocker:
xriderbc
Anyone have a link to the code formula so i can try some out? Inventory disappearing fast in my area- some reseller must be buying every single one.
G
Gannz
Triad, NC
=47000 & TEXT(RANDBETWEEN(0,99999),"0000") & 6035 & TEXT(RANDBETWEEN(0,9),"0")
Send me two if you figure it out or get it to work. Success rate should be around 10-20% but I'm 0-25 and gave up.
G
Gannz
Triad, NC
Finally figured out how to generate your own code...
Start with this 470000XXXX6228X
Pick any random 4 numbers for the first XXXX
Keep those 4 numbers the same and change the last X to 0-9 until you get a hit or until it says "promo already redeemed". If you get promo already redeemed. Pick four new numbers for the first XXXX.
xriderbc
Finally got a code to work, but Lowes now says ready for pickup in 3-7 days, which means cancellation. Resellers emptied out 8 stores in my area in about 20 minutes, ha ha. Just wanted 1 for extra storage.
Oldgloryfirearms
Southern Maryland
worked for me thanks!!
aroslv
Thanks that worked for me. Going to use it for the welding table i am building =]
firworks
IL
Very tempting... I need storage for up in my lab. Maybe I'll try to grab one if I can't find any better deals on AWD.
exmaxima1
Midwest
Damn you guys! It worked and I just bought a second cabinet....
GForceJunky
Code worked (took a few minutes of playing around). For $36 or whatever, can't go wrong (I hope).
Should be picking it up later today.
Thanks...for helping me spend more money =S
firworks
IL
Are you guys buying the top separate in separate transactions with coupons or just buying the top and bottom and getting 15 off the total?
GForceJunky
I bought just the bottom...just wanted something small to roll around the garage that I could throw some parts in and use as a small worktop. That and I can't really afford to keep spending on things I don't really need - I can justify just the bottom when it's $35.
Don't think you can get a discount on the top unless you add something to the order worth $1 or more (easily done) and then you'd have to do it separately, I think. Unless it's specifically $15 off an item worth $50 or more, but when I redeemed the code it said $15 off $50, so I think it's just the whole order.
QUIKSVT
Hilliard, OH
Bought the top and bottom separate. Had top add another item to the top order to go over $50. Will p/u tonight, order is ready to p/u.
Tscott
Keystone Heights, FL.
Correct, I tried. Ended up with 3 total orders. 2 orders with 1 bottom box each and 1 order with 2 top boxes. I could have added the dollar item, but I was tired of screwing with the codes.
Tom
cheechi
Triad, NC
I was hoping this would lead me to a 50 off 250. all gone. If someone has a recent one they used and are willing to share it with me so I can try to generate another for myself I'd appreciate it in PM.
firworks
IL
I decided against grabbing one. The code generation is a bit too iffy for me. I've gotten those coupons in the mail before and I'd be pretty disappointed if someone had stolen my code before I got to use it. Without it, 50$ is out of the impulse buy range.
kneeman
A man with integrity. I like it!
archirelic
texas
Damn!! Managed to order 1, even though online it was showing 4 at my local Lowes! Went online to order another and all gone! Online inventory still shows as 3, but assuming it hasn't updated at this time!
Regardless, picked up on, THANKS OP!
gamp945
Store cancelled my order saying they can't find them. Placed another order from another store. Fingers crossed!
Co-Dan
I picked up 3 to go under my workbench, Didn't have time to get a code to work, but even at $50 they are a good deal.
naturalgas
Metrowest Ma.
Thanks OP. I just got one of each. Got the last bottom in area with 15 coupon and picked up the small box with 10% off coupon
bubinga
Got it to work 1st time,
used 2711 and 0 on the end.
