The Garage Attic Retracting Stairway
Vintage Veloce
San Diego
We just finished building our garage. Probably the most interesting feature is the attic stairway.
Most people with attics have used those weak and narrow pull down folding or telescoping stairways. They are narrow and steep and not very strong. I wanted to be able to easily use the attic storage area so I wanted a really good stairway.
It is important to understand that attics need to be designed properly to support the weight. From the beginning of the garage design this stairway has been planned for. I discussed it with the truss engineer and we made sure to design for the truss spacing, the weight and the point loads. Additionally, the whole system has been designed to account for the various loads and weights on all of the components.
I did lots of drawing to design and build the stairway and components but this one sketch illustrates the basic function:
And here is a video of the stairway in action!
Details
The counterweight:
The pivot:
The cane bolt and my stick to extend my reach:
The pulley system:
The stair to cable attachment:
V
Vintage Veloce
San Diego
Looks like a nice stairway, but no rails? Nonetheless, nice project.
Actually, after going up just a couple of the steps you are in the ceiling opening, which makes an effective rail for the upper steps. I was also concerned a regular rail might impede my handling of larger items near the bottom of the stairs. All that said, if it feels "iffy", I'll add them.
Frankly, the bigger concern is the big hole in the floor of the attic. I'm likely to add a barrier around that!
mygarageone
Munising , Mich
How cool , I have been thinking of this same thing for our new garage . I had the trusses set for a 3 ft wide set of stairs just like what you have done.
IPACA9
Independence, Mo
Very nice. Just finished my stairs to my mezzanine last night. I really thought about making retractable steps but I figured they would just be left down most the time anyways. I will say that making stairs *****...lol
Rockcam
Grand Rapids
OK - this stairway is super cool.
Very well done - especially love the unistrut track and counterweight.
Car and garage also look great.
ms fowler
Littlestown, PA _ 6 miles south of Gettysburg
I have very nearly the same setup. The guy who built my garage had a wall, 10' from one end for a "man cave". He attached some pretty heavy stairs to that wall for attic access. I need space more than a man cave ( garage is 30X40 overall) so I took out his wall, and used his stairs. I have a Harbor Freight 2500# winch hooked up to pull them up, and then I have 1/2" diameter steel pins as "safeties" to prevent the stairs from falling in the event of winch or cable failure/ When I get everything drywalled and painted, I will also paint a safety zone on the floor as a reminder of where the stairs will come down.
matt_i
This is a really great design, I would like to "adapt" parts of it to my build! :thumbup:
Nice clean garage also.
KDXSR5
Wyoming
Nice and clean stair install! Do you have a part # for the pulleys you used in the build?
V
Vintage Veloce
San Diego
Here are the pulleys I used:
Stanley National Hardware 3219BC 2" Zinc Plated Wall/Ceiling Mount Single Pulley
https://www.amazon.com/gp/product/B000VZRODK/?tag=atomicindus08-20
I also used rated structural screws to install these. Note you have to be very careful about the height of the screw heads and the cable routing.
Note, with a small pulley diameter you need to use very flexible cable. The typical stuff from the hardware store or home depot is unlikely to work well. More flexible usually means smaller gauge with more strands. You also want to use properly rated and tested crimps, and the crimping sleeves have to be the correct material to prevent galvanic corrosion. It took me quite a while to figure this stuff out. All my stuff was from Loos Cableware http://loosnaples.com/
tfalk
Somerset NJ
Very nicely done! For the pull down stairs, I have to ask, is the garage attached to the house? My only concern if so would be I believe code would say the ceiling has to be fire rated and I'm not sure that would qualify?
jako
A very clean build and a nice car as well.
I wonder if you couldn't bring that stair down by lifting the counterweight?
Maybe a lever on a foot pedal?
V
Vintage Veloce
San Diego
You definitely can lift or pull on the counterweight or cables to move the stairway. I was originally considering putting a handle on the counterweight itself. But when pulling on the counterweight, it often twists and then doesn't move well in the unistrut track. I also can't reach the counterweight well when it is up by the ceiling.
I also realized I wanted the cane bolt at the foot of the stair, so I needed to reach up around that area anyway, and thus I went with the stick with a hook on it and the screw eye.
jako
Indeed, the weight of one curious cat could bring it down on the hood of that Alfa.
Smoker
San Antonio
I did an L shaped staircase built in the back corner of my new shop - I considered a few options including a fold down or pull down setup like this but ended up going the route I did for three reasons -
The truss manufacturer gave me a girder truss option so I could go up to 48" wide on the entryway.
The built out second floor was going to see alot of traffic when storing and retrieving items. Raising and lowering would be a chore.
I wanted decent handrails as I have a 12' ceiling.
This solution looks great for this case though, very nice.
V
Vintage Veloce
San Diego
And THAT would be a disaster! ;-)
Actually a fat cat might start it coming down, but it would be a slow descent at least. But you are correct, that is exactly what the cane bolt/latch is for.
shortykorte
Tallahassee, Fl
Very nice solution. Looks finely made. Job well done! If it meets your needs then it is perfect.
Since it isn't the stairway to heaven, where does it go?
LS6 Tommy
Northern NJ
Vwry nicely executed! I'm a crappy carpenter and I had to have acces that used a very small ceiling and floor footprint, so I opted for a +/- $80.00 premade solution. I got a Werner telscoping space saver ladder...
Tommy
Kaizen
New England
Strangely, heaven is at the bottom of the stairs ;-).
I'm motorcycle guy, so I don't need high ceilings and a big lift. So I put in attic storage for all my spare parts.
Ok thanks for the teaser.....if you put that much effort and detail into stairs please show us the rest of the garage. The space itself with lighting/sunlight looks awesome. Love to see exterior too
Jackfre
N CA
That is nicely done. What were the differences the engineer came up with in your truss design? My trusses are designed for the standard 40# load and I am not putting a lot up there as a result. I went with the 350# pull down AL ladder, which is as you note, steep and narrow. I did cut a hatch (22.5x48") that has a winch above to raise/lower bulky material. Even with the hatch I have found myself half way up the ladder asking myself, "why the hell am I doing this?" Again,. well done!
V
Vintage Veloce
San Diego
The truss engineer made a bunch of changes like using 2x6 instead of 2x4, and a special triangular piece in the peak. He also put in an extra diagonal web. We designed the load for the wider spacing for the stairway, 32". In addition to the full floor loading for the attic we added a large point load where the pivot for the stairway was going.
Here's a few pics of the outside for Kaisen... Craftsman style to match the house. Note the beam ends supporting the fascia and the gable vent details.
View media item 65206View media item 65207Incidentally, in the picture, above note how the rafter tails look evenly spaced. The uneven ones that are at 32" for the stairway were cut off and we put "false tails" at the proper locations, every 24". Because of the math the ones at the end of the roof have a bigger space.
And the sliding gate:
View media item 65208
C_F
Utah...SNOW BLOWS!
I really like your stairway! It was obviously well thought out & executed, very nice. I'm kicking myself for not thinking of something similar when we built our house in '98. Because I didn't plan ahead, I currently get to use a 10' ladder. Oh well, I only need to go into the attic 3-4 times a year.
I also like your sliding gate, it looks stout.:thumbup:
eastbaysubaru
NorCal
Fantastic staircase! Very inspirational. I'm not sure my garage ceiling would accomodate this style of staircase (I just cut and framed an opening and use my extension ladder in the meantime).
-Brian
Kaizen
New England
I knew it had some exterior flair. very nice. next to big Victorians I love the craftsman houses esp out your way. The ones back here feel like a log cabin in a city.
MeanGreenZ71
NC
Subscribed. This was the same idea I had for my attic access. Any more info/drawings/dimensions/etc on the pivots and brackets?
