Dave-H
Hi all -
I'm having an epoxy floor installed on Monday, and I'm trying to understand whether the cold temperature will be an issue or not. The installer says that so long as the slab temp is 40 or higher we should be ok.
We're having lows in the low 20's and highs in the low 40's next week. I recently insulated and installed a heater and I can confidently keep the room temperature in the 70's - but the slab temp would, of course, be lower than the room temp.
Should I be OK? I am also not sure what happens in the gap where the garage door meets the slab - will the door need to stay open an inch or two, that will not help matters.
If we don't do this now, I need to wait until late March. So trying to sort out the situation. We are also leaving the country exactly 9 days after the floor is installed, so it needs to be able to handle parked cars by then.
Any ideas about whether this is advisable?
thanks!
thanks!
