Garage Extension to my 20X20 Garage
JimVonBaden
Northern Virginia
I have wanted to do this for a while, and finally got the OK from the wife. Actually, she told me she wanted to park in the garage, so this is the plan.
I plan on a 12X16 extension to my 20X20 garage. It will be my workshop area, and I can use the garage when needed. The motorcycle lift will be inset in the floor, and all my storage will move to the workshop. The garage will then, barely, fit both cars and her bike. My bike will go in the workshop.
Here is the layout and plans. It mimics the existing garage and will appear seamless when done. I have to notch the right side to clear the fence, but I will use the extra space to add a mini-split AC/Heat system.
Tell me where I messed up please.
Colin Len
Long Beach CA
You're lucky you're into bikes and that sort of size would work! My (and likely everyone else's) question is - why not go bigger? Depending on what you use the back yard for it looks like you have room to go further back or even out to the left.
Another question would be whether you've thought out getting in/out of the workshop. If there are 2 cars and a bike in the garage does that leave room to push another bike back into the workshop? Personally I hate moving cars for stuff like that. I'd consider a wider exterior entrance door, maybe even a rollup on the left side instead of that standard sized man door.
Lastly, if it were me I'd need more workbench square footage.
Wish you the best of luck regardless - and I'm quite jealous as my 18x20 is tiny and I'd LOVE another 12x16 addition! I actually had an 8x14 shed build off the back of mine which is extremely helpful but still not an entirely new workshop!
J
JimVonBaden
Northern Virginia
Believe me, if I could build bigger I would. The green space rules in my city do not allow it since I have a large patio and front parking. I can pull one car back and park my bike in the open end for easy access since I ride my bike daily and my cars sits for weeks at times.
I would love bigger, but it is what it is!
Thanks,
captain14
Are you going to do most of the labor?
And this is a winter project or are you waiting until springtime?
I have followed your other projects here and will certainly follow this one.
Good luck from College Park.
J
JimVonBaden
Northern Virginia
I have guys to pour the pad. I will probably do half of the construction labor. Too many things take two guys or more for me to do it alone, and my wife isn't much good for heavy lifting. I want to start soon, but it depends on if I can get the pad down before it snows. If not, it may wait until March.
Thanks!
LX-Markham
Markham, Ont.
I wish I had room like that to add on to my 20x20 garage.
That's going to be real nice when done. Great plan.
Looking forward to seeing the build.
stonesfan68
Houston, TX
I'd add a 220V electrical outlet somewhere. You never know if/when you'll want/need a big compressor, or welder, etc.
Bluedodge
Michigan (not the Detroit part)
If it was me......
I'd make the "left wall" man door larger. Large enough to pull your motorcycle in and out of. I'd actually go with a single stall over-head door. Then I'd turn the bike-lift thingy 90 degrees so you essentially park on top of the bike-lift thingy when you get home. Extend your brick patio area another 15' so you can ride in and out of the side of your new addition.
Now if you really want to do it right, you're going to put your bike-lift thingy on a turntable. That way you can drive both into and out of your new garage. ...like the dang Bat Cave! Plus you can position your bike for lighting and tool access when working on it.
J
JimVonBaden
Northern Virginia
If it was me......
I plan on parking the bike in front of the car normally. I drive once a week at most, but ride nearly every day. However, the 36" door is just wide enough to get my bike out if needed. A rotating bike stand sounds cool, but would mean a much larger hole in the floor, and round, plus rolling panels that I can stand on. Now it is getting a bit complicated. I may get a 42" outside door instead, no garage style doors on that side since it will be facing the patio. The wife wants it cozy, not garage like. :eek:
Part of installing the pad for the extension is adding 10 feet to the existing patio. This will bring it right up to the other side of the workshop door. Good call.
John in OH
SE Ohio & Eastern Virginia
Ditto this 240v suggestion!! Also, wondering why you are not putting any outlets in the rear wall?? Don't skimp on the scope of electrical outlets or lights.
Except for the electrical suggestions it looks like a great addition!! Enjoy!!
NUTTSGT
Northern Central Ohio
Thanks,
Is it possible to get a variance for a little bigger like 16x16 ?
J
JimVonBaden
Northern Virginia
It will actually be 12X16. The angle of the land makes it narrower towards the back, and the greenspace issue.
Anyhow, good news, the work starts this weekend. I am increasing the size of the pavers, and adding the pad for the garage.
Original project:
Can be seen completed here: http://www.garagejournal.com/forum/showthread.php?t=145450
From this proposed size:
To this:
We extended the side pavers for a Hot tub that will be delivered tomorrow. We also extended the pavers to the end of the garage, and I added the outdoor furniture plan. Lastly, you can see the gray concrete pad at the back of the garage.
Stay tuned.
LX-Markham
Markham, Ont.
Exciting stuff!
LOL, the garage looks smaller than 20x20 in those pics. I guess I 'think' mine is bigger because it's a semi detached.
captain14
2 nice but cold and windy days this weekend. Do you think you will get the footer dug and ready for inspection this weekend?
I think you said your BIL crew was doing last of the work?
Good luck
J
JimVonBaden
Northern Virginia
Good luck
The digging and forms are almost done now. I am pretty sure they will be able to pour, weather permitting.
Yes, BIL's crew. Same guys who did the other pavers.
MikeF2316
Thornhill, ON
I'm not sure how I missed this thread last fall, but I have a couple of suggestions. My detached garage is like yours, no roof overhangs, no shelter outside the doors. I wish I had some, if nothing else it makes your outside lights last longer. And make a decent "pad" outside the door, to make it easier to get stuff in and out.
oldmxracer
Jim,
Just asking, You said about inserting the lift in the floor, but I see no provision for that in Your pour ?
J
JimVonBaden
Northern Virginia
Yeah, it is an issue. Extending the roof overhang on the front is a possibility, I may add porticos on the man doors, but I rarely use them.
Thanks,
J
JimVonBaden
Northern Virginia
Ancillary to the garage extension is a paver expansion with water and electrical.
I laid out the pipes, conduit and water, to ensure I have it available for my outdoor kitchen, and to move the backyard hose to the actual back yard. I will be running 12Volt wiring as well, for the outdoor lighting.
J
JimVonBaden
Northern Virginia
Finally some progress, while I was out of town!
Tomorrow I will get a better look, and start gathering the materials for the build.
