Quality tire gauge?
MushCreek
Upstate South Carolina
OK- I'm tired of crappy tire air pressure gauges that sometimes work and sometimes don't. I've never had one that cost more than a few dollars, but I'm ready to move up to the next level. Any recommendations for a reliable, durable tire gauge?
Rustypigeon
USA
My go to gauges are the Jaco Elite ($20) and an Accugage DT110 digital ($16) Both are accurate and durable. I would recommend both as good quality at a good price and durable.
I probably have 6 or so Milton pencil gauges. They are perfect for keeping in the glovebox since they are cheap and durable. They all read within 2 PSI of actual pressure, but Jaco and the DT110 read within .5 PSI of what I believe to be actual.
To estimate what actual pressure is, I just averaged all of my quality gauges and inflators and assume that the average must be very close to actual pressure. I just make a note with a sharpie for any gauge that deviates more than 1 PSI from this average.
shockwave
Marietta,ga
My current tire gauge is cornwell/Astro pneumatic digital tire gauge inflator works great and never let me down in the 3 years I have owned this great compared to standard dial type gaiges
heytrid
I bought one of these, decently priced and seems robust.
Autometer #2160
Fireball027
Niagara, ON
If you are looking for a good pencil gauge get a Milton. You can get them for 10-15 bucks.
if you want a nice digital inflator/gauge I recommend the Astro 3018.
I have been using the Astro one daily for the past couple years and other then a new battery needed it has worked flawless.
kylini
Zion, PA
I might need two- my 3/4 ton truck tires require 80 psi when loaded. Many of the gauges only go up to 60 or so.
You'll probably want a gauge that goes up to around 150. Ideally, your target PSI should be in the middle of the gauge.
Rustypigeon
USA
The Accu-Gage DT110 measures 5-150 PSI. The Milton Milton S-976 measures up to 160 PSI. I have both of these.
They are both about $16.
I have 4 or 5 Accu-Gage analog gauges. The come with a lifetime warrant. Yes, you have to pay for return shipping, but I have used the warranty several times. Last year I sent them all in and the were calibrated +/- 1 psi. Cost me about $10.
Pay extra for the rubber boot. I also like the swivel angle head and the one that hold pressure until the button is depressed.
straightcut
Phoenix, Arizona
I was in a similar position and wanted a quality gauge for the garage. I didn't want a gauge that required batteries that would be dead when I needed it and I wanted better accuracy than a pencil gauge.
After scouring eBay, I settled on a quality U.S. made US Gauge* (beware, some are made in China) and screwed it onto a Milton 691 straight head air chuck. You can pay more and you can pay less, but I'm completely satisfied with the price and quality! :thumbup:
*0 - 60psi, 2-1/2" diameter
lilcraigford
Portland, ME
MushCreek
Hmmm... there doesn't seem to be much consensus, other than maybe Milton. It's a little disconcerting that the highly rated gauges on Amazon still have a fair number of duds, either being off from the get-go, to failing after a short period of time, to not working at all. I have a couple pen types; not sure if they're Milton or not, but they have lost their function for the most part, although they are both pretty old. How does one calibrate a pressure gauge without a known 'good' one to begin with?
brtsvg
Treat yourself to a Milton 932 dial gauge, it's Christmas after all. I got one several months ago, am very impressed with it and it will last me for the rest of my life.
No BS Chinese **** for me, spend a few $$ and get something you are proud of.
