Aiming for 36" but some how end up with a 39" height work bench, after the last minute 3" caster instead of a huge 1" bolt as adjustable leg.... but still worked out great. at least it is finished..... probably not cheaper than buying but at least I get the custom size I wanted and heavy duty, plus some material left for something else....I jumped on top of it a few times no issue.... at least its a 4 piece design and can be taken down into pieces.
BOM
2"x2"x10gauge tubes sold in 24' length needed 4x 33.5" for legs 2x 16" for cross brace
1"x3"x10guage tubes.. soled in 24' needed 2x 70" since my base is 74"
1x of 2"x3/16x3' flats cut to 2"x2" squares for capping top of 2x2 and as taps for attaching screws to the wood piece.
1x of 2"x 1/4x3' flats cut into 2"x2" squares for capping bottom of the legs and drilling /tapping holes in the center with jig
Ikea casters Non-Marring type with stops supposedly 300LB rated I had M10x1.25 threads.
Ikea solid top... some discontinued model solid wood for kitchen cabinets 24"x96"x1" I think... cut to 84" for my requirement
4x 3" length 1/2x13TPI Bolt
4x washer
4x 1/2x13TPI thread coupling
Thx for all the folks suggestions in these threads.
http://www.garagejournal.com/forum/showthread.php?t=344117&highlight=hole
http://www.garagejournal.com/forum/showthread.php?t=340109&highlight=height
BOM
4x washer
