Good idea?Ryobi as tool investment
squeekers568
I bought a rigid impact driver got a great after Xmas deal on it at HD and went to go use if for the first time and it would not work so I had to take it back I really like rigid should I invest in Ryobi cause I'm on a budget cause I feel that there good tools they seem good in videos or should I wait and get a Milwaukee there tools are just expensive compared to Ryobi please help
I use my tools to work on cars
Local
Fallbrook,ca
Home use and even contractor I seen ryobis do fine. Not the best but a good bang for the buck. Another good alternative is Porter cable if on budget.
gdocktor3
Connecticut
A green Ryobi 18v hammer drill kicked my 18v Ridgid hammer drills *** a few months ago drilling 3/4" worm bits through a few hundred studs to run electrical. In fact, the Ridgid couldn't complete one hole. Granted it's older and been worked pretty hard it's whole life, but still. That Ryobi ran all day and didn't skip a beat. If I'm not mistaken Ryobi is made by same company who makes Ridgid and Milwaukee, only with cheaper materials to focus on homeowners and DIYers. The only thing that might not be worth buying are their impact wrenches. They aren't nearly as powerful as a Dewalt or Milwaukee for example, otherwise their tools are pretty good for the price.
Parrothead
Earth
If your a homeowner or even a serious DIYer, I'd say Ryobi is the way to go. Battery support is going to be there for years to come as they all use the +One system. They transitioned from nicad to lithium and you could still use the same batteries.
The only other company that did that was DeWalt. I went from 18v nicad to 18v lithium, to 20v lithium with an adapter. That means I don't have to replace fully functional tools because the battery system isn't supported anymore. I don't think Milwaukee, Makita, Ridgid and Bosch offered the same opportunity, though feel free to correct me if I'm wrong.
EOC_Jason
Bentonville, AR
I don't use cordless tools much, I went with the craftsman and I'm happy with them (they are the same as Ryobi)... Though I wish I went with Ryobi brand because they are constantly coming out with new products and refreshing their line, Craftsman hasn't come out with anything new in quite a while.
The great thing though is Ryobi all use the same battery, doesn't matter if it's the old blue or new green models...
They aren't the top-end stuff, but for the home DIY you couldn't ask for any better for the price. I've seen a fair amount of contractors use them too.
Usually at HD they have lots of benches set up to try out all the brands. See what feels comfortable in your hand and balanced.
But if you were going to buy you should have done it back during Christmas they had some good deals.
squeekers568
I did buy the rigid and it didn't work it was the gen x5 impact for 78$with tax I want Milwaukee but there expensive I work on my car and my familys car alot I have beat up used no name tools that aren't cordless and barely work
pauls_workshop
Indiana, USA - Underappreciated Place to Live!
Doctor: The 1/4" Ryobi impact driver is a super great tool, easily the equal of most other brands. I've used my two for about 10 years now. The 1/2" impact wrench is also excellent. I have the older one, which can handle anything auto I've asked it to do. The newer 1/2" available now is higher torque and even better. While the 1/2" impacts are less torque than some pro brands as you say, they also aren't at the low end either, but somewhere in the middle. Good for most people. True pro mechanics will want only the best and highest torque ratings of course. - Paul
Heel2toe
Massachusetts
Personally I'd go return your Ridgid as it was DOA and pick up a new one. With the Lifetime Service Agreement I'd say theyre perfect for home use. Can you get something better sure but is it worth the added cost for a difference you probably won't even notice, hell no!
I've been using my Ridgid tools for a little over a year so far and they've done everything I've asked them to. The tools work well and after I got them registered for the LSA its tough to beat that. My only gripe is a lack of more tools like a dedicated 3/8" impact but is what is is.
bdelmar2
I guess it depends on what your expectations are, what you plan on doing with the tools.
I have a set of Ryobi cordless I've had for years. They aren't the most powerful, and the batteries will need recharged if they don't get used for a week or so, but for what I need them for they worked fine.
I rented a crappy house cheap, the landlord wasn't going to do any repairs, nor had he in years. I was able to keep it from collapsing and pretty much functional for several years with my trusty bucket of tools and the set of Ryobi stuff.
If you want to cut anything with the saw, get a thin decent quality blade and you can cut a few 2x4's (like 3 - 5) before you need to change the battery, for example.
I wouldn't try driving 3/8" lag screws with the drill, but for basic drilling or drywall screws it works fine.
They have come out with better batteries since I bought mine, so the performance is probably better now.
In any case, between the cheap rent and not buying crazy expensive tools I didn't really need I was able to buy my own house, and now I can replace the Ryobi with better if I want and not sweat it.
If you are trying to get a job in the construction industry, or do that kind of work for a living on the other hand, you are better off buying the higher end tools.
The Ryobi aren't going to hold up to that kind of use for long most likely and you will end up buying the tools twice when you can least afford to.
SilverBulletZ06
This ^^^^^^ . If I was just starting out I would pick the best battery deal and get everything I needed to use that battery system.
It's important to understand that ONLY the batteries that come with tools have the LSA. Makes it worth the extra cost to get the kit.
justanengineer
Motor City
JMO but I consider cordless tools disposable, and I prefer the Milwaukee M18/Fuel line at that. Corded tools OTOH last dam near forever, can very commonly be bought for peanuts used, and if you buy something decent it will be very rebuildable. The main reason I LOVE Milwaukee - cheap, readily available parts that are stocked dam near forever. My 1968 Sawzall still has many parts available, runs great, and has been ridden hard since new. Yes, there is a convenience factor of corded vs cordless but Joe Homeowner with a tight budget probably should weigh convenience vs replacement cost.
squeekers568
I did return the rigid they wouldn't replace it though cause it was a sale item and no more were in stock
tcianci
Walpole, Ma
How about you invest in some punctuation?
ddawg16
S. California
Almost all my stuff is Ryobi. It's built my garage and 2-story addition. I used the dog **** out of them.
for the money, they are the best value/performance. Even my weed whacker uses the same battery.
zoomzoomjeff
Des Moines, IA area
Ditto. Have the old dark blue Ryobi set with NiCad's. Now that they went to Lithiums they're great, still fit the tool. Used the dog **** out of mine too. 1/4" impact, 1/2" drill, sawzall, tiny circular saw, jig saw, worthless vacuum, a ******** chain saw they had a long time ago, and a caulk gun.
RE: Ridgid's Lifetime Warranty, I've been told from the guys at Depot that it's the Lifetime of the tool not a forever warranty, so when that model is discontinued, there's your warranty. ..........The more you know.
JKady
Spanaway, WA
Almost all my cordless stuff at home is Ryobi, I bought a decent set for something like 75 bucks used a couple years ago. I use my impact driver and 1/2" drill on a weekly basis, sometimes all weekend long with no problems at all. On a budget/for home owner use they are just fine. I didn't want to drop the bucks on tools for my home garage like I do at work since they don't make me money but I've been pleasantly surprised. The NiCad's I got originally wore out in pretty short order because I didn't take care of them like I should've, but the lithiums are great and lighter/smaller.
slow_mow
Middletown, CA
I have a feeling you're still using NICAD's. Try a LiIon and you'll be pleasantly surprised.
I started with a basic Ryobi set 11 years ago. It came with Drill, Circular Saw, Sawzall, and Flashlight. All of those tools are still going strong, along with many tools I've added along the way. Now I run nothing but LiIon in all of them, blue or green, and couldn't be happier. one+ is the way to go.
redmondjp
Redmond, WA
To the OP - you can't go wrong with the Ryobi. Start small - buy a drill/impact driver kit with two batteries and a charger. You'll have a whopping $99 + tax into it. Then if you like it, you can add to the system. If you don't, you can sell it for $50-60 and try another brand.
And they have that new LED worklight that uses the 18V batteries now as well that I'm drooling over.
Fredartic
Ste-Sophie, Quebec
I personally bought few years ago (in 2005 around), a bundle of Ryobi tools (chain saw, jig saw, circular saw, drill, impact drive, lamp, vacum...) and I still have it. The originals batteries died in 2014. I have also the big yellow brand that I won a kit of 18v. I use most of the time my Ryobi tools that are more lighter and they do the job as well. I use my Dewalt just when more power is needed. I love so much my impact driver Ryobi. I appreciate that Ryobi made compatible the old blue tools with the new green batteries, not like Dewalt that they complicated things with an adaptor that increase the weight and the longer of the tool... Recently, my Dewalt charger burned as it is newer than my Ryobi... so, I suggest you to go with Ryobi. My wife just bought me a new kit of impact driver, drill and charger that became on sale on black friday event at a ridiculous price and I'm very happy.
kctyphoon
Jersey/Staten Island
Just look at both line ups the different brands offer, and go from there. Pick what you think offers the most. The Ridgid Gen5x stuff gets alot of good reviews, but some of the Ryobi stuff is pretty impressive. The newer 1/2" impact wrench is a good buy for the price..
