Should I use these fixtures in my new shop?
poppinjohnnies
Kansas
I have several 3 bulb 4' T-8 light fixtures that were removed from a commercial building. These are the typical dropped ceiling fixtures. I'm in the process of building a 32x40x14 shop and I wondered whether these will be sufficient for the high ceiling. It will be a 3-12 pitch clear span building. Any suggestions / ideas are appreciated.
I wanted to place a link to my shop build in the gallery section but can't figure out how to do it. I'm not a very "techy" dude. :dunno:
checkthisout
Yeah they'll be fine. I currently have 4 4 bulb toffee lighting a 28x40 work space. Ceiling is 16'.
txvwnut
Bedford, Texas
What's the voltage on those lights. Most of the commercial ones I've seen were 277 or 480, and just changing out the ballast is as much as new lights.
cybrdyke
USA
They're made to be used in a grid ceiling, but you can find a way to hang them, I'm sure.
Normal T8 lamps are fine, but you can find some that are slightly higher lumen if you want a little more light. Another option is to drop in some LED lamps. You dont need to do any fixture re-wiring and you can save about 50% energy.
Good luck
CD
P
poppinjohnnies
Kansas
What LED bulb would you recommend for these fixtures? The current bulbs are F32T8-SPX41 4100K 32 watt bulbs.
Norcal
Never have seen a 480V troffer, 120V or 277V, or 120-277V yes.
