Tim240Z
Well, I spent a few hours today replacing the infamous intake gaskets on my 71 C20 (with 99 Suburban L31 engine/trans). I did everything by the book. Everything worked out well....EXCEPT....when removing the rubber water line from the front of the manifold, I managed to twist the steel water heater line that comes up from the water pump. Now it leaks there, at the spot where the steel tubing pushes into the top of the pump. I have tried a couple of glues (Seal All and 2 part epoxy), but it doesn't want to seal, it still sweats from the joint.
Any clues as to how I can re-seal this?
Tim
Tim
